Question about Compaq Presario SR1000T (568657) PC Desktop
Who are buy power strip or power inlet? - Compaq Presario SR1000T (568657) PC Desktop
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Compaq Master
  • 2,226 Answers
You can go to any best buy office max office depot home depot lowes ok
Posted on May 23, 2011
Flashing ready and water
Hi u machine looks like a fracino cherub if thats the case it sounds like the inlet solinoid open it up take it out its a littel blue box siral strip it make sure theres nothing blockin
g it test power to switch if all ok its the inlet solinoid switch 28.50 + vat. 6.50 POST from fracino hope I helped?
Feb 11, 2013 | Coffee Makers & Espresso Machines
Does my Acer Aspire 5100 laptop have a fuse?
No. Power would be prevented by a bad outlet, power strip not on, faulty or mis-connected power cord, bad connection between the tip and inlet of the power cord, a bad power inlet, or a faulty motherboard. Independently testing each of these until you narrow it down is really the best/only way to figure out the problem.
Nov 16, 2012 | Acer Aspire 5100 Series Laptop Charger...
Pc wont turn on
Check the power cord at the wall, the pc, and power strip if you're using one. Remove the laptop battery if it has one, and try turning it on. If you don't get any lights, or fans coming on, and the power outlet is verified working, then your cord, power inlet, or motherboard is faulty.
Nov 14, 2012 | Computers & Internet
50to 60 compression on a husqavarna 455 rancher chain saw. Ring job and how hard?
455 is an X Torq engine, this means it runs very cool on the inlet side of the piston, they are quite prone to gumming the ring in if they have been used on a heavy two stroke mix, due to the designit is a full machine strip down to get to the piston, skilled man 3 hours to strip and rebuild.
Sep 07, 2011 | Husqvarna , No.455 Rancher, 20" Gas -...
Stripped connection at the cold water intake into washing machine
If your inlet valve itself is stripped then you have to replace the valve. The plastic thread is part of the inlet valve. If its only the screen in your inlet valve you can remove the screen and replace it. However if you crossthread anything plastic it HAS to be replaced.
If you give me your model number of the washer usually the wpl 4318046 can be used as an inlet valve which is a cheaper alternative than your local parts distributor would tell you. GE parts on avg are 30% more expensive than anything else. On ANY ge appliance there is usually a way around there replacements with some minor altercations. I wish this site had a way you could contact me directly. I just joined so am not an expert yet but ive done my time in the field. If i could give you any expert advise its DONT BUY GE, OR LG.
Let me know if this helps.
Jan 22, 2010 | GE Washing Machines
Gears stripped. can I buy the timer unit
The PB912M10 timer clock motor is not sold separately. Aug 2010.
If power pack transformer still works: buy cheap plug-in timer, set power pack to override, and plug power pack into cheap timer.
With receipt, power pack might still be under warranty.
Open following link for power pack tips and resources:
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html
Sep 30, 2009 | Intermatic Malibu 121W Power Pack...
Installing load panel & inlet box
The bigger lugs will tighten just fine. Go that route and it will be easy to upgrade! If it seems way large when you put the wire in, strip the wire back and double it over. The # 6 may be a bit big for the 30 amp lugs. 30 amp circuit is usually # 10.
Sep 08, 2009 | Reliance Controls 50-Amp Power Inlet Box...
Haier XQB55-10 : water leakage from inlet hose jointer
You must examine your machine hose to see if it is blocked. Clean out the fine nets in the hose as well as at the machine entry (inlet water entry). Clean well with a tooth brush, refit carefully. Water should be in good pressure for machine operation.
Feb 23, 2009 | Haier HWD1000
Recommendations for power strip, etc. for HP Slimline
Hi when you buy a power strip especially to prevent lightning strikes ensure that the power strip has gas tube protection alongwith the usual MOV and Fuse
May 14, 2008 | Computers & Internet
Compaq Presario SR1000T (568657) PC Desktop Logo
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
