Question about Sony FD Trinitron WEGA KV-32FS120 32" TV
How do i change the video input from video 4 to something else, e.g. video 3? I am currently using video 4 to watch the tv. I have component video coming into the tv from an onyko receiver with no audio going to the tv. I suspect something is wrong with video 4...how can i change to video 3 to check?
  • Sony Master
  • 6,694 Answers
To change the video inputs press the TV/VIDEO button repeatedly on the remote to cycle through available video inputs.
ok
Posted on May 22, 2011
  • jmanbball Jul 28, 2011
    You might have to go under setup and change the labels for the different Videos. There is an option to skip different video inputs, which will make them not show up when you cycle like described above.
Can I attach a HDMI cable to an Old Samsung TV Model # HLN5065W1X/XAA
Gina, these are all the inputs on your TV
S-Video 4-pin DIN (2 sets) Back Composite RCA (2 sets) Back Component 3 RCAs Back Component (HDTV) 3 RCAs (2 sets) Back RGB 15-Pin Dsub Back Tuner Co-ax (2 sets) Back DVI Digital Input 24 pin DVI Back S-Video 4-pin DIN Front Composite RCA Front
You can not use HDMI cable with this set up.
Feb 22, 2016 | Samsung Televison & Video
How do I hook up my blu ray to my floor model panasonic tv
You can use an HDMI cable if both your tv and Blu-ray player have that imput. That will give you the best picture and sound. Both video and audio are carried through the one cable. Next down in quality are Component cables. You may need to use these if your tv doesn't have an HDMI input. These 3 cables are red, blue and green. They will give you the picture but no sound. This is normal . All component cables need red and white composite cables for audio. When you have made your choice of HDMI or Component, click the input button on your tv remote and scroll down to either HDMI 2 or 3 or 4(if you used an HDMI cable) or choose "component" to allow the signal to come through. Make sure you at least have the blue-ray player on so that when you do see it on the screen, you'll know which input you chose to get it to come through. Remember, after watching your Blu-ray, remember to turn your input back to your cable setting so you can watch tv again
Dave
Jan 28, 2015 | Panasonic Televison & Video
How do i change the input
The 27" TV uses the same instructions as the 20", and I found the manual for you at the link below. Answering your question directly, here is the section of the instructions about changing input:
Changing the TV's Input Normally, your TV displays the signal coming through the antenna terminal. However, if you've connected another component to your TV(such as a VCR & DVD) using the Video/Audio input,you will want to be able to view the signal from the component.To do this, you will need to switch from the ' TV ' input to the 'AV1-AV3, CVI' Input, as follows. 1 With the TV on, press the MENU button twice, then " Set-Up " menu will appear. 2 Use the WCHV buttons to select " Input ". 3 Press the CVOLB buttons to change the input source from ' TV ' to 'AV1, AV2, AV3, CVI'. 4 Wait 20 seconds, or press DISPLAY button or MENU button to return to normal TV viewing. * CVI means the Component Video Input (Y/ PB/ PR) from the DVD player etc.* Users can also select these input modes with the TV/AV button or the INPUT button on theremote controller. * On the AV1 mode , if you connect the S-VHS jack to your TV, "AV1" is changed to "S-VIDEO".
The link to the manual is below.
Jun 01, 2014 | Daewoo DTQ-27U4SC 27" TV
What channel does the tv have to be on - I have dish network - do I leave the dish off or on and move it to a certain channel?
First check what channel or input your TV is currently on bypowering the TV off then back on and noting the channel or input that appearson screen when the TV is powered on. If you are using a Coax Cable toconnect the receiver to TV1, check the receiver's back panel for the outputname. If your receiver has a "TV CH 3/4 out" (non-ViPReceiver): Tune TV to channel 3 or channel 4, if it has"Home Distribution" output (ViP Receiver): Tune TV to channel 62or 75. If using non-Coax (RCA, Component, or HDMI) to connectreceiver to TV1, cycle through the inputs until picture appears. In your casesince you have the Toshiba XDE500 connected between the receiver and TV, tuneTV and component to channel 3/4 (coax) or correct input. Hope this helps, andhank you for being a valued DISH Network customer!
Phillip Chang DISH Network Customer Support Representative
Feb 08, 2011 | Toshiba XDE500 Player
Dear Technician, I have 4 components that I am trying to connect together, a Panasonic HDTV model #TC-L32X1, a GO Video DVD/VCR model #DV2130, a Yamaha stereo receiver model#RX-690, and a Scientific...
