It uses oil only to lubricate the chain. The type of oil in not critical although special chain saw oil is available. If you use anything but chain saw blade oil, make sure that it is a light oil, both in viscosity and in colour because it is a total loss system and dark or dirty oil can become very messy. The chain adjustment is on the body at the end of the blade, it actually moves the blade in or out to set the chain tension. The chain should be tensioned that when it is pulled at the bottom, the guides of the chain should not quite come out of the slot in the blade. If the chain is too tight it overheats the blade and stretches the chain.
Amazingly I read the owner's manual online and there is no mention of what type oil to use. However, this is a chain saw, albeit and electric chain saw. Therefore it is reasonable to assume that you would use bar oil which you can purchase anyplace that sells chain saws. Just ask for chainsaw bar oil. If you want to clarify this call 1-800-858-8501.
You need “Bar and Chain Oil”, available at hardware stores and home centers. It is SAE 30 with additives to make it adhere to your bar and chain. An excerpt from a Remington manual follows (edited). FILLING OIL TANK 1. Remove oil cap. 2. Fill oil tank with SAE 30 motor oil if the temperature is between 30 & 75°F. • Colder use SAE 10 oil. • Warmer use SAE 40 oil. 3. Replace oil cap at once. Tighten oil cap firmly for a good seal. This will avoid oil seepage from tank. 4. Wipe off excess oil. • It is normal for oil to seep when saw is not in use. • Empty oil tank after each use to prevent seepage.
If you have more questions or need additional help please reply below and I will get back to you. Good Luck. HTH Lou Thank you for using FixYa.
From page 9 of a M12510US (bar oil is SAE 30 with additives to help it adhere to the bar and chain): FILLING OIL TANK
1. Remove oil cap.
2. Fill oil tank with SAE #30 motor oil. Note: For temperatures below 30°F, use SAE #10 oil. For temperatures above 75°F, use SAE #40 oil. 3. Replace oil cap at once. Tighten oil cap firmly for good seal. This will avoid oil seepage from tank.
Note: It is normal for oil to seep when saw is not in use. Empty oil tank after each use to prevent seepage.
This is one of the most complete "Owners Manuals" Remington offers. If not your saw you can find your manual here: Remington.com http://www.desaparts.com/index.htm
Type "YourModelNo" into the "Model #:" window, then click search.
Click the YourModelNo - Remington Electric Chain Saw "View Model" link.
Click “View Owners Manual” or "View Illustrated Parts Breakdown" link.
While Bar Chain oil will probably work, the owners manual (sitting in front of me) on page 9 says to "use SAE #30 motor oil". This is the owners manual for Models: M12510US, M15012US, M15014US, M15014AS, M30016US, M30016AS, M30016AW, M35016UW, M35016AW. Remington Electric Chain Saw
