How can i fix this problem in my flyff ph client its said ERROR: File Not Found CODE:0 RESULT:4 i really need your reply please i would be so greatfull if you help me with this problem.
    Novelist:
  • 123 Answers
Good day. For this kind of problem the only way to resolve it is to download the entire client again and have it reinstalled on your pc. Most client get specially after getting patch or updated in which the client itself encounters an error which cannot be solve even you try to patch the game. This are some tips to resolve your concern
Things to do:
1. download full client
2. uninstall previous client
3. delete the previous folder
4 restart pc
5.install the game
6 patch the game
7. restart pc
After this the game should work fine. Make sure that you have a recommended settings to avoid future problem. If this didnt resolve your issue you can check their official site for help. Hope this resolves your problem. Thanks for visiting Fixya and have a great day.
Posted on May 22, 2011
How do I fix server error 8004849
This is from Microsoft:-
If you receive Server Error: 0x80048849 and/ or 0x80048820 in Windows Live Mail at home or while you're in your regular network, it may be due to the setting of the MTU (Maximum Transmission Unit) on the mail client.
If you get this synchronization error at a coffee shop, airport or a place from where you don't usually connect to the internet, we suggest synchronizing mail on your regular internet connection.
When the MTU setting on the mail client is larger than the MTU settings configured on network devices between your mail client and the mail client servers, some data packets may be lost, causing mail synchronization to fail.
Follow the steps given below to fix synchronization errors due to mismatched MTU settings:
Determine the MTU setting on your network device
Apply the MTU setting to your mail client
This is a trial and error process, and will be different for each user. You may have to repeat the procedure below a few times, before you can find out the MTU setting of your network device. Follow the steps below:
Open command prompt
Click Start ? Run ? Type cmd
In the Command Prompt Window, type in the following:
Ping <Mail server address> -f -l 1500
Notes:
The <Mail server address> is the IP address of the mail server that you are unable to synchronize with.
For Hotmail, 65.55.33.106 is the IP address for DeltaSync (mail.services.live.com).In this document we will be using this IP address as an example.
In the -l 1500, 1500 is the max MTU for Ethernet connections.
You may get an error like this (100% packet loss):
C:\Users\username>ping 65.55.33.106 -f -l 1500
Pinging 65.55.33.106 with 1500 bytes of data:
Packet needs to be fragmented but DF set.
Ping statistics for 65.55.33.106:
Packets: Sent = 4, Received = 0, Lost = 4 (100% loss)
If you received the error above, subtract 28 from the 1500 bytes of data. In the Command Prompt Window, type in the following:
Ping <Mail server address> -f -l 1472
If you get a 0% Packet Loss with 1472, it means the MTU setting of your configured network is 1472
Note: If you continue to receive the error described in (b) above, repeat the above steps by subtracting 28 from 1472 bytes of data. Repeat these steps until you get a message for 0% packet loss. If you were able to communicate with the mail server at an MTU size of 1424, you will receive the following:
C:\Users\username>ping 65.55.33.106 -f -l 1424
Pinging 65.55.33.106 with 1424 bytes of data:
Reply from 65.55.33.106: bytes=1424 time=230ms TTL=241
Reply from 65.55.33.106: bytes=1424 time=196ms TTL=241
Reply from 65.55.33.106: bytes=1424 time=162ms TTL=241
Reply from 65.55.33.106: bytes=1424 time=163ms TTL=241
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss)
Approximate round trip times in milli-seconds:
Minimum = 162ms, Maximum = 230ms, Average = 187ms
Open command prompt as administrator (you must be an admin on the computer)
netsh int ip show int
You will receive a message similar to the following. Find the connection name that you use to connect to the internet and note the Idx value
C:\Users\Username>netsh int ip show int
Idx Met MTU State Name
1 50 1472 connected Loopback Pseudo-Interface 1
11 20 1472 connected Local Area Connection
To apply the correct MTU setting on your mail client, type the following in command prompt:
netsh int ip set interface <Idx value> mtu= <MTU setting of your router> store=persistent
Press Enter
For example, if the correct MTU setting was 1424 and Idx value of your connection was 11, you will type:
netsh int ip set interface 11 mtu=1424 store=persistent
If (c ) was successful, you will receive the confirmation message "Ok"
Exit command prompt
Restart your computer
Open WL Mail and see if the issue persists.
have Windows Vista Home Premium Recently unable to send or recieve Window...
Feb 12, 2015 | Toshiba Computers & Internet
How do you fix quick books error code (-6177,0)
How to fix it
Intuit recommends 4 solutions for this problem. The first solution may solve your problem, or you may need to try all 4 to resolve the issue. For best results, perform the solutions in the order shown.
