Compatibility problem with my latop and router
I've recently installed a new router in my house but when I try to connect to the internet via wi-fi t doesn't work. It just says that the set up of my laptop is not compatible with the network. This is not the fist time that this has happened to me either. I had the exact same problem at a friends house before. My laptop is an Acer aspire 7720 G and it has the latest NLan wireless card so I don't understand the problem. One friend suggested that I change my computers IP address. Is this completely necessary or is there an easier way? And, if I must change the IP address, how would I go about doing that? Please bear in mind that I'm a complete wally when it comes to computers so everything will have to be explained in very simple language. Thankyou so much.
  • spazzer Aug 15, 2008
    I can see the network in the list of possible networks to connect to. But where the signal bar usuallly is there is a big red cross with " the set up of your computer is not compatible with this network." It works fine if I connect via cabel.
  • spazzer Aug 21, 2008
    This problem has been resolved, not entirely sure how but there seems to be 2 sinals comming from the router. By this I mean speed touch *** and now speed touch***2. I can connect no problem to the new 1 whereas the original still saysits not compatabile. Don't understand it myself, but I'm just happy it works.
  • 474 Answers
Each router has it's own IP address so you might have to change it and most routers have an ip that starts with 192.
Posted on Aug 16, 2008
    Novelist:
  • 173 Answers
First check if you are able view your wireless network in your laptop, and are you connected to the wireless network.. is there any other wireless computer going online through the same router.
Posted on Aug 15, 2008
6ya staff
SOURCE:
I have T-Mobile 4g galaxy avant android phone. I do not have coverage n my ares 4 the Internet. Cam I hook WI-FI up 2 my desk top and accessories the inn tenet via my home wi-fi
You can get WI-FI anywhere WI-FI is available with a smart phone.
But if you only have a modem at home and an ethernet cable from the modem to your computer to get internet, then you may not have WI-FI at home.
You'll need to get a wireless router to have WI-FI at home.
Once you do that, you can continue to have your desktop hooked up by the ethernet cable, but you can also install a WI-FI adapter card in your desktop. It will have an antenna on the back of your computer and then you can set it up anywhere in your house and have internet without an ethernet cable.
Mar 16, 2015 | T-Mobile Cell Phones
Ethernet conection dosen't work
More than one computer or just one? Sounds like something wrong with the computer lan port.
Jan 10, 2013 | Computers & Internet
I have pokemon white version & it says we do not have wifi connection when we do have it at our house. What do we need to do to make it work?
The DS Lite does in fact connect to wi-fi via a router. For example you can have a Wi-Fi battle with any random person around the world if you have wireless internet in your house on Pokemon Black or White. My thought would be that your router has an encryption type that your DS does not support. The same thing happened to me. You can first try to go to the main menu of your Pokemon game and click on the Nintendo WFC Settings. Through here try and connect to your router by entering the password you have set for your router. If this still doesn't work try taking the password off of your router via your computer and see if you can connect then. Lites will only connect to certain types of encryption passwords. I use WEP and it works fine.
Mar 15, 2011 | Nintendo DS Lite Console
I purchased a new IPOD and I can not access the wifi from my Linksys wireless router.. I reset my Linksys router to try to solve this problem. And at first when the light was amber I was able to have...
Resolution If you know there is a nearby Wi-Fi network, but you are unable to locate it on the Settings > Wi-Fi screen:
  • Move closer to the Wi-Fi router or hotspot.
  • If you are using a personal Wi-Fi network, verify the Wi-Fi router is connected to power and turned on.
  • Wi-Fi networks configured as "closed" or "private" do not broadcast the network name to Wi-Fi devices.
    • Join a "closed" or "private" network by tapping Settings > Wi-Fi > Other and entering the Wi-Fi network name, security, and password.
After joining a Wi-Fi network, if you notice the signal strength is low or intermittent
  • Check for any sources of potential interference.
  • Remove any cases or attachments on your device that could interfere with a Wi-Fi signal.
If you are unable to access the Internet while connected
  • If you are using a commercial Wi-Fi network that requires a special login or subscription, see this article for more information.
  • If you are in a location with multiple Wi-Fi networks, verify that you are selecting the correct network.
  • Verify that the Wi-Fi network settings are correct:
    • Tap Settings > Wi-Fi.
  • You can configure network-specific settings, including IP address, DNS, and Search Domain settings.
  • Use "Forget this Network" to reset settings for this particular Wi-Fi network, including the password. This is also useful if you identify a network issue and want to prevent the device from automatically using this network in the future.
  • Use "Renew Lease" to acquire new IP address, DNS, and Search Domain information from the Wi-Fi network.
  • Note: If the Wi-Fi network uses MAC address filtering, you will need to add the MAC address to the access list for the Wi-Fi router. The MAC address for your device is listed as the Wi-Fi Address in Settings > General > About.
If you are still unable to join a Wi-Fi network, or are unable to access the Internet while connected, try the following
  • Restart the device
    • Hold the power button until "slide to power off" appears. Slide to power off your device. When it is off, press the power button to turn it back on.
