Question about Frigidaire FGX831CS Top Load Stacked Washer / Dryer
Model lc120j working on fridgaire stackable washer and dryer. trying to replace the dryer belt. already have the back of the unit torn apart, need to know what is the simpliest way to get this belt on the motor pulley without having to take the motor out? email address: lynn7278@verizon.net
  • 116 Answers
SOURCE: Frididaire FLSE72GCSA stackable washer dryer
It is possible that the belt has come off or the lid latch is no functioning.
First unplug the machine then remove the two screws from the front lower edge of the washer.
The front panel will lift up towards you at a 45 degree angle. The latches will release than the entire front panel can be place out of the way.
The lid latch can be seen on the underside of the top panel to the right, check that the wires are not loose.
You will see a large motor mounted upright near the base this should have the belt around the pulley to the bottom of the tub assembly. Check for obvious damage
Outside of this you will need a repairman for help.
Posted on Jul 28, 2008
aborcass
  • 2651 Answers
SOURCE: STACKABLE WASHER/DRYER DISASSEMBLY
FLSE72GCS6 this model number is showin as a complete laundry center, not 2 seperate peices. in which casse there is no seperating them
Posted on Dec 09, 2008
  • 1028 Answers
SOURCE: Model number on my Frigidaire stackable washer/dryer is wore off
ckd dryer door and door frame
Posted on Dec 13, 2008
SOURCE: Frigidaire Gallery Series Model # GLEH1642DS1 woint spin or agitate
Works very well it just wont spin out. its like i have it on no spin
Posted on Apr 20, 2009
  • 512 Answers
SOURCE: I have a Frigidaire Gallery Stackable that has a screechy dryer
Sounds like it is worn out. Get a parts diagram and take it apart and see what parts are missing or worn out. The belt is probably coming apart and that is the black stuff. There are several plastic wear plates and a bearing/bushing for the drum, plus the belt idler and all these can wear out. The motor could also have a bad bushing in it but more than likely that will require a new motor as they don't usually sell just the bushing or end caps.
Posted on Sep 03, 2009
How do I replace the belt on stackable laundry center
oh yukkkkkkkkkk hate working on these stackables. u have to break them apart for most jobs, try googling how to take apart ur brand model and youll get instructions, sorry cant help more
Sep 13, 2014 | Frigidaire Dryers
The stackable washer will not agitate
Give me a model number. Fridgedare and White westinghouse made some of these stacks for Kenmore. I'll need to know the manufacture. Reply with the whole model number and I'll help.
Aug 27, 2009 | Kenmore 98702 Stacked Washer/Dryer
My kenmore stackable model number has been
there should be a number on the belt take it to the spares place and they should be able to match one up for you
Jul 15, 2009 | Kenmore 98702 Stacked Washer/Dryer
Stackable washer/dryer
hi..
When your dryer drum isn’t turning anymore, it’s usually a broken belt. Tearing the dryer apart is usually straight-forward enough but stringing the new belt on the motor and idler pulley can be tricky. The Complete Encyclopedia of Dryer Belt Configurations shows the belt configurations for almost every dryer brand you can think of.
this will fix ur problem..
thank u rate me
May 25, 2009 | Kenmore 93702 Top Load Stacked Washer /...
Asko stackable dryer/Bosch stackable washer compatability
If you arer going to replace the washer with a Bosch Axxis model, it will simply plug into the back of the dryer (if it is electric) because normally the dryers are 220 VAC. Works A-OK.
Nov 23, 2008 | Bosch Axxis WTA 3510 Electric Dryer
Ge spacemaker washer and dry stackable.
if you have a broken belt... remove the back. and the drum support. then you can remove the belt... and replace it with the new one...pull back the pulley and them loosen the belt... let me know
Sep 16, 2008 | GE WSM2480DWW Unitized Spacemaker Washer...
Kenmore Model 94812301 Stackable Washer/Dryer
try adjusting the feet on the bottom. apart from that the bearings may need replacing.
Sep 01, 2008 | Kenmore 94812 Top Load Stacked Washer /...
Disassembly
what are u trying to repair on it?
Aug 20, 2007 | Whirlpool LTE6234D Top Load Stacked...
Frigidaire FGX831CS Top Load Stacked Washer / Dryer Logo
80 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