Solution 1: Move the file to the local hard drive
Solution 2: Be sure your version of QuickBooks is updated to the latest release
Solution 3: Run the QuickBooks File Doctor
Solution 4: Manually resolve -6177, 0 without using the QuickBooks File Doctor
http://support.quickbooks.intuit.com/support/Articles/SLN41400
for more help call 1-855-383-7236 or visit QuickBooks Tech Support
Jul 10, 2014 | Intuit QuickBooks Pro 2007 Full Version...
Upgrade log: ---------- HWK Update Client v
Authentication stage error: Error: Server returned unrecognized reply
ufs 3
Oct 06, 2013 | Lantronix CoBox-FL-IAP (COBOXFLIAP11)...
HWK UPDATE
Originally Posted by MIRYALA SRINIVAS viewpost.gifhwk Update server has crashed,ODIA TEAM is working to fix the issue ASAP.
So dont update your box.
We inform you when server is working fine
Br.
Vijendra Saini.
dear sir,
i have format my pc then i need to install what should i do????????
Upgrade log:
---------- HWK Update Client v 2.0.8.0 ----------
---------- HWK upgrade started:9/8/2009 8:19:09 PM ----------
-- Target Id : 62 CF 1 10
-- UFSx Boot : UFxBoot V2.2 (c) SarasSoft 2003.
-- UFSx Firmw.: UFS_USB V2.8 (c) SarasSoft 2007.
-- UFSx S/N : 71327
-- Features : 00000001
-- Licence 5 : True
-- UFSx Vendor: TORNADO
-- HWK ID : A1.04-PRO1-7ACEA977416000C9
-- HWK Status : 1, DL: 0
Locating HWK Upgrade server...
HWK Upgrade server found!
Preparing connection to server...
Connecting to HWKUpgrade server...
Server connection successfully established.
Authenticating on server...
Jul 25, 2012 | Computers & Internet
ERROR FLASH DISK : used space 0 free space 0 "read data is 0 , the data not explorer' Please fix the problem, Thanks
click start control panel administrative tools computer management disk management right click on your drive select properties click tools you should see click check now click start two boxes
automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now start
you might tick one box then return after its finished the first repair then return and tick the second box you should not do anything while the chkdsk utility is in progress any input may damage this drive
I found that you get best results by ticking one box then returning after it has finished then tick the other box
If you need more help with this post a reply
hope this helps you
Jul 31, 2011 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Upgrade log: ---------- HWK Update Client v 2.1.0.0 ---------- ---------- HWK upgrade started:6/11/2011 7:02:40 AM ---------- -- Target Id : 62 CF 1 10 -- UFSx Boot : UFxBoot V2.2 (c) SarasSoft...
Upgrade log:
---------- HWK Update Client v 2.2.0.0 ----------
---------- HWK upgrade started:8/1/2013 6:34:25 PM ----------
-- UFSx S/N : 56512
-- Licence 5 : True
-- HWK ID : A1.04-PRO1-DA0064A542600069
Jun 11, 2011 | Lantronix CoBox-FL-IAP (COBOXFLIAP11)...
How 2 get cheats in flyff ph tell me plzzzz
Hi indolos2008
Go to http://www.cheatsguru.com/pc/flyff/ or simply do a Google search: "flyff ph cheats" to give you a range of sites to visit.
Jun 03, 2011 | Video Game Consoles & Games
If I try to scan or copy some files, it writes me: 'Error in scanner and follow instruction in manual. Scanner driver will be closed.(Code:201)'. Please help
copy and paste the link below to your browser...
http://www.google.com.ph/search?q=CanoScan+3000F+Flatbed+Scanner+code+201&ie=utf-8&oe=utf-8&aq=t&rls=org.mozilla:en-US:official&client=firefox-a
Mar 01, 2011 | Canon CanoScan 3000F Flatbed Scanner
How to download hwk update client v 2.1.0
Upgrade log:
---------- HWK upgrade started:6/2/2011 6:35:55 AM ----------
-- UFSx S/N : 78650
-- Licence 5 : True
-- HWK ID : A1.04-PRO1-DE6985914260006D
Oct 07, 2010 | Lantronix CoBox-FL-IAP (COBOXFLIAP11)...
No sound!
Did you get the driver from HP? Here is a link to install (or download) the driver for your system. It may be beneficial to download it to your computer in case you need it again.
SR1603WM Audio Driver
Dec 22, 2008 | Computers & Internet
Computers & Internet Logo
308 people viewed this question
David Payne
David Payne