  • Reset network settings by selecting Settings > General > Reset > Reset Network Settings. Note: This will reset all network settings, including passwords, VPN, and APN settings.
  • iPhone only: If you continue to experience issues, consider turning off Wi-Fi and using the cellular data connection instead of Wi-Fi.
Additional Information If using a Wi-Fi router at home, refer to your user manual/documentation to assist you with some of these suggestions.
  • Check the manufacturer's website for your Wi-Fi router for firmware or software updates.
  • Verify the Wi-Fi router can broadcast an 802.11b/g signal. If using a 802.11n Wi-Fi router, consult the manual/documentation for how to configure the Wi-Fi router for 802.11b/g compatibility.
  • If you are using multiple WEP keys on your Wi-Fi router, try configuring your Wi-Fi router to use only a single WEP key.
  • Try or resetting (or turning off and then on again) your Wi-Fi router. Note: If your ISP also provides cable or phone service, check with them before attempting this step to avoid interruption of service.
  • Disable wireless encryption or security on the Wi-Fi router to rule out encryption issues. If this resolves the issue, try using a different encryption or security protocol.
Mar 22, 2010 | Linksys Wireless-G WRT54G Router
I cannot connect my IPOd Touch to the internet to download music . I need wi-fi connection. I already have internet service. What is wi-fi and how do I get it?
Wi-fi is wireless internet. Wireless internet is aquired via a router that supports wireless internet. The router is connected to your modem which supplies your internet.
Sep 29, 2009 | NetGear DG834G Router
How can i ins tall my rangemax dual band wireless-n router wndr3300 to my laptop to setup wifi in my house
Connect your router to computer with ethernet cable.
Then access it with following link.
http://192.168.1.1 or
http://1921.168.0.1
type user name as "admin" and password as "admin" or blank or "password"
Then configure your router as WEP.
Then go to wireless and check that wi fi is enabled.
Then go to wi fi security and add WEP key it is your password to connect your wi fi.
Also enable dhcp if you want get ip auto to computers.
configure your wan settings as your internet service provider like dns ip addrses.
Then save settings and restart the router.
Now go on your laptop first turn the wi fi switch on your laptop .
Then check that your wi fi network adapter driver is proeprly installed.Also check in my network places that your wi fi is enabled.
Then double click on wi fi icon and click on "View wi fi networks."
then connect then enter password which you set in router wep key.
Let me know if you need more assistanse.
Thanks.
Aug 31, 2009 | Computers & Internet
I want to to connect 3 computers to Belkin N+ wireless router
you don't need an installation for the router on the other devices, just make sure you connect via ethernet or wi-fi (for wi--fi make sure to have a strong password for the network)
Apr 17, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Hi, I have an old acer laptop and my wife communicates with me on it using broadband and a router with a usb pick up. I have returned home and have a new acer laptop with wireless LAN already installed. It...
Youe broadband router is working ok with the broadband cable.So it is configured with the broadband cable.Now,to work with the wireless internet,you have to configured the wi-fi router to work internet.You can see the wi-fi connection but unless & untill you will configure wi-fi router it must not work or if before it was working with the wi-fi then you can check the wi-fi router setting because it might change by mistake.Surely it will work after configurating wi-fi router.
Jan 03, 2009 | Computers & Internet
Cannot get ipod touch to connect to wireless network
Many Wi-Fi issues can be resolved by doing the following:
Basic troubleshooting
  • Tap Settings > Wi-Fi and turn Wi-Fi off and then on again.
  • Verify that you are in range of your Wi-Fi router or base station.
  • Confirm that your Wi-Fi router and Cable/DSL modem are connected to power and turned on.
  • Check whether other devices (portable computers, for example) are able to connect to the Wi-Fi network and access the Internet.
Jan 01, 2009 | Linksys Wireless-G WRT54G Router
Wii Error Code 91010.
Error Code: 91010
Our experience shows that error messages within this range are typically caused by temporary network issues with the Nintendo Wi-Fi Connection. If there is a problem with the network, our technicians will work to get the service back up as soon as possible. Please retry your connection later.
If you are connecting to the Nintendo Wi-Fi Connection for the first time, or the problem has not resolved itself after a few hours, please review the following:
  1. Our servers may be trying to handle an unusually high amount of traffic (especially if you are trying to play online with a recently-released or popular game, or if there is a new Wii system update). Please wait a few hours and try the connection again later.
  2. How are you connecting online? The Nintendo Wi-Fi Connection is only compatible with Cable, DSL, and Fiber-optic internet connections. If you are connecting via Satellite, EV-DO (cellular), Dial-up, or other types of connections, then you should try to use an alternate type of connection. Contact your Internet Service Provider if you are not sure what type of internet connection you have.
  3. The error may be caused by a basic setting on the router that needs to be adjusted (such as the channel). Please review our general router troubleshooting.
Sep 12, 2008 | Video Game Consoles & Games
Open Questions:
Computers & Internet Logo
96 people viewed this question
Ekse
Marvin
Marvin
