Question about Kitchen Ranges
How to get a broken screw out, so that we can replace the belt on maytag neptune washer? Do you have pictures of this? My neptune washer is a mah3000 it was purchased in 1998. It stopped working the other day. It would not spin, so when we took the back off, the belt fell off, and so did the screw that hold's the belt on.
  • flowerchi950 May 23, 2011
    The screw that turns the main pulley. This is the screw that you see when you take the back off. It goes in the middle of the wheel that turns the drum.
  • Kitchen Ranges Master
  • 2,331 Answers
What screw holds the belt on,the belt raps around the top pulley and down to the bottom pulley,what screw are you talking about.
Posted on May 22, 2011
  • Sal DeAngelo May 23, 2011
    the only thing i can tell you is there are easy out tools you can buy to try and get it out or drill it out and then get a tap and die kit so you can screw in the next size screw but i don't think this is gonna be easy to do.
My Maytag Neptune Washer Model MAH3000AWW, Serial 35269627WB drains the visible water that can be seen inside the drum, but then does not drain the rest of the water that remains between the drum and its...
Hello, The earlier Maytag Neptune front loaders have a balance ring on the inner tub that has liquid in it and that causes the sloshing sound when you turn the tub by hand. That is normal.
I noticed that you have a MAH3000... Have you replaced your door latch wax motor yet? If not, it will fail and damage your control board located behind the timer. See NeptuneHelpSong for a video that explains the failure.
I hope this helps...
Apr 25, 2011 | Maytag Neptune Washer
Sometimes there is water that fills in my washer after I use it. It does not happen right away but by the next day. I don't know the model but I do know this is an old washer....gold....I have had it for...
Q - My washer seems to keep filling  with water, the water keeps coming in the washer and going out the drain without the washermotor running.
A - This often is a drain hose that is too low or a drain hose that has been pushed too far down inside the stand pipe....the water is actually siphoning out of the washer. Do not "seal" the drain hose to the house plumbing pipe, this will also allow the water to be siphoned out.
  1. Boot change helps
  2. Consumer Display Code Table on the Electronic Display Maytag Neptune Front load washer
  3. Free on-line repair manual for the Neptune washer MAH3000, MAH4000, MAH5500, MAH7500  ( Acrobat reader required )
  4. How to access the console on the mechanical timer models
  5. How to access the workings of the washer
  6. My washer door is locked and it will not open up...HELP
  7. My washer will start when I push the start button, but a few seconds later, it will shut off
  8. My washer will not pump out + pump noise problems
  9. My washer will not spin
  10. Odor complaints from the front load Neptune washer - mildew complaints + a new "freshen up" procedure
  11. Parts breakdowns/exploded of the Maytag Neptune front load washer ( mechanical timer models )
  12. Problem chart for MAH3000 & 4000 Neptune washers
  13. Readers repair tips
  14. Trouble shooting tips from the Neptune manual for MAH3000 and MAH4000 models
  15. Tips from our friendly engineer on changing the boot and re-installing that clamp and spring
  16. Tips on changing the washer belt  ( acrobat reader required ) Belt parts link
  17. Tips that show what components need to be checked/replaced if a certain resistor on machine control board is bad. It is as follows: Burnt resistors in Maytag Neptune washer models MAH4000 and MLE/MLG2000
  18. Washing one item in a front load washer
Apr 01, 2009 | Maytag Washing Machines
Maytag neptune smoking
it could be the seal on the drum or it could be the belt getting too warm
Jan 12, 2009 | Maytag Neptune Washer
Neptune mah5500bww
I've had the same problem with a Neptune MAH3000. I replaced the mother board to no avail. I replaced the timer control to no avail. I then replaced the door lock assembly (wax motor, door switch, etc.) and problem solved. Luckily, I had another machine that I could rob parts from.
Nov 02, 2007 | Maytag Neptune MAH5500B Front Load Washer
Maytag neptune 98 burning smell
check to see if the door boot is intact. if there is a hole in it water could be getting to the motor control board and you are in danger of shorting the machine out. the other possibility is the main computer board may be on its last legs and is doing a slow sizzle
Sep 18, 2007 | Maytag MAH6700AWW Neptune Front-Load...
Kitchen Ranges Logo
63 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
