Question about Olivetti Office Equipment & Supplies
Malfunction in Electronic typewroter
When I switch on the error light appears and nothing works even after following all the instruction in the manual.
  • Olivetti Master
  • 3,594 Answers
What are the make and model?
DickyO
Posted on Aug 15, 2008
Looking for instructions how to use Electric light Switch timers
Electronic timers are usually 7-day.
Usually a 24-hour timer has mechanical analog dial that rotates as time passes.
Copy following link for instructions by experimenting with features:
http://waterheatertimer.org/How-to-set-timers.html
There are many timers on the market today, including plug-in, box-type, timer modules, delay timers, indoor-outdoor timers, and knock-offs of each brand. Each has different watt load rating that usually appears on side of timer.
Some timers work with any type bulb, and others only with incandescent.
Copy following links to help identify timer.
http://waterheatertimer.org/Intermatic-timers-and-manuals.html
http://waterheatertimer.org/Woods-timers-and-manuals.html
Jul 26, 2012 | Hardware & Accessories
O/d light blinks when driveing o/d seems to be engaged car has 198000 miles and runs very good also engine light is on
O/D light blinks, but with that the check engine light is ON.--- This will make your troubleshooting easier.When the check engine light comes on, and remains on, this indicates that there is error stored in your cars computer.---- Once the computer is scanned, you will get error codes, as per that error code it will point towards faulty part, which is causing the O/D light to blink.-------- Most probably the O/D light blinks, If a problem exists in No. 1 or No. 2 solenoids or speed sensors .
--------------- For car after 1995 it requires OBD2 tool and for car before 1995 it requires OBD1 tool.------- --------- You car will require OBD1 tool.There are very few auto parts store and repair centers who have OBD1 tool.In your case you required OBD1 tool.------ You can just contact local auto-parts store and they will guide you to the nearest store who has OBD1 tool.There you can get your car scanned.If there is error set in your cars computer, then you will receive the error code.As per error code it will point towards the faulty part causing this problem in your car.------------- -------------- The codes which you get is scanning will be mostly any of this following codes:--- DTC P0500 - Vehicle Speed Sensor Malfunction
. DTC P0750 - Shift Solenoid "A" Malfunction
. DTC P0753 - Shift Solenoid "A" Electrical Malfunction
. DTC P0755 - Shift Solenoid "B" Malfunction
. DTC P0758 - Shift Solenoid "B" Electrical Malfunction
. DTC P0770 - Shift Solenoid "E" (SL) Malfunction
. DTC P0773 - Shift Solenoid "E" (SL) Electrical Malfunction
. DTC P1520 - Stop Light Switch Signal Malfunction
. DTC P1705 - Direct Clutch Speed Sensor Circuit Malfunction
. DTC P1765 - Shift Solenoid Valve SLN Circuit Malfunction
. DTC P1780 - Park/Neutral Position Switch Malfunction
--------------- Now it all depends on what code you get, as per that you can replace the following part.------- This will help.Thanks.Helpmech.
Jul 07, 2011 | 1995 Toyota Camry
My Canon 1000D won't operate even when turned on. There is power somewhere because there is a lighted display in the viewfinder and it flashes busy
I can help you fix the BUSY Error or Error 99 of your Canon EOS Rebel XS / Canon EOS 1000D.
Installation of this Canon EOS Rebel XS / Canon EOS 1000D firmware version 1.06 update will solve these problems:
  1. Some cameras may exhibit a phenomenon in which the LCD monitor does not display, the shutter does not release, and the BUSY indication remains lit in the viewfinder.
  2. The message, "Err 99 Shooting is not possible. Turn the power switch to<OFF> and <ON> again or re-install the battery", appears on the camera's LCD monitor, and after the above operation is carried out,the LCD monitor displays in a language that is different from the actual language setting.
See the firmware instructions and download the firmware upgrade by following these Fixya Tips :
  1. Follow this link to download a pdf version of the firmware installation instruction guide.
  2. Follow this link to download the Windows Version of the Canon EOS Rebel XS / Canon EOS 1000D firmware version 1.06 update.
  3. Follow this link to download the MAC version of the Canon EOS Rebel XS / Canon EOS 1000D firmware version 1.06 update.
