Question about Philips Computers & Internet
Hi, Thank you for email . I have a small Philips 250gb external hard drive model No. sde3275xc/97. It came into contact with some water 2 days ago and since then my laptop does not recognise it. It is not listed in Device manager so is not installed you just plug it into usb port. When it first happened I was getting a message to download some software from manufacturer but I'm not sure where to go (ie log into)
  • 33 Answers
It's possible that a harddrive coming into contact with water would no longer be usable. You can have a professional recover the data, if the data on the device is important. Please check the info below:
http://www.ontrackdatarecovery.com.au/top-four-data-loss-tips/
You can also try placing the harddrive in a bowl of uncooked rice overnight. The uncooked rice will absorb the moisture from the device. Although I cannot guarantee this fix as its possible that water may have damaged the harddrive.
Posted on May 22, 2011
Describe your Western Digital 250GB MyBook External USB 2.0 250 GB Hard Drive Problem Do you have a picture of the voltage and amperage adapter for the Western Digital 250GB MyBook External HD ?
I don't have a photo of the AC adapter, but if you look on it the Voltage and Amperage specifications are;
Input: 100-240VAC / 50~60Hz
Output: 12VDC / 2A
This means the Input power can be from 100 volts to 240 Volts AC, and at 50 to 60 Hertz
The Output power is 12 Volts DC at no more than 2 Amp's. (Amperes)
Asian Power Devices Inc. has a model DA-24B12 that fits these specs.
Also a Wattac AC adapter model number - BAO362Zl-8-A01 will work.
Otherwise just use a 12 Volt, 2 Amp power pack, with a positive on center contact, and a 2mm pin hole
Nov 23, 2010 | Western Digital 250GB MyBook External USB...
REQUIRE WINDOWS 7 DRIVER FOR IOMEGA SILVER SERIES 250GB EXTERNAL HARD DISC DRIVE. THANK YOU
The external hard-drive is "plug-and-play", and Windows XP/Vista/7 all support "plug-and-play".
Thus, it should automatically be detected by Windows.
So, what's your "real" problem? Symptoms? Error-messages? What happens? What does not happen?
Nov 05, 2010 | Iomega Silver Series External 250GB...
External hard drive stopped working
Hmm any sort of nise from the disk is not a good sign. try using the unit on another Pc. if you have the same issue you might have to take it for warranty.(if you have warranty)
May 22, 2009 | Maxtor OneTouch II external hard drive...
Seagate FreeAgent Pro Desktop 250GB - no power
go get a external drive enclosure from computer supplier
compusa
best buy
circuitcity
Feb 04, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Clicking sound on Firewire 250GB
okay, I had this issue with my acomdata 500GB. today I decided to open up the drive to see if I could remove it and restore the data. after unscrewing all six screws (4 on the front and 2 small ones on the side, you'll need two different phillips, a large one and small one), I looked inside. first I registered the driver inside (it's a Western Digital) in case I needed to get it replaced. sure enough, it was still under warantee, even though the enclosure/driver kit is not (acomdata warantee runs out after a year for this model). but I noticed a slippage on the mangnetic copper film strip right above the USB port entry. it was slightly falling off the edge of the port. so I just fixed it, not thinking much of it, it just didn't "look" right. then I had a thought to plug it back in. driver now works again! I am about to recover my files and then test unplugging it to see if this repair "sticks".
Jan 01, 2009 | Acomdata 500GB External Firewire HD 500 GB...
Partition external 250gb drive
why would you want partition it??? XP will recognise the 250. Partition was useful for win 98, but pointless excercise with XP.
Aug 07, 2008 | SimpleTech 250GB USB2.0 7200 RPM External...
Make freeagent deskot 250GB master hard drive
1) I greatly suggest against making ANY external HD your primary disk.
2) Not many computers support this.
3) The most likely method would involve reisntalling your OS (Windows/OS X) onto the drive.
4) I just noticed this thread is from three months ago... :P
Dec 28, 2007 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
Philips external hard drive cannot be found
Uninstall the drivers for your external hard drive on your mac. reboot your computer then install the drivers back and plug your external harddrive back to your mac
Dec 20, 2007 | Computers & Internet
Computers & Internet Logo
118 people viewed this question
Top Philips Computers & Internet Experts
micky dee
Are you a Philips Computer and Internet Expert? Answer questions, earn points and help others
