Question about Dryers
MOD110.87562602 FRONT LOADER DOOR WON'T LATCH. BUT DRYER RUNS WITH DOOR CLOSED WITH A PROP. WHAT COULD BE WRONG?
  • Dryers Master
  • 43,501 Answers
The door latch/switch is bad....
That is not that hard to fix and you can easilybuy the parts yourself online...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
Here is one site that I recommend http://ping.fm/zJDAM
heatman101
Posted on May 26, 2011
Door will not stay shut
There has to be some sort of spring on the door latch assembly that keeps the door closed. If broken or no tension the door will not latch and spring open. And when the door springs open, a safety switch shuts the machine off.
Nov 21, 2013 | Bosch Nexxt WTMC3321US Electric Dryer
My malber wd2000 door won't open
Malbers use a thermal (heat acting) latch to hold the door closed, so it stays latched for about 2 mins after being turned off. This is to give you time to think before you open the door and possibly spill water all over your feet. When the little bi-metallic piece cools off, it bends to one side (inside the latch assy) releasing the catch, and the door can be opened. Sometimes, the bi-metallic part bends OK, but the latch catches and won\'t release. It just needs a little vibration to free it up. A smack to the latch area (on door or face of Washer) will free the latch.
I tell my customers: Don\'t pull too hard on the white door handle. If you can\'t open it with your little finger (seriously) it\'s not ready to open!
Nov 14, 2013 | Malber WD2000 Front Load Washer / Dryer
Washing machine won't turn on
It is likely that the trouble can be traced to the door latch switch. Since it is a front loader, it isn't possible to open the door once running - or start if the door is not latched fully.
This can be due to a faulty sensor (that detects whether the door is closed fully or not), wiring between the sensor and circuit board, or the circuit board that contains the logic that operates the washer. Before tearing into it, carefully inspect all around the door gasket and door opening on the machine itself. Inspect the actuator on the door - check to see that it hasn't been snapped off (if it has, replace it and try again) and that it is aligned with the sensor on the machine. Apply a modest amount of pressure on the door to see if the door simply isn't closing enough to allow the actuator to activate the sensor (making it believe the door is open). If it works, look for an obstruction somewhere that is interfering with the door closure.
Otherwise, you're goijng to need to call for service.
That's about it.. good luck!
Unless the problem is visibly obvious (corroded connection, broken connector, pinched wire, etc.) it will be nearly impossible to fix without some special tools, troubleshooting skills and familiarity with the washer's service manual.
Feb 14, 2013 | LG Tromm Front Load Washer And Dryer Set
Dryer won't start
If you look closely, there are 3 separate pins that must latch. One is a simple push-button style which latches no problem.
The others are little prongs at the top and bottom of door. The bottom prong latches cleanly, but the top one will not latch because the door is a bit too flexible.
Close the door normally, then firmly press on the top edge of the door. You will hear the final latch grab, then you press and hold the start button. The dryer starts normally.
Oct 21, 2012 | Whirlpool GEW9250 Electric Dryer
Kenmore front load washer door won't latch lock light on
On some Kenmore front load models, if the black gasket around the door opening is unseated (for example, because you drag some heavy wet laundry over it) the door will not engage the lock and stay closed. This is a feature to prevent the washer from leaking when the gasket is not sealed. To fix it, simply reseat the gasket and the door will close and lock.
Jun 21, 2012 | Kenmore 44102 Front Load Washer
The dryer won't run on any cycle...There is power to the dryer...the door is closed tightly...the latch appears to be in good condition.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jun 27, 2011 | Malber TD700 Electric Dryer
Frigidaire front loader door, will not latch securely. Can prop a broom against it and it works.
Sounds like could be broken Door hook/******..........Sometimes the small metal bar that holds the spring jumps out of its seating you can tell this if the door hook looks kinda funny not operating properly...Remove the door trim and refit the bar this allows the spring to operate and puts pressure onto door hook thuss allowing it to close ........
Nov 23, 2010 | Frigidaire ATF6000ES Front Load Washer
The dryer door will not stay closed. It will actually close but it will not stay closed therefore it stops during the cycle. It we prop something against the door it will stay closed and a full drying...
Go to www.appliancepartspros.com do a search using the model number and you will find the schematics for the dryer. Look for the cabinet parts diagram and locate the latch assembly. Look for the door latch and the door catch both parts will probably cost less than $10. There may be some minor disassembly required but not a big ordeal.
Nov 22, 2009 | Dryers
Whirlpool Front Loader Dryer Door will NOT stay closed
I have the same issue with the door popping open. If you push hard on the bottom of the door then it snaps in. I think the bottom latch is broken or misalligned.
Oct 17, 2009 | Whirlpool GEW9250 Electric Dryer
Dryers Logo
Top Dryers Experts
