There is a Eurolec WD001 washer/dryer installed in the flat I've recently moved into. The machine has got to the end of a programme, but the door will not open. No instruction manual has been left with the machine. How do you open the door?
  • 1294 Answers
SOURCE: electrolux ew 1200i
Click on Electrolux (below FIXYA)on this website, type in your model No & search. You will get a shortlist; click on your model,below the page u will get Manual/Guides. Click on the blue - voila! u hv your manual on line!! Good luck.
Posted on May 01, 2007
  • 121 Answers
SOURCE: Instruction Manual
it can be found here dont think thats the full model number but
http://www.whirlpool.co.uk/app.cnt/whr/en_GB/pageid/pgsrvifuhome001
Posted on Mar 03, 2008
  • 108 Answers
SOURCE: WD440 programme m
This sounds like a faulty pcb and/or inlet valve. see links for prices.
meatballs77 - If you have warranty (the machine is less than 1 year old which yours is) or paid for extended cover then call hotpoint to replace... Hotpoint should be able to fix this - this should be free. call 0870 4422 510
Rememer parts are free up to five years - but there is a £90 callout fee after the first year.(unless you extend the full warranty)
Posted on Mar 26, 2008
kjmac
  • 97 Answers
SOURCE: I do not understand the
hiya,
what make of machine is it?
can you give a brief description of the symbols
cheers
Posted on Jul 28, 2008
informatica
  • 1114 Answers
SOURCE: candy smart cmd 146 ( washer and dryer)
Hi - You can download the manual from the link underlined in blue below:
Candy
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Posted on Aug 10, 2008
Candy as108
IT has shorted out u will need to replace board
Aug 21, 2013 | Washing Machines
The door on my Hotpoint Washing Machine WT741 won't open even though the programme has ended. We've tried running the programme again and pumping out but still the door won't open.
The door latch may have broken. You can sometimes open the door from the inside. You will know the door latch is broken if the door handle is floppy. If the door handle is not floppy - then the issue is probably with the door interlock. This is the electronic part that prevents the door from being opened during and after the wash has finished.
Either way - you'll need to get the door open.
To do this, unplug the washing machine from the mains and then move it out from where it is. Tip the washing machine to a 45 degree angle. Don't tip it over 45 degrees as you may break internal parts.
You need two people to do this - one person hold the machine at 45 degrees angle, whilst the other person puts their hand up into the machine - you should be able to feel the door catch mechanism and depending on the model, open the door that way. Sometimes the manufacturer has helpfully put a manual release inside - and sometimes they don't.
If you aren't able to open the door using that method. Get a length of strong string and poke the middle section of the string into the gap between the washer door and the machine body - to the right of the door handle. Use a flat headed screw drive to push the string into the gap, all the way around the door, so that you end up with the two ends of the string on the left hand side of the door. Now have someone put the ends of the string whilst the other person pulls the door handle. If the string is pushed in far enough it will release the door latch and the door will open. It takes a bit of persistence to get it right.
Once you have the door opened you can usually replace either the interlock mechanism or the door latch itself. Parts are easily available online from sites like espares and yourspares.
Mar 29, 2013 | Washing Machines
I have a bosch logicxx 7 washing machine. I've
Suggestion: Keep the beep button pressed or keep pressing till the beep indicates 'off'.
Mar 24, 2013 | Washing Machines
Dryer function on De Dietrich washer-dryer doesn't work
take care do not play with electric ??????????
????????????????????????? warning????
check heating element
check stats
check you have power at element
Nov 05, 2012 | De Dietrich LZ9619 Front Load Washer /...
EUROLEC Model WM002 Washing Machine How do I open the door after it completes a wash?
im hoping you solved the mystery and would be kind enough to tell me ,how the door opens , moved into a new house with that machine insitu, i cannot get the door open have wet washing inside since yesterday, i would appreciate if you would let me know the secret.
Dec 30, 2010 | Washing Machines
Frigidaire Affinity ATF7000E Front Load Washer My washer & dryer are brand new 2 days old! I have ran about 8-10 loads through them now and EVERY time the washer spins it vibrates the whole house. The...
There's a few things that cause this and there may be no easy answer. Is the washer on the second floor? Is the washer on a ceramic tile floor? ...wait a minute, you said it vibrated the whole house so this makes me think the floor has some "give". If any of these there is no easy fix. I've seen ONE thing that does work though. It's a pedestal that spans under the washer AND dryer, one long one which distributes the weight and vibration. I don't know where to get one but I do know they are out there. One of my customers had one and I took notice because the floor was ceramic tile and the washer wasn't vibrating all over the place. It was very stable.
Oct 12, 2010 | Frigidaire Affinity ATF7000E Front Load...
I do not understand the symbols on the wd001 washer dryer
hiya,
cheers
Jul 27, 2008 | Washing Machines
WD440 programme m
Nov 07, 2007 | Hotpoint Aquarius WD63 Front Load...
Electrolux ew 1200i
Apr 30, 2007 | Electrolux EW1200i Front Load Washer /...
Washing Machines Logo
48 people viewed this question
Top Washing Machines Experts
