Hello, I have a weather king 13pja, its about 4 years old. I have checked everything. the coils are cool, the unit receives the signal to turn on, you can here the click but nothing. Electricity is going to it. the outdoor unit will not run. any suggestions.
  • 6 Answers
SOURCE: fan coil unit won't cool or heat in room1 while room2 runs well
could be undercharged, or overcharged, or wires weren't put back on valves in unit.
Posted on Feb 16, 2009
  • 4 Answers
SOURCE: KING FURNACE MANUAL
You do not need a warranty card for your warranty to be valid. Your installing contractor provides the labor warranty and the factory provides the warranty on parts. All the necessary information to make a (parts) warranty claim is embedded in the serial number of your unit. As for a manual you should contact the installing company or visit the Weatherking (Rheem) site to request this information. www.weatherking.com
Posted on Mar 26, 2009
SOURCE: A/C Stopped Working
outside fuses are blown on condensor unit at dissconect
Posted on Jul 13, 2009
  • 534 Answers
SOURCE: Ramsond Split system - R55GW - will not cool or heat
That would be the way to go even thought the cost is high. If not you run the risk of compressor failure and the metering device may be clogged. I know the price is what has you over a barrel but, the cost to you in the near future will be 3 times as much.
Sorry I could not cure the problem over the internet
Also check around there may be someone who could do the job slightly cheaper.
Dave
Posted on Jan 15, 2010
hvac1
  • 338 Answers
SOURCE: a/c unit not cooling house weatherking model #12AJA3601
I use a spray nozzel on my water hose to clean out the oustide coil. You can go to a local Hvac parts store and get a cleaning gun and foam to clean the coil. I just use my water hose and sprayer with arm and hammer baking soda.
Posted on Jun 04, 2010
Weatherkink model 13AJA42A01 3 YEARS OLD. UNIT WILL NOT COOL LIKE IT DID. UTILITY BILL HIGHER. ADDED FREON DIDNT HELP. LOW SIDE 72PSIG . HIGH SIDE 300 PSIG. AMBIENT TEMP. 92 DEGREES. THERMOSTAT SETTIN
Check-1)Airflow be sure inside and outside coils are clean. Plus filter. 2)Leaks in duct return and supply 3)Temp difference across cooling coil. (Evaporator)should be around 18degree diffrence between air going in and air going out. 4)See that nothing is making heat run at same time. Like a stuck sequencer or short in control wires.
Aug 27, 2012 | Weather King 10AJA3601AH Air Conditioner
I have RUUD furnace with build in coil for air conditioner and Weather King compressor outside of my condo. ALL EQUIPMENT IS 4 YEARS OLD I didn't have any problem with heat at winter, but in summe
When you remove the panel to the unit it turns off the power to it. The reinstalling the panel will reconnect power and allow the unit to reset. So the cheapest and easiest thing you can try is to replace the thermostat. Make sure you see how many wires you have connected to your existing tstat and buy near the same thing. It's possible that the tstat is acting up, not allowing the unit to cool when the temp demands. And turning off power is resetting the tstat as well as the unit. It will be hard to troubleshoot with the info provided so a new tstat will be worth a shot. Hope this helps!
Apr 07, 2017 | Ruud Matching Split Air Conditioner
Trying to get info (tonnage seer rating) on a weatherking mod# 10ajb48a01 condencing unit to find a matching evaporator coil and cannot find anything on internet
This is a 4 ton model condensing unit. You can go up 1/2 ton for the evaporator, meaning a 4 1/2 (A) coil will work just fine and allow a bit more cooling capacity.
Sep 10, 2011 | Weather King 12AJA4801AH Air Conditioner
A/c unit not cooling house weatherking model #12AJA3601
Jun 03, 2010 | Weather King 12AJA4201AH Air Conditioner
Hello I need some help, the a/c had been running for a short time then just turned off. Thermostat doesnt light up. We flipped the circuit breaker but nothing, the unit is 3 years old help!
The fact the thermostat doesn't light up means its not getting power which would normally come from a small transformer inside the furnace or air handler. In most cases there is a switch located on the side of the furnace or immediately next to it. Quite often the switch with inadvertently get turned of by a child. Simply turn the switch back on if thats the case and everything should work just fine once again.
Sep 14, 2009 | Weather King Heating & Cooling
Freez up at the tube going to the fan blower unit
it is either low on freon or the airflow is blocked. check your filter first. then see if the coil is dirty. saying it needs a new coil because it is freezing is an expensive guess unless he did a freon leak test.
Oct 27, 2008 | Weather King 10AJA4801AH Air Conditioner
Not cold air cool air?
Check your air filter. if its ok call the guy who installed it and have him fix the leak. It prob is a bad weld joint. Check the joints on the copper tubing inside at the coil and outside at the a/c and feel around and see if there is oil leaking from the joint. If not you may have a leak in a coil or on the txv inside on the coil.
Aug 31, 2008 | Weather King 10AJA3601AH Air Conditioner
Not cooling predictably
Possible causes are dirty filters, dirty condenser coil, dirty evaporator coil, or low referigerant charge. Any one of the conditions will affect heat transfer.
Check the filters in your indoor unit, If they seem to be clean and replaced on a regular basis, your evaporator coil is probably in good shape. Unfortunatley on some Weather King models even checking the evaporator coil is not possible due to the extensive amount of referigerent lines that block access to the coil without some major work including evacuating the refrigerant.
The most likely cause is a dirty outdoor condenser coil. On weather king models you will have to remove the casing that surrounds the coil because is is built in such a way that the condenser coil cannot be properly cleaned with the casing in place. Once it is removed make sure breaker is switched off and clean the coil with a water hose.
If your outdoor coil is not dirty then it is a refrigerent problem.
Jun 10, 2008 | Weather King 10AJA3601AH Air Conditioner
Heating & Cooling Logo
27 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
