Whirlpool Stylemaster 4213343 won't spin. Everything else seems to work. Makes a humming noise like the motor is trying to do it. Could it be a belt? We tipped the washer up and notices alot of rubber shavings on the floor underneath. Thought maybe the belt might be stretched beyond function or just plain broke. Couldn't figure out how to get into the mechanics of the machine. Any thoughts? Thanks!
jsrock516
  • 5911 Answers
SOURCE: kenmore washer
If your washer is not spinning fast enough, or barely spinning at all, this is usually a symptom of any one or all of the following: 1. Bad gearcase (transmission). 2. Bad basket drive, with which the transmission couples to under the agitator. 3. Bad clutch/brake assembly. Which mounts on top of the gearcase under the basket drive. Usually a tell tale sign of a gearcase beginning to fail is the sign of an amber colored oil coated under the washer or inside the casing. I said, "usually". It doesn't always happen, but if you notice any signs of oil, the gearcase is shot. The basket drive and clutch assemblies are harder to diagnose and require some disassembly of the washer and the removal of the gearcase to inspect. Let me know if this helps.
Posted on Aug 02, 2007
natengel
  • 19 Answers
SOURCE: washing machine will not spin makes loud humming noise
motor coupling needs to be replaced
Posted on Nov 05, 2007
  • 90 Answers
SOURCE: Whirlpool washer... terribly noisy...
direct drive coupling.
Posted on Jan 13, 2008
IFIXALL
  • 868 Answers
SOURCE: Whirlpool Thin Twin washer won't start, just makes humming sound
The belt is broken and needs to be checked for any other part that has failed causing the belt to burn.
Posted on May 26, 2008
SOURCE: Maytag Performa PAV2300AWW screaching noise, belt problem, pulley broke
My Maytag Performa was making the loud squealing noise. I changed out the water pump/bearing, took care of the problem.
Putting a new belt on just help burn up the bearing (they needed replacing) and probably ruined the new belt. Probably seized the water pump bearing and the belt jumped and broke the motor pully. A washing machine motor is very strong, when that h20 pump bearing seized (or possibly some bearings jamed up) the motor kept on turning that belt and the plastic pully gave in. You'll need to replace that also. If the h20 pumb bearing is turning freely, likely the bearings jammed up but or now loose. That bearing should be tight, no slack or play in it. You can probably wobble the pully on it all around while turning it. The slightest slack is too much.
Posted on Oct 29, 2008
Whirlpool dryer won't spin
Most dyers after you pull the top up, the front should just lift a little and it should come loose, sounds like you may have the belt intact, but the motor is not conected to the belt.
Jan 12, 2013 | Whirlpool Dryers
Indesit G74V dryer won't spin
Some dryers have a belt tension idler and switch combination that works to keep the belt under tension and shuts down the dryer if the belt breaks or falls off.
Apr 28, 2017 | Dryers
Whirlpool stylemaster 4217141 REV A Agitator/spin cycle broken upper agitator spins by hand but tub won't spin
open the lid and get a model #, sound like all you need is agit dogs # 80040. then remove top of the agitator, could be a softener dispenser. under that you will find a plastic cap, pull up with needle nose pliers. under that you will find a 7/16 or 1/2 bolt, remove the bolt and the agitator can be lifted off. the agitator can now be split into to pieces, turn the top half over and the assy with the agit dgs will fall out. simply replace and reassemble and DO NOT OVER TIGHTEN BOLT. just snug it up. should be fine.
Jan 02, 2012 | Washing Machines
Frigidaire dryer not working drum won't spin,
Hi How old is it , ? and dose it soun like the motor is running but not turnning the drum ? this would be a bad belt , you will need to do some more investagating for me to help you
Dec 06, 2011 | Frigidaire Dryers
Won't spin out and makes a humming noise
Wait for your handsome husband to come home and have him fix it. jk
Nov 09, 2011 | Maytag MAH6700AWW Neptune Front-Load...
What should i look for on my whirlpool washer if it hums but won't spin, agitate, or drain?
The motor may be shot if it is getting current and won't operate the washer.
Nov 04, 2011 | Washing Machines
My Whirlpool stylemaster 907675 Washer wont spin.. The lid switch is fine.. Washes fine and all other cycles work.. just wont spin.
Hi, stylemaster washing machine won't spin on the top half. The bottom part spins perfect. the top doesn't seem connected. What
should I do ?
TIA
RJ
Jan 08, 2010 | Washing Machines
Whirlpool Stylemaster 4217141 tub not moving wash/spin cycles
Sounds like the drive belt is broken or very loose. Take off the back and check the belt. If loose or missing, tighten or replace. This is usually done by loosening the motor support bolts and moving the motor until the belt is tight, then re-tighten the bolts. Replace belt in the same way.
Apr 22, 2009 | Whirlpool Washing Machines
Whirlpool Washing Machine won't spin
Sounds like motor controller or motor either way it's not cheap...Sorry
Mar 13, 2009 | Whirlpool Washing Machines
Washing Machines Logo
240 people viewed this question
Top Washing Machines Experts
