Question about Arris SURFboard SBG900 Wireless Router (DHSBG900)
Vonage ip voice will not work with internal firewall turned on
I have a Motorola surfboard sbg900 cable modem/gateway that moves ip traffic just fine. I just installed vonage and it will not draw dial tone with the firewall turned on. Can anyone help with this issue?
Regards,
Zack
    Novelist:
  • 173 Answers
Then iot seems that your fire wall is not compatible with it, try installing a different one, or try port forwarding that will fix your problem
Posted on Aug 15, 2008
SOURCE:
How do i turn wifi off surboard sbg6580
log in to the modem as if you were going to change the wireless password (browse to default gateway and enter username and password) then turn off SSID broadcast (usually by un-checking a box)
try these
SBG900 Default IP:
192.168.0.1
SBG900 Default Password:
motorola
SBG900 Default Username:
admin
Nov 19, 2013 | Arris SURFboard SBG900 Wireless Router...
Searching for password on bottom of motorola surfboard SBG900
try this link
https://www.cleancss.com/router-default/MOTOROLA/SBG900
Jan 15, 2018 | Arris Surfboard SBG900 Modem Cable Modem...
I FORGOT WHERE TO FIND THE PASSWORD FOR MY WIRELESS TO HOOKM UP MY PS3
you must browse your router and go to the security section under wireless configuration. see page 87 of (http://www.motorola.com/staticfiles/Support/US-EN/Home-and-Office/Cable-Modems-and-Gateways/SBG900-SURFboard-Wireless-Cable-Modem-Gateway/Documents/Static-Files/SBG900_User_Guide.pdf) for screen shots of where to look.
and remeber a PS3 need to have broadcast of ssid turned on for the intial setup.
GL
hope this helps
Don't forget to vote for me
TY
Jammer
May 27, 2011 | Arris SURFboard SBG900 Wireless Router...
Is the Motorola SBG900 cable modem gateway a router- that is will it enable file sharing between the computers that share the gateway (one wired, one wireless). If so how is this set up?
you should be able to set up a home network you will have to enable file sharing, if you run through the network setup wizzard in the control pannel it should be fairly straightforward
Jan 21, 2011 | Arris Surfboard SBG900 Modem Cable Modem...
Unable to wireless connect TP-Link TL-WR841ND to Motorola SBG900
DO any of these error conditions show up on the front panel display?
Front-Panel Lights and Error Conditions
Light Turns Off During Startup If:
RECEIVE The downstream receive channel cannot be acquired
SEND The upstream send channel cannot be acquired
ONLINE IP registration is unsuccessful
POWER The SBG900 is not properly plugged into the
power outlet
OR
Light Turns Off During Normal Operation If:
RECEIVE The downstream channel is lost
SEND The upstream channel is lost
ONLINE IP registration is lost
POWER The SBG900 is unplugged
If you rent or lease your SBG900 Contact your cable service provider.
If you own your SBG900 Call 1-877-466-8646 for technical and warranty support. Support is available
24 hours a day, seven days a week.
Feb 28, 2017 | Arris SURFboard SBG900 (49402201900) Modem
Motorola Surfboard SBG900 will not connect to Playstation Network
You need to give the PS3 its own IPAddress outside of the firewall. You need to configure the router and the PS3.
Mar 13, 2010 | Arris SURFboard SBG900 (49402201900) Modem
Enable upnp on motorola sbg900
I don't believe that model support uPNP
You can however, try port fowarding UDP port 3074 to your internal IP of your xbox
Jul 10, 2009 | Arris SURFboard SBG900 (49402201900) Modem
Online problem with motorola SBG900
hardwire the modem with the acer computer and shut both the modem and the computer down..then turn on the modem ..wait for a minute and then turn on the computer..just check whether the status still says local or not.....remember this is the first step..if it doesnt work,,keep me infmd,,i will be back with u
Mar 16, 2009 | Arris SURFboard SBG900 (49402201900) Modem
Arris SURFboard SBG900 Wireless Router (DHSBG900) Logo
208 people viewed this question
Top Arris Computers & Internet Experts
Ekse
Greg Ulan
Ann Moroz
Ann Moroz
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
