Question about LG Televison & Video
I have an LG W931 VCR that needs to be re-programmed & i need to know how to set it up to record something. Please help.
  • LG Master
  • 5,047 Answers
If it's the manual you need then go to the LG website it should be free!
Posted on May 25, 2011
Need to know step by step instructions 0n how to record from my tv to my vcr including plug ins
I am assuming you wish to record what is playing on your TV to the VCR and not just asking how to record on a VCR, which is much easier, just put your cable from your antenna/cable box on the vcr and pick a channel from antenna or use channel 3 or 4 for cable box and press record. To watch TV with or without recording connect VCR output (Either coax or Composite) to same type input on the TV. If this is your question, then comment if you have trouble and I will get more detailed. This is a good video on doing this: https://www.youtube.com/watch?v=zgb7uoLIaQE
So if you want to record what is playing on your TV to the VCR, you must have a TV OUT on the TV. The only types of TV OUT that I have seen that would match to a VCR are either coax or RCA.
If the TV OUT is coax just connect one end of coax cable to the TV OUT on the TV and connect the other end to the Antenna/Cable IN on the VCR. Play the program on the TV and record on the VCR usually on either channel 3 or 4. Unless you have the VCR set up to play on another TV you will just have to use trial and error (record on one channel and playback on TV to see if you recorded anything, is so that is right channel, if not, then try the other one.) to find out which.
So, on to recording the signal from a TV on a VCR. If the TV OUT is Composite (RCA jacks, yellow, red, and white or black) you will need some RCA (Composite) cables. They may be labeled patch cords or dubbing cables at the store. That is if you can find them. I don't know if they are still being sold as a video accessory. If not just use RCA audio cords.
There will be two plugs on each end for mono sound recording and three for stereo sound recording. You will have to have audio or L & R audio, and video OUT on your TV and audio or L & R audio, and video IN on your VCR. Plug the yellow cable end into the video OUT on your TV and the yellow on the other end into the video IN on your VCR. Do the same for audio. I have always seen yellow as the color for video, but audio is sometimes white and sometimes black, and in stereo audio right is usually red, but left can be either white or black. With a little luck the cable plugs and TV and VCR IN & OUT jacks will match in color. If sound is mono the is nothing to get wrong. If audio is stereo the worst that can happen is the sound for right side will play on the left and sound for the left side will play on the right. As long as red is used for right it should be correct.
If there is only one set of input jacks on the VCR, the VCR input will probably need to be set to 'Line In'. If there are multiple sets of input jacks they should be labeled 'Input 1', 'Input 2', etc.. The VCR input setting will need to be set to the input you plugged the RCA cables into. The jacks you plugged cable ends into should be labeled. The setting for input on the VCR and TV should match the label on that device.
Now turn on the TV and put it on what you want to record. Do this before it comes on if you want to record all of it. Having set the VCR on 'Line In' or on the correct input, just press record on the VCR. Leave the TV on while recording.
As long as the TV is on and going to play something you want to record, you can set the timer on the VCR to record it, but instead of setting a channel you will choose either 'Line In' or the input number you are using.
This should always work to record a show on the TV when the signal is coming in through a coax cable from an antenna or cable box. But there are some TVs that only send that signal to the TV Out jacks. So if you are watching something from another source, like another VCR, a DVD player, or a video camera on TV on the TV and try to record that you will only record the incoming signal from the antenna or cable box.
In that case just connect the other VCR, the DVD or the camera to the recording VCR and play it on the one using the OUT jacks and record on the VCR using the Input jacks. This should make a better recording too. You can see what is happening by using the OUT jacks on the VCR and connecting the cable from them to the IN jacks on the TV and selecting the 'Line In' or 'Input 1, 2 etc.' matching where you plugged the cable from the VCR in on the TV.
