Question about Intex Pool & Spa
My intex ultra frame was put on our patio we filled it now realize it is 4 inches off level. Now what do we do is this ok?
5 Suggested Answers
  • 297 Answers
SOURCE: unlevel ground 3 inces
if you had said it was a blow up ring intex then yes it very likely would collapse. with your situation it is less likely, but possible
as for the metal frame you still need to keep an eye on how many swimmers or on the low side and if they hold on to the rail
your weight distribution of water does not need to be disturbed by hangers on.
water weighs 8 pounds per gal so with your 12000 or so gallons could shift
be carefull and keep an eye on it especially if any of the support leggs are on plain old dirt dirt turns to mudd no matter how hard it was during dry days throw in the weight of the pool with wet dirt and the leggs will start sinking
Posted on Jul 15, 2009
jennerina
  • 86 Answers
SOURCE: My cousin dug out dirt at the high point of the
They say that the pool should be completely even. I dont want to tell you, you have to re-do, but I also don't want to tell you that you shouldn't. Without seeing it, it is hard to say whether or not it would be safe to leave. That being said, attempt to straighten those leaning post, applying something underneath each pole so that they do not sink into the ground further. (which may difficult with the water in)
I personally have put 1/2" slate bricks under each pole post to avoid it sinking into the ground, so it being un-level is not a problem.
Basically only you know what you feel safe doing. I just hope I have helped to give you a solution to the sinking poles issue. If the ground is uneven, even with something under the post, it can still be uneven. It will be hard to get completely even. Ours is off slightly too, but its fine.
Posted on Jul 29, 2009
  • 22 Answers
SOURCE: 2010 Easy Set 2500 Gph Swimming Pool Filter Pump (): ok we have the 24 by 52 in intex metal frame pool ...
88 It is the Setup/Start up Code. it is displayed until you set the timer. which you do so by holding down the down arrow till you hear a beep, then hold down the up arrow till you here a beep. from there you can set the time and then to lock it in repeat the process. On the filter set it to run atleast 1 hour longer than you SWS. set the timer on both at the same time.
Posted on Jun 17, 2010
SOURCE: my wife and i bought a 16 by 48 in. ultra frame
I set my new pool up on Saturday with 6mil plastic down first over the grass, then the pool liner and frame, and now 3 days later there are 6 areas where grass blades have grown through both atleast an inch in height already. How is that possible and what can I do now.
Posted on Jun 01, 2011
I have a Intex above ground Pool 18 feet by 9 and 52 inches deep. How do I over winter this pool?
no you cant keep an above ground pool full water unless you live in a warm climate area that dont feeze
Oct 19, 2014 | Intex 18 X 52 Ultra Frame Pool Set with...
When filling pool the top seem to move towards the centre of the pool,How do i stop this.
As the pool fills more te pressure against the walls will push them back out again, I wouldn't worry too much about it till you have it 3/4 full.
Terry
Nov 30, 2012 | Intex Ultra Frame Rectangular Pool...
Ph level and clorine level too high
get in the pool companies to adjust the levels to correct and remove the alge growing in the water
Nov 04, 2017 | Intex Automatic Salt Water System for ...
My wife and i bought a 16 by 48 in. ultra frame intex pool. we had profesionals level the ground, we have a sandy base, and after filling our pool with water and the legs settled, the pool is approx. 2 in....
There won't be any structural problems and you will notice the difference more than anyone else. If you redo the pool next year it will help to set each leg on a patio brick so it won't settle.
May 10, 2011 | Intex Ultra Metal Frame Pool w/ Upgraded...
HOW MUCH WATER IN INCHES AND GALOONS DOES A 10FT ROUND AND 30 INCH HIGH METAL FRAME POOL HOLD ?
It will hold ~1175 gallons assuming it is filled to 24" deep. The formula is pi x radius x radius x depth x 7.48.
John
Mar 14, 2011 | Intex "" Metal Frame Pool Set (56998e)...
My pool is not level by 2.5 inches. Will it
Drain and move to level ground . or add sand on the low side to keep it level
The Pool Tech
Jul 12, 2010 | Intex Frame Set 12 ft x 30 in Pool with...
Intex changed product materials of pvc pools
You would think that two tarps would be enough, lol
I would get weed killer and kill the grass or put sand over it. the last suggestion is diggin it up and then putting sand over it to level it back up.
Please rate and let me know if it helps.
thanks and God bless
Jun 25, 2010 | Intex "" Metal Frame Pool Set (56998e)...
Unlevel ground 3 inces
No, it wont collapse, if you fill it too full it will just overflow
May 23, 2009 | Intex Easy Set Pool 15x36
Pool & Spa Logo
154 people viewed this question
Top Intex Pool & Spa Experts
avionik99
Level 1 Expert
Jay Finke
Jay Finke
Mike
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
