Question about Kenmore Washing Machines
We had to turn off our water a couple of times this week and now the kenmore washing machine keeps filling with water when it is not in use. We also have a kenmore water softener don't know if this has anything to do with it. it seems to fill up with water close to the time our water softener recharges. We don't have the maual to troubleshoot, no codes display when this happens as the machine is not on
  • Kenmore Master
  • 2,699 Answers
If the machine is filling on it's own you have to replace the water valve located on the back of the washer.when you shut off the water and turn it back on sediment in the pipes can get disturbed and flow into the valve,when the valve goes to fully close it can't because sediment is inside the valve and stopping it from fully closing,the only way to fix this is to replace the valve,you don't want to come home to a flooded out home because of the valve.whenever you write about your appliances send the model number so i can look up your model and give you the part number,when you go to your parts store,give them the model number off of the machine and they will sell you the correct part.
Posted on May 22, 2011
Why dose water keeps filling wash when off oasis he 27082 top load
The timer turns the water on to fill, the pressure switch turns it off. If the water contacts are welded together (can happen over time) then the water solenoid will be on all the time. Easy way to check. Unplug the unit, then remove the electrical plug from the water valve (hot or cold depending which one is causing the issue) plug unit back in. If water stops filling the timer is bad. If the water does not fill then the timer is fine, but the water valve solenoid is bad.
Jul 29, 2014 | Kenmore Oasis HE 27082 Top Load Washer
My older model kenmore washer only fills with water when the hot or warm setting is on. When it's set to cold, either washing or rinsing, it stops. It will still agitate once filled on any setting. It...
You have said it all. OLD.
time to give it up and get a new one.
first, the cost of figuring out what part is defective and getting a replacement part may take a couple weeks and couple hundred dollars for the repairman.
second, you will STILL have all old parts on the rest of the washer.
third, if you buy a new washer, you have serious expectations of it working properly for at least 5 years.
Mar 08, 2018 | Kenmore Washing Machines
My Kenmore 90 Series washer keeps filling until the washer is turned off.
More then likely the soleniod valve has dirt stuck undr the seat and it cannot close....
When a washer just keeps on filling with water it is
Kind of the opposite of this problem that I wrote about in these tips...
Washing Machine Problems No Water
http://www.fixya.com/support/r3880845-washing_machine_problems_no_water
Washing Machine Fix Washing Machine No Water
http://www.fixya.com/support/r3880533-washing_machine_fix_washing_machine_no
heatman101
Aug 19, 2010 | Washing Machines
My Kenmore moel #11027082602 ran while we were
Yes it is very possible. If it fills with water and starts the cycle and the water keeps running in then your water inlet valve on the back where the water supply comes in is sticking. It needs replacing.
Feb 16, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Water over fills and machine does not start washing
put the washer on warn and start to fill,turn washer off,if it keeps filling then you need a new water valve,if it does not stop filling your water level,hose has come loose or the water level switch is bad-mike
Feb 09, 2010 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Kenmore washer won't stop filling during initial wash cycle
I had the same problem too on one of my washers (not kenmore) it didn't complete cycle because someone turned off the hot water valve. soo i turned on the hot water and it worked fine. keep in mind that mine wasn't a kenmore. hope this helps some...
Oct 08, 2009 | Kenmore 24032\24036 Top Load Washer
Water keeps flowing does not stop---does not go thru cycles
You probably pinched the water fill hose that comes up from under the tub when you closed the cabinet. Also make sure it is free from trash in the bottom of the tub and that it is tightly connected to the water level switch.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 06, 2009 | Kenmore 24032\24036 Top Load Washer
My front load whirlpool
if it is kenmore top loader replace 1 more time if brakes right away again its your transmission."less soap plz"
Nov 08, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
195 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
