Question about Karcher Vacuums
I need an owners manual for Karcher Pressure Washer ipx5 hds 945 1.027-881 year 2000
What filter kit do I need for a karcher MV 3P wet dry vacuum.
does the manual not tell you try Google make model etc
May 31, 2015 | Karcher Vacuums
Karcher vaporapid 1105 manual
there should be a labeled fill line on the clean water resavore
Mar 26, 2014 | Karcher Vacuums
Karcher 4.91 m leaking a lot of water as soon as hose is turned on, also rsulting in low pressure. It's approx 15 months old and used approx 12 times. Stored in spare bedroom during the cold winter. Was...
I could be that the rubber washer that is on the piece that the hose screws on to is dried out. Try replacing it. Any outdoor products store would have it.
Mar 27, 2011 | Vacuums
Cant get my soap dispenser hose working on my karcher winner 10, any suggestion?, lost my instructions manual so dont know weather i need to be doing anything for it!
If you have not yet found a solution, then here are some steps to take.
1. The soap dispenser only works on low pressure!!!!!!! So you have to REMOVE the high pressure Sprayer so that all you use is the Trigger Gun without the Extender.
2. Pull out the thin Plastic Hose with the filter attached in the end, and insert into your container of detergent.
It will only splatter the detergent over the area you want to clean, so you will then need to REATTACH the SPRAYER into the hand gun to work with the soap to lather, clean and spray of till clean.
This seems to be the way the system works on this model......also known as K2.36M (AU) in Australia or (EU) in Europe on the Karcher.com.au site then Service then Manuals. or on the link below.
Hope this helps any of you who has misplaced their Owners Manual just like I did and had a great problem trying to find a link as Karcher doesn't recognize the Model No: as Winner 10 or 11.
Cheers, Luke
Nov 19, 2010 | Karcher Vacuums
Can I get a parts book on the Tornado Karcher CW50? I need to order parts. Thank You
Karcher doesn't publish a parts manual, but there are numerous sites like this one that offer diagrams and allow you to order from a picture.
Oct 12, 2010 | Tornado CW50 - 91450 Bagged Upright Vacuum
The plastic parts inside the pump have disintigrated. I had a Karcher just like it and it did the same thing. I thew it away. Is there a rebuild kit for the FH180B? Where can I get it?
This is a Pressure Washer correct? Just want to make sure I am working on the right problem here since somehow you are in the vacuum category. But I can definitely help you with this pressure washer, just please confirm.
Thanks
Tim
Oct 05, 2010 | Vacuums
DE4002 Steam Vacuum: Is there a manual for The Karcher DE4002 steam cle...
Hi There,
Here's a link to the owners manual for your Karcher DE4002.
If you found this information helpful, please be sure to rate the repair helpful, or leave feedback. This is really appreciated.
Owners Manual For Karcher DE4002 Steam Cleaner
May 05, 2010 | Karcher DE4002 Steam Vacuum
My Karcher is leaking from the motor I think. Is it fixable? It's a KB 5050
My Karcher K 3.99 is leaking and dropped pressure. is it fixable (not filter)
Apr 04, 2010 | Karcher K DS 5500 Vacuum
I have just used the karcher steam cleaner and now cannot get the safety top off. Rio
i cannot get the cap off my karcher sc1122 even though its cooled down
Nov 16, 2009 | Karcher 1201 Canister Vacuum
Vacuums Logo
424 people viewed this question
Top Karcher Vacuums Experts
richie46
Are you a Karcher Vacuum Expert? Answer questions, earn points and help others