Hi and welcome to FixYa,
Unfortunately, size limitation of what could be attached prevents posting a connection diagram. Still, proposed connection scheme:
  • 4250HDC's HDMI to Panasonic's HDMI 1 or 2;
  • 4250HDC's VIDEO OUT to GoVideo's LINE IN 1 VIDEO;
  • 4250HDC's AUDIO OUT to 2 pcs of RCA Splitters (shown below);
  • 1 pair from the 2 splitters to GoVideo's LINE IN 1 R-AUDIO-L;
  • the other pair to Yamaha's LD/TV L & R;
  • GoVideo's LINE OUT VIDEO to Panasonic's VIDEO IN 1 VIDEO;
  • GoVideo's LINE OUT R-AUDIO-L to 2 more RCA Splitters;
  • 1 pair from the 2 splitters to Panasonic's VIDEO IN 1 L-AUDIO-R;
  • the other pair to Yamaha's VCR 1 IN L & R;
  • to watch cable TV in HD quality, set Panasonic to HDMI 1 or 2 by pressing Panasonic remote's INPUT button, then 3 (or 4), then OK;
  • to hear cable TV programs on Yamaha's speakers, set Yamaha to LD/TV;
  • to watch DVD or VHS, set Panasonic to Video 1 by pressing Panasonic remote's INPUT button, then 6, then OK;
  • to hear DVD or VHS on Yamaha's speakers, set Yamaha to VCR 1;
  • to record cable TV programs, press GoVideo remote's TV VIEW button a couple of times to cycle through the signal sources or until Line 1 is displayed.
The use of the splitter shown below would effectively double the AUDIO OUT of the cable box and the DVD/VCR combo to feed both the TV and the stereo. Additionally, this would allow use of the cable box and/or the DVD/VCR combo with or without the Yamaha.
dd46b75.jpg or
27340be.jpg or
Good luck and thank you for asking FixYa.
Apr 27, 2010 | GoVideo Go Video DVD/VCR Combo
Problems establishing audio output from DVD RW to TV
If you own a Digital Video Recorder, such as TiVo, or a DVR from a Cable or Satellite provider, then you know you can record to the device's hard drive to view TV shows at a later time, much like the old VCR. However, saving those TV shows becomes difficult as the Hard Drive starts to fill up. The answer to saving your shows is to record them to DVD! This can be accomplished easily by hooking up a DVD Recorder to your DVR
Here's How:
  1. 1)record a TV show on your DVR that you want to save to DVD!
  2. 2)Turn on the DVR, DVD Recorder and the TV that the DVD Recorder is connected to. In my case, I have my Samsung DVD Recorder (no hard drive) hooked up to my TV via an RCA Audio/Video cable from the rear outputs on the DVD Recorder to the rear RCA inputs on my TV. I use a seperate DVD Player for playing DVDs, but if you use your DVD Recorder as a player as well, use the best cable connections you can to connect to the TV. See the articleTypes of A/V Cables for more info.
  3. 3)Connect an S-Video or RCA video cable and composite stereo cables (red and white RCA plugs) from the DVR to the inputs on your DVD Recorder. If your TV has Component inputs, connect the Component Out from the DVD Recorder to the Component In on the TV, otherwise you can use S-Video or Composite. You will still need to use RCA audio with your video connection.
  4. 4)Change the input on your DVD Recorder to match the inputs you are using. Since I'm using the rear S-Video input, I change my input to "L1", which is the input for recording using the rear S-Video input. If I was recording using the front analog cables it would be "L2", the front Firewire input, "DV". The input select can typically be changed using the DVD Recorder remote.
  5. further instructions continued in my next comment post please read.
Apr 05, 2009 | Sharp Televison & Video
We have sound but no picture i have sound but no picture. when you change inputs the word input is doubled up and distorted
There were not much info in the manual but it did suggest trying this.
1st- Unplug for a few minutes and then plug it back in. Or use the reset button look it up in the manual. MANUAL
2nd- Blank screen troubleshooting
• If you're trying to watch TV, change channels or press the ANTENNA button to switch tuners.
• If you're trying to watch something that's playing on a component connected to the TV (like a DVD or a VCR tape), press the TV
button on the remote, then press INPUT until you get to the correct video input channel.
• If you're trying to watch a component (like your DVD player or VCR), make sure the component connected to the TV is turned on.
• If you're trying to watch a component (like your DVD player or VCR), make sure the component is connected correctly.
Post back if non of these ideas work and explain if there are any lights flashing or changing colors on the front where the green light usually is. A fixya rating would be appreciated, thank you for stopping by Fixya!
Feb 16, 2009 | Mitsubishi WD-62525 62" Rear Projection...
The who input button
usually a tv that doesn't "see" video on the S-video will not even "switch" to it.  It just goes to the next Svideo, RCA etc..
Make sure your cable is not damaged. (on both ends) Does the svideo source and svideo cable work with another tv or video device?
31GT740 Manual From the Manual:   " WHO•INPUT In TV mode, press WHO•INPUT to toggle through the available Video Input channels (VID/SVID and the current channel). In SAT mode, press to select available channel lists.
Using the WHO•INPUT Button Use the WHO•INPUT button to toggle through the available input sources (VID and the current channel) and view the content from the component you have connected to the TV. 1. Press TV to place the remote in TV mode. Make sure that the content from the component is turned ON. 2. Press WHO•INPUT to tune to the available input source and view the component. 3. Press WHO•INPUT again to tune back to the channel you were previously watching.  "
James Mac
Sep 10, 2008 | GE 31GT740 31" TV
DVD signal received in wrong aspect
PRESS SETUP GO TO MISCELLANEOUS PRESS ENTER THEN DOWN TO OSD SETUP PRESS ENTER AGAIN AND DOWN TO MONITOR AND CHANGE TO 16.9.
HOPE THIS HELPS.
CABLE GUY.
Feb 21, 2008 | Onkyo TX-SR605 Receiver
Sony FD Trinitron WEGA KV-32FS120 32" TV Logo
319 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