  4. Follow this link to download the Canon EOS Rebel XS / Canon EOS 1000D Instruction Manual.
I hope that helps.
Apr 06, 2010 | Canon EOS Digital Rebel XS / 1000D IS...
Honeywell F50e electronic air cleaner indicator light stays on
Could be a faulty sail switch in the air cleaner that keeps the air cleaner on even without air flow.
Dec 20, 2009 | Heating & Cooling
Minolta di 520 MALFUNCTION
after nessage not apear error code,anymore specification?
Jul 17, 2009 | Minolta DiALTA Di520 Laser Printer
Is there a problem with my engine
E = error. Have dealer run scan test for fault codes.
Electronic Transmission Error Indicator
The vehicle is equipped with a redundant electronic gearshift indicator. This character appears with the key in the RUN position and displays the same gear selection as shown on the selector lever floor console next to the range selector lever. If an "E" character flashes or remains on this indicates that a transmission malfunction has occurred.
Visual Inspection Chart Mechanical Electrical
  • Shift lock actuator
  • Transmission control switch
  • SST (+/-) switches
  • Shift cable and bracket
  • Park sense switch
  • Central junction box (CJB) Fuse:
    • 204 (5A)
    • 205 (5A)
  • Damaged wiring harness
  • Loose or corroded connections
  • Powertrain control module (PCM)
Diagnostic Trouble Code Chart Five Digit DTC Component Description Condition Symptom Action P0815 SST +/- SST +/- circuit input signal failed. PCM has detected an incorrect voltage SST input. May not be able to shift in manual mode. Go To Pinpoint Test C . P1780 TCS TCS input incorrect per selected position. TCS voltage incorrect. No overdrive cancel when range selector is moved. Go To Pinpoint Test A .
Apr 24, 2009 | 2001 Lincoln LS
SRS light is flashing in Honda Accord 97
The SRS light means "airbag malfunction" take it to the dealer, only they, will be able to tell you which airbag is malfuntioning. Do not, I repeat do not attempt to fix this on your own airbags have tricky sensor and can cause a even worse problem.
Dec 28, 2008 | 1997 Honda Accord
Frigidaire Range FEF357BBD error code F9
I had the situation where the oven thinks the door is locked but it was not locked. Setting and holding clear eventually gave a f9 error.
I solved this by turning the circuit breaker off and taping over the oven light switch ( so it thinks it really is locked ) and turning on the breaker. The oven unlocked and appears fine now.
Nov 09, 2008 | Frigidaire PLEF398AC Electric Kitchen...
Konica minolta EP2010 error code c05
I have a Konica Minolta CSPRO EP1054 (in the Middle East)
I accidentally plugged the EP1054 copier into a 110V outlet instead of the 220V. Immediately the malfunction code (error code) of "C05" appeared along with the "Call Tec Rep" indicator light (wrench).
I followed the instructions posted by "Soul Visitor" ... i.e., I found the "Trouble Reset Switch" (not shown in the user manual) by opening the upper back panel and pressing the small black button in the lower right hand corner of the middle circuit board (green).
It worked perfectly!7df26b9.tif
Nov 08, 2007 | Konica Minolta DiALTA Di200 Copier
Player does not play
Hi, I had the same problem, MiMusic wouldn`t even recognise there was a disk connected although I could see it in My Computer.Found the answer on internet.
Attach it to your p.c. Then go to My Computer and highlight it. Right Click it and a box will appear . Go to FORMAT and format it. Another box will appear and ask if you really want to do it as data will be lost. Answer YES. Then format it. Disconnect from your p.c. Turn it on and you will be able to access the menu facility. Follow the instructions and goto CREATE LIB, BEFORE you put any music on to the thing.
I found it created library as soon as I disconnected it. BACK UP anything you have on it first as it will be wiped. It is working perfectly now and MiMusic is too. Yippee. Pat.
Jul 07, 2007 | Goodmans GMP33000S MP3 Player
Top Olivetti Office Equipment & Supplies Experts
James Cagle
James Cagle
Jim Keysor
Coss
Are you an Olivetti Office Equipment and Supply Expert? Answer questions, earn points and help others