Summary:
Device playing what you want to record is the: SOURCE
1. Using RCA dubbing cables plug them into the OUT jacks on the source and the IN jacks on the VCR.
2. Set the VCR input to the setting that matches the label on the jacks in which the RCA cables are plugged.
3. Play the program on the source and press record on the VCR to begin to record it.
Note: Leave the TV on if that is the source.
If you have any questions I assume I will get a notification if you leave a comment and I will be happy to answer.
Hope this helps. Good Luck!,
Ron
Jan 24, 2015 | Samsung Televison & Video
Just hooked up my new Magnavox DV220MW9 DVD Player ? VCR Recorder. I was able to set the time and a vcr timer program but now I can't switch the source. It now comes on as the DVD but neither the remote...
You need to release the timer to access the VCR. Press the Timer Set button on the remote or the Stop/Eject button on the recorder. Then press the VCR button.
Please note: the scheduled recording will not run as programmed unless you press the Timer Set on the remote again. (The timer locks the VCR until the scheduled ON time.) The DVD player is controlled separately and becomes the default unit.
I hope this helps.
Oct 04, 2010 | Philips Magnavox DVD/VCR Dual Player
Can,t Record from VCR to DVD
Make sure you have your VCR connected to the recorder by either the ANTENNA cable or 3 A/V cords. Make sure the recorder is on whatever output channel the VCR is set on (switch on the back of the VCR) for RF, or that the VCR is set for AV output and the recorder is set for Input 1 for the back of the recorder. You should be able to see a picture on the recorder of what's playing on the VCR. If you got that far, then you should be able to record the incoming program using the menu features of the RCA 8030. I hope this helps.
I need a manual for this machine if anyone has one.
Feb 20, 2009 | RCA DRC8030N
Connecting TV to DVD / VCR Recorder
Appreciate the direct "Ask Me".
I am assuming that what you intend to do is:
  • record a TV channel/program/show either on VCR or DVD;
  • while at the same time watching another TV channel/program/show directly on the TV.
Yes, but only if you are not using/needing a cable decoder box. To do this, the coaxial cable from your provider would have to be made to supply both the RF/ANT/CABLE IN of the VCR/DVD and the TV. To accomplish this, you would need a 2-way splitter. One input to the splitter, 2 outputs, one each for the DVD/VCR and the TV. The DVD/VCR would have to be connected to the TV using yellow, white & red RCA cables. To watch DVD, VCR and/or what is being recorded on the DVD/VCR, set the TV to Video mode. To watch regular TV, select the channels on the TV.
Good luck and Thank you for using FixYa.
Pls be informed that due to my current rank and rating, even a Helpful wouldbe detrimental to my status. Should this solution not address yourconcern, it would be appreciated if you could just not rate it at all. Cheers.
Dec 29, 2008 | LG RC797T
Panasonic NV SJ205 changing RF settings
Your VCR has input to record video-audio signal. Here is 2 options to record program in vcr.
1= You need to hook up video-audio cable at Monitor Out in TV and video-audio in at VCR. select Line-1 or Line-2 (where you hook up cable) in vcr and insert cassette with Record Tab intact, VCR is ready to record TV program. select desired channel on tv and hit record button of vcr, recording will start.
2= Plug RF antenna / cable wire in RF In of vcr and tune desired channel in vcr (get help of vcr's user manual for that) and push record button to start record directly in vcr.
Have further query, let me know please.
bye.
Sep 09, 2008 | Panasonic NV-SJ205 VHS VCR
Setting VCR to record at a specific time from TV
Press buttons such as "Menu" or "Timer" on your remote and you should see a place to set the times for recording. Try using the fast forward button on the remote to get to the next level of an item on the menu
May 26, 2008 | Televison & Video
Pioneer dvr 225 recorder
the dvd recorder has to be set to monitor the program your watching! you can not copy vhs tapes to dvd this way because the tapes that are prerecorded have a copy protect feature and will nut copy right!
Dec 15, 2007 | Pioneer DVR-225 DVD Recorder
Televison & Video Logo
46 people viewed this question
Computer Repairing
Computer Repairing
