Question about Lexmark X2550 All-In-One Printer
NOT PRINTING FROM USB - Lexmark X2550 All-In-One Printer
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • Lexmark Expert
  • 289 Answers
If you use a laptop.
please assure the port on setting properties (driver) it must be the same with your plug on laptop.
see a picture
Posted on May 22, 2011
My printer is not printing
Standard checks: If you are using Windows system up to Vista: Check all these:
Power cable, USB or LPT serial cable, the port to where you are printing in the printer properties configuration, (right click the printer icon) - (computers with multiple USB ports: unplug and plug into a different USB port and watch the printer icon change to ready in the computer/system/printers window- very subtle). Sometimes stored print commands from several days ago will begin printing.
Check cartridges, error light indications you can research on Google.
Jun 09, 2016 | Office Equipment & Supplies
WHY DOT MATRIX PRINTER NOT PRINTING DOS BASE PRINTS
It can't.
DOS printing need LPTx parallel port because DOS don't understand/support USB.
YOU can share the printer with windows printer driver, then
go to CMD prompt
Type
Net use lpt1 \\<computername>\<printersharename>
Then print DOS job to LPT1
May 12, 2014 | Parallel USB Print Server 2 Port USB&1...
Baud rate hp 9600 for HP M1522
you are using serial port printing...or usb port printing
if you using usb port printing no need to change the buad rate...????
Oct 01, 2013 | HEWLETT-PACKARD LaserJet M1522nf...
I am simply making a copy and it is printing super slow.
hELLO IDEAL58ST,
While printing from the USB Port sometimes slow printout/data transfer will result in slow printing of print jobs. SOLUTION: Solution After the printer is installed on the USB Port, check the description under the Ports Tab what is selected. Please refer to the figure below : c00873625.jpg Using the USB/ Virtual Printer Port and DOT4/ HP Laserjet 2420, under the Port/Description Tab printer speed will be as per the standard. Whereas using the DOT4/ Generic IEEE 1284 under Port/Description Tab, Printer speed will be very slow. If DOT4/ Generic IEEE 1284 is selected by default, then you have to uninstall the USB driver from the Device manager and plug in the USB cable again. Then it will detect the printer and USB port with respect to the printer model.
THANKS.
Sep 06, 2011 | HP OfficeJet 6110 All-In-One InkJet...
My printer shows ''User intervension required'' other than ''Ready''
The issue may be resolved by clearing the pause printing in the printer driver or by setting up a parallel connection with the computer. Clear pause printing
  1. From the Windows Desktop, select Start , Settings , and Printers .
  2. Right-click the HP LaserJet printer icon that is being used.
  3. Select the Work Offline or Pause Printing option (if enabled) to remove the check.
  4. Print the document again.
Establish parallel connection
  1. Turn off the printer or remove the printer from the network.
  2. Connect the printer to the PC using a parallel cable.
  3. Power on the printer.
  4. Print the document again. NOTE: If the User Intervention Required message reappears, disable or remove any HP LaserJet software utilities loaded on the system (for example, Status Window, HP Toolbox, etc.). Prove printer functionality and troubleshoot communications; try printing again.
Uninstall and reinstall the driver After performing a cold reset on a product installed with USB, a higher DOT4_00x port is created, causing the printer to hang while printing. NOTE: This is required with products installed on a USB port only.
  1. Uninstall the USB printer driver.
  2. Remove the HP folder and AIO folder from the hard drive.
  3. Reinstall the USB printer driver.
CAUSE: This error can occur if when using a network or printing from a laptop. When the print job goes into a pending status, the printer is either in Work Offline or Pause Printing mode. Hope this helps. Please rate my response.
Thanks.
Have a good day.
Mar 15, 2010 | Computers & Internet
Printer is connected but does not print
Hi
Thanks for using FixYa. Please check the following things first---
· The printer cover is closed and the rear access door or optional duplexer is attached.
· The printer is connected to the power source and turned on.
· The cable connections are secure and the cartridges are correctly installed.
· The paper or other media is correctly loaded in the in tray.
Now check the printer cable connection: If the printer cable is attached to a USB hub, a printing conflict might exist. Use one of the following methods to resolve the conflict:
· Attach the printer USB cable directly to your computer.
· When printing, do not use other USB devices that are attached to the hub.
Now verify if the printer is connected to the correct USB port: If the computer is configured to use both the back and front USB ports on the printer, then you might be printing to the wrong port. The computer has two versions of the printer driver: one for the front USB port and one for the back USB port. If you are connected to the back USB port, but select the printer driver that is associated with the front USB port, the printer will not print. In the application that you are printing from, click File and then click Print. The Print dialog box opens. The Print dialog box displays two versions of the printer driver. Select the version that is associated with the port to which you are printing. The issue will be resolved.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Aug 12, 2009 | HP DeskJet 6540 InkJet Printer
Hp office jet 4255 printer not printing anything or copying
ok..first try to make a copy and check if it copies fine or not..
if it copies then hardware is working fine..
turn off the laptop and unplug the USB cable..
turn on the laptop and wait for 5mins and then connect the USB cable..once the USB cable is connected do not try printing..wait for the hardware to get installed..
and then go to the printers folder and check if the printer icon says 0 ready..if it says then try printing..that should work
Feb 19, 2009 | HP OfficeJet 4255 All-In-One InkJet...
PROBLEMS PRINTING
Hi Anabel,
I've heard of this kinds of issue in cases where an adaptor cable (usb-serial, usb-parallel) causes this. But if this isnt you perhaps you can try reloading the printer's newest driver.
Jan 21, 2009 | Samsung SRP 350 Thermal Printer
Printer P 400 not regonized by windows XP
check under device manager-universal serial bus controllers if you have USB PRINTING SUPPORT
-check for conflicts (?, !, X marks)
-If USB printing support doesnt show, unplug usb cable and try plugging cable to different usb port
-notify me after checking
Apr 05, 2008 | Office Equipment & Supplies
Printer not working when hooked up to notebook
uninstall the driver completely,reboot the system,again install the driver first,connect the printer afterword.
thnx N
Jan 29, 2008 | HP Deskjet 3845 InkJet Printer
Lexmark X2550 All-In-One Printer Logo
23 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
