Question about Siemens Washing Machines
Siemens E12 46 touch and wash will not drain. I tried draining it but the plug will not come out of machine, is there something special to do? I can't find users manual on line.
  • 45 Answers
SOURCE: Aftron Washing Machine draining power
check and see that the entire drain line is free from any obstructions, if you have lowered the hose and still not draining entirely, its a sure sign of obstruction somewhere in the drain line or even the drain pump.
Posted on Jan 27, 2008
  • 1462 Answers
SOURCE: Ariston Washer Dryer AML 105
i know it sounds simple but have you checked the filter and also check for foreign objects in the pump impellor
Posted on Jun 26, 2008
  • 3741 Answers
SOURCE: washing machine will not drain. water wont drain
If your washer won't drain, check these:
It spins, but doesn't pump
It doesn't spin or pump
It pumps, but the water returns
It spins, but doesn't pump If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the hoses from the pump and pull the item out.
To remove the sock from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using needle-nose pliers, try to grab and remove the clothing through the port.
Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator, top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might be happier getting a qualified appliance repair technician to do the job.
If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be turning, the internal impeller may be broken. If so, you need to replace the pump.
It doesn't spin or pump If your washer doesn't spin or pump water out but the motor is running, your washer probably has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it.
It pumps, but the water returns If the water that pumps out of the machine goes back into the machine after the spin cycle, your washer may be siphoning the water from a laundry tub that has a slow drain, back into the washer. The usual remedy for this is to improve the draining of the laundry tub. (Is something stuck in the drain?) Also, check for these problems:
  • If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess.
  • If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
Posted on Aug 20, 2009
  • 289 Answers
SOURCE: washing machine will not enter spin cycle. When
the washer goes in one direction for wash and the other way for spin.sound's like you have a bad motor.
Posted on Nov 18, 2009
SOURCE: SIEMENS XLM1400 WASHING MACHINE DOES NOT SPIN
siemens xlm 1400 washing machine fills with water but wont wash
Posted on Jun 04, 2010
I want to know how can i cleare the erro f21 about siemens washing mechine.
Error f21 happens when the machine does not drain in an appropriate time. This can be caused by a blockage in the drain or a faulty pump. There is a previous post in relation to resetting this error. have siemens washing machine that says f21 what does that mean
Jan 14, 2017 | Siemens Washing Machines
I have smelly brown deposits coming back into the wash and staining the wash
If your drain hose is draining under the sink its probably coming from there.Pull the hose through as much as you can
and tie it up as high as it will go at the sink waste.this will stop
any waste from your sink flowing down the washing machine drain hose.
Mar 07, 2015 | Siemens Washing Machines
Siemens s14-44 washing machine door stuck
assuming its stuck because its not emptied propperly.remove drain hose from rear and with a bowl or large pan hold the hose at ground level.it will then drain,it doesnt need to be plugged in.but when u switch on you ll prob hear a clic.it should now release
Apr 16, 2014 | Washing Machines
My siemens washer front loader is displaying an E04 what does that mean
Drain is blocked - unplug the auxillary drain plug and check for clog.
Mar 21, 2014 | Siemens WXL142 Front Load Washer
Siemens SI14-44 washing machine is error coding F:18. something wrong with the emptying of the machine.... is the filter blocked? is so where can you clean out the filter?
check in the manual for the error code most of washing machine if the error code is in users manual its means its only minor problem,but if the error code is not in users manual its means you need to call an service technician to not waste your money or time if you do by your self.
F:18? if this error is for water stuck?
for the automatic washing machine mostly have drain pump, please check the filter of your drain pump, if clog your drain pump of some hair pins,cotton buds or coins or any small item,that the cause of water stuck,and it will long time draining or totally not running the drain pump.and its cause of stop of cycle of washing machine in rinse time or spin time,because after washing the pump must be on to remove water before start the next cycle.
Nov 02, 2013 | Washing Machines
Siemens washing machine keeps washing
Hi Linda Bailey,
If it keeps washing it could be that it is unable to progress to the Drain or Spin cycle. The likely culprit could be the Drain Pump Filter. To clean the Drain pump filter:
1) Plug the appliance out.
2) Open the small compartment below the door (Either Right or left hand corner) You will see a small pipe and a circular lid with a handle.
3) Drain the water by using the small pipe (Get a bowl for the water!), take of the cap of the hose or use the tap on the pipe on some models.
4) Once all the water is drained, open up the cap (Again.. Keep the bowl close by for spillage) by turning it anti-clockwise. Once off, clean the filter which is found on the cap.
5) stick your fingers into the now open compartment, be sure to clean out any obstructions, and feel if the impeller inside can turn freely.
THATS it! Now re-insert the cap, and close the pipe if open. Plug your machine in and viola!
It should solve your problem.
If not, let me know.
Kind Regards
JEDEMEYER1
Oct 03, 2011 | Siemens WM14S794GB Front Load Washer
Dishwasher siemens is not draining water.
Hello & Welcome to FixYa
Dishwasher not draining completely problem usually occurs due to clogged/blocked drain hose or the drain pump not working. First try to clean the drain hose and drain pump filter for any clogs, then check drain pump operation. If the problem returns after cleaning then it is the drain pump that needs replacement. Please get back to me if you have any other questions.
Kevin
Jan 09, 2011 | Siemens WFXD8400UC Front Load Washer
Water will not drain
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Oct 10, 2010 | Siemens Washing Machines
Washing Machines Logo
255 people viewed this question
Top Siemens Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Siemens Washing Machine Expert? Answer questions, earn points and help others
