Question about Frigidaire Refrigerators
Frigidaire model num frs26r2aw6 wont get cold any more i think what i hear is the compressor clicking on every 4 min
  • Frigidaire Master
  • 2,605 Answers
Hello, welcome to FixYa.
It could be a number of things so the problem will need to be narrowed down. Based on your post though the place I would start is as follows, making sure the compressor itself is coming on/operating...likely not.
The noise you alluded to, "i think what i hear is the compressor clicking on every 4 min" sounds to me to be a faulty "ptc" or also known as a starting device.
If you feel like you can trouble shoot further I`ve provided the following info to assist you or you may decide to call a professional appliance technician...it's your call.
I don`t know the age of your fridge, but I should mention...
** Most of the manufacturers of fridges ( including Frigidaire ) have 5 to 10 years sealed system warranty which would include the compressor but not the electrical starting devices i.e., the overload & relay. Check your owners manual, it is the ultimate authority on warranty no matter what anyone else tells you according to.**
If you have a multi- meter you can check the compressor to see if the windings are ok.
**First, Unplug the fridge**
Remove the panel at the back down at the bottom. This should gain you access to the compressor.
On the side of the compressor will be the start relay/overload assembly such as this image...it may be enclosed in a black plastic cover as well.
Pull off the relay & overload and you'll see 3 pins in the form of a triangle...
With a meter measure between any 2 pins at one time, going between each pin with one remaining on a "common" pin.
You'll want 3 measurement's, similar to this example- 6ohms, 3ohms, and 9ohms.
On some meters you may simply get a reading of "0" ohms, as long as the needle moves off of "infinity" which would indicate an "open" winding=not good !
If following that, the readings are good, purchase a hard start kit. Part # HS410 also known as a 3in1 starter kit.
frigidaire model num frs26r2aw6 wont - 775ec2d.jpgbr />775ec2d.jpg
The above package contains info and hardware on how to connect it.
NOTE : the HS410 ( 3 in 1 ) should be considered just a temporary "fix" as opposed to an actual "repair" in should not be relied on for long term reliability or safety, but rather thefactory replacemnet, double check with your model number.
Hope that help`s move you forward if nothing else. If so please take a second and rate the guidance and a testimony to your inquiry you received here at FixYa, either or all is appreciated.
Let me know if the compressor is indeed operating yet the fridge or freezer fail to cool, if that is the case you could have a leak in the system, a restriction or even a mechanical failure within the compressor/not pumping. Good luck and I'll continue to help in any manner I can.
Regards,
Macmarkus :)
Posted on May 22, 2011
Compressor only stays on for 2-3 minutes than shuts off
if the sensors are okay, it might be the compressor overheating, my portable ac (moretti elite ac) is also behaving the same, especially when i turn the fan to max. the compressor shuts down about 7 mins and turns on again in about 5 mins, now i found out when i turn to medium or low the compressor runs normally. i think when on medium or low setting some of the cool air directs/channels to the compressor thus cooling it more.
Jun 03, 2013 | Frigidaire FAP094P1Z Portable Air...
Freezer not freezing food,,,,some what cold but not frozen...refrigerator side is cold....model # FRS23LH5DB5 seerial # LA43908689.........I am thinking it is the blower or blower control,,,any advice....
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Sep 13, 2011 | Frigidaire Refrigerators
My frigidare refrigerator freezer wont get cold model...FRS26HBBSB
heatman101
Sep 02, 2011 | Frigidaire FRS3R5EMB Side by Side...
I have a Frigidaire freezer chest. model number: mfc13m4fw3. It will click on for ten seconds and click off. I don't understand whats wrong. It wont stay on. Thank you
heatman101
Jun 29, 2011 | Frigidaire Freezers
Refrigerator 1yr old and freezer isn't working and the back almost burns hand to touch. What is wrong
If there is no cold at all and the fans inside and out are running then the compressor is trying to start but can't you should hear the motor try to start then a click then no sound fro the compressor for a few min. If this is so then it may be the start relay on the end of the compressor(where the wires go to the compressor)
Oct 16, 2010 | Frigidaire Refrigerators
My refrigerator was unplugged for three months , now it wont get cold. What could be the problem?
if you can get to compressor set your cold control all the way down(coldest setting) then see if you hear contactor on compressor click if not give a tap from a small wooden or plastic mallet near and around the contactor(not directly on contactor case its plastic or aluminum) and see if that will start compressor,if comp is running and its overly warm it may be low on refrigerant
Jul 20, 2009 | Frigidaire FRS-26DR7D Side by Side...
Compressor clicking on/off - freezer and refrigerator losing cold
I have a side by side frigidaire refrig about 4yrs old, but lately the freezer is not getting near as cold. My built in gage says it is a t 17-20 deg F even after I try to program it to 1 deg.
Apr 15, 2009 | Frigidaire FRS26R4A Side by Side...
Fan running,both cold settings at 4 , freezer 14 degrees C
you need to replace the start components on the compressor, theres a relay that mounts on to the compressor that takes out the start winding after it starts the compressor up. You can also try whats called a three in one to try to start up the unit. Good Luck.
Mar 28, 2009 | Maytag MBB2254G Bottom Freezer...
Kenmore Coldspot Side by Side Model 51559101
Unplug the Ref for 15-20 min., plug it back in and listen for the compressor to start. You will need to be behind the Ref so you can tell if the compressor or the fan is running. It will help to take the cover off so you can see the compressor.
Compressor not running but you hear a clicking noise. The relay needs to be replaced.
Compressor runs but not cooling. Low on coolant
Feb 06, 2009 | Kenmore 53642 / 53644 Side by Side...
Refrigerators Logo
312 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
