Question about Hammering
I rented a milwaukee breaker hammer and plugged it in and cant get it working, is there a safety or something I dont see?
  • 2,176 Answers
I would contact the rental yard first so that you don't have to pay for non-use. I am not aware of a safety so I would try another outlet and if still nothing I would take it back and tell them that you could not use the tool. If you give me the model number I will find a manual to double check for you.
Posted on May 24, 2011
Milwaukee 5338 breaker hammer does not have the breaking power that it use too. It will lightly peck not beat like it should. what is the problem? How do I fix?
check that the 2 controls are in the correct position for hammer /drill or just drill. Other than that you may need to have the hammer action lubricated or repaired.
Oct 22, 2014 | Drills
Need Parts List And Service Guide For Kango 990/950 Breaker
If these are the original Kango kangos then you are out of luck. They have been obsolete for many years now and no parts have been manufactured for a long time. The name was bought by DeWalt and they didn't do much with it. The Kango name is now ownd and used by Milwaukee, but there machines do differ alot from the originals. There were a few main models and the main mid sized breakers were the 900 (hammer only) and 950 (rotary hammer) There were a few facelift/variations of each (K, X and B I think) and they did use a couple of different sized seals/pistons/cylinders.
If it is one of the Milwaukee models you can look up diagrams here...
http://www.milwaukeetool.com/
Apr 24, 2012 | Hammering
Our circuit breakers keep tripping. The house is only 12 months old and our electrician says the builder installed Cutler Hammer Combination type AFCI is the problem. Is there a problem with these being...
They can be defective, but usually not. It is usually something that is plugged in that will not operate on the arc fault circuit. Brush type motors are bad as they are actually arcing at times. Unplug all devices, and try to find the culprit. These are for your safety, and once you find the problem devices you should be fine.
Sep 09, 2010 | Cutler Hammer "CUTLER HAMMER" ARC FAULT...
I was drilling and it just stopped working, is there a safety switch or something
If there wasn't a burnt smell signaling burning out the drill then you should be able to just recharge the battery
Jun 20, 2010 | Milwaukee 2690-24 18-Volt Hammer-Drill,...
I am trying to buy a sds chuck for my milwaukee plh 32xe rotary hammer drill
you can buy an SDS chuck that gos into a normal drill chuck,, it cant spin in the normal drill chuck as its got a hexsy drive on it its a much cheaper way to go and will fit any other drill you have or will ever get
Feb 16, 2010 | Milwaukee Drills
I am looking for new brushes and a new cord for this Cat#5338 Serial #805-9155 can i order these from a local company or McMaster Carr ?
If you go to Milwaukee Electric Tools on the internet, look under "find a service center" they have all the service centers in North America. You can get your parts at any of them.
Feb 03, 2010 | Milwaukee Tool Milwaukee 5338 Big Daddy 15...
Lost my manual for the milwaukee rotary hammer drill, Model GAT serial number 776A196160.Can I download a free copy?
http://www.milwaukeetool.com/PartsAndService/DownloadManuals/Default.aspx
That is NOT a valid Milwaukee Model #, but the link above will give you the manual you want if you enter the correct Model #..
Aug 05, 2009 | Hammering
Removal of flywheel from briggs and stratton 4 cycle engine 3 hp
Without the $100 flywheel remover that briggs will happily sell you you can do the following.
First you will need another body to help, two if available
2 pry bars or large screwdrivers
A air hammer if you have it or a large hammer if not
Loosen the flywheel nut until it backed off til the nut is just barely one thread or even with the shaft. Now put your pry bars behind the flywheel on opposite sides. Have someone provide constant pressure (don't be too forceful the block is made of aluminum and can be damaged). Now hit the end of the shaft with a hammer or air hammer (the nut is protecting the shaft threads) with medium power. With a few careful hits the flywheel should pop right off.
If you run into trouble or are unsure of something in this proceedure please ask.
Mar 30, 2009 | Briggs & Stratton Ignition Kit 2-8 HP...
Hammering Logo
82 people viewed this question
Top Hammering Experts
John Trevino
Steve
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Hammering Expert? Answer questions, earn points and help others
