Question about RTO Atwood Water Heater - 6 Gal LP
Have an Atwood LP water heater in myacht houseboat. Water Heater lights fine and runs ok for a short period of time, then shuts off before water gets hot. Can try to immediately light it back but nothing happens. Can wait awhile, it will light back up, run for a short period of time, then shuts down again before water gets hot. Thanks
  • hootie1006 May 23, 2011
    Thank you very much! I will get the model number and order the thermostat. Is it hard to install?
  • RTO Master
  • 43,501 Answers
You have a bad thermostat/ECO.... the ECO cuts out and will keep you from relighting till it cools.
Here is a site that has parts for your heater, but you will need to know the exact model number to get the right part.
Atwood parts
heatman101
Posted on May 23, 2011
  • D. Floyd Kolb
    D. Floyd Kolb May 23, 2011
    Not hard to install.... just make sure to check out what wires go where BEFORE unhooking them.
I have a G6A-7E electronic ignite water heater.
Make sure propane is on and getting to your stove burners ok, first, then try switching it back on. If it fails to ignite, shut switch off and try a couple of times, if still no ignition, get back to me.
May 24, 2010 | RTO Atwood Water Heater - 6 Gal LP
Have an G6A-8E Atwood water heater. It Starts fine and shuts down after a couple of seconds. I can see the diode in the control board continue to spark after ignition I replaced the igniter.
If it has the little thermal cut-off in power wire to thermostat (has a little plastic jacket over it) try removing it, and connect female spade from power wire, directly to male spade on thermostat, and see what happens. Also, make sure electrode is positioned in flame good for flame sensing properly.
May 21, 2010 | RTO Atwood Water Heater - 6 Gal LP
I have a RV Atwood water heater and it ignites and starts ok but shortly thereafter it shuts off. I wait a minute or two and it restarts but shuts off again. Could it be the circuit board, or the sensor in...
You may have a control board issue, there is no sensor that is IN the water tank your thermostat controller are exterior to the tank under the black foam looking piece which I think is where your trouble lies
Feb 19, 2010 | RTO Atwood DSI-RV Water Heater-6 Gallon
Atwood water heater runs for two minutes and shuts down, replace thermostat and EEC clean thermocoupler still no joy, short out thermostat lead it ran until the EEC open. any ideas???
If you have the little thermo cut off in the circuit to thermostat, (little resistor inside small plastic tube) try removing it from the circuit. Just pull the wires at each end and attach directly to thermostat where it was before. If it works now, you found the problem, if not, get back to me.
Sep 04, 2009 | RTO Atwood Water Heater - 6 Gal LP
Need the removal procedure for the G6A-8E RV water heater.
SHUT OFF ALL ENERGY SOURCES TO HEATER. REMOVE ELECTICAL SUPPLY LINES AND TAPE THEM OFF. DRAIN WATER FROM HEATER. REMOVE AND CAP WATER LINES. TURN OFF LP. REMOVE AND PLUG LP LINE. REMOVE SCREWS FROM OUTSIDE CIRCUMFERENCE OF HEATER. PULL HEATER OUT.
Aug 27, 2009 | RTO Atwood Water Heater - 6 Gal LP
Atwood series 2001 fault alarm
Posible dirty sensor affecting sampling of air. Gas sensors have little filters that need periodic replacement.
May 06, 2009 | RTO Atwood Water Heater - 6 Gal LP
Atwood water heater problems
probly the sensor on the modul. Take and clean it off with emery cloth and then reinstall it.
Jan 21, 2009 | RTO Atwood Water Heater - 6 Gal LP
RTO Atwood Water Heater - 6 Gal LP Logo
511 people viewed this question
Top RTO Water Heaters Experts
Jim Goldsmith
Jim Goldsmith
Donni Steen
Are you a RTO Water Heater Expert? Answer questions, earn points and help others
