When you plug machine in the on/off button and the star cancel buton lights momentarily and also the final spin light. Then when you try to switch on the machine using the on/off button nothing is happening not lighting up.
  • 1 more comment
  • Mark Royle May 22, 2011
    Sorry should have said its a Hotpoint WF100P
    Hotpoint Aquarius WF100P When you plug machine in the on/off indicator and the start/cancel indicator and the final spin idicator above the buttons light momentarily. Then when you try to switch on the machine using the on/off button nothing is happening, not lighting up.
  • Mark Royle May 23, 2011
    I'm getting 32.7 ohms on the heater element. Since I originaly wrote this, the machine now does the same thing except the on/off indicator and the final spin indicators come back on and stay lit.
  • Washing Mach... Master
  • 1,902 Answers
Hello & Welcome to FixYa
If the drain filter assembly located inside the front bottom access panel is clean and the water has drained completely then all these lights indicate a problem with the heating element. If you have a voltmeter then you can test the element for 28 ohms, if it is fine then the control board needs replacement. Please get back to me if you have any other questions.
Kevin
Posted on May 22, 2011
  • Kevin White
    Kevin White May 23, 2011
    The control board needs replacement
  • 4,323 Answers
Hi
If the drain pump is clean and the water inlet valve is fine then the issue is with the control board that is bad and should be replaced. Hope this helps...please post back with the manufacturers name and model no for further assistance.
Daniel
  • Daniel Scott
    Daniel Scott May 22, 2011
    Clean the drain pump assembly first, it is located inside the front bottom of the unit. After its done and the issue returns then it means that the control board is bad and should be replaced.
Hp 625
A bit vague? Unplug, remove battery, leave battery out, plug in , push the on/off button. Describe what happens, fan spins? LED's blink? HDD spins up? Sound? Any thing on the screen?
May 26, 2013 | Computers & Internet
Washing machine does not do anything when you press start
Turn off the machine then unplug it for at least 5 minutes and plug it back. Turn on the washer then press any button and wait for 5 seconds. Press and hold the START/PAUSE and CANCEL buttons simultaneously and the most recent error code will appear on the display as an "E" followed by two numbers, a number and a letter or two letters. The control will beep and the Door Lock, Wash, Rinse, and Final Spin indicator lights will flash. Post back the error code to determine the problem and necessary actions to be undertaken in order to address it.
Aug 23, 2011 | Frigidaire Washing Machines
Hotpoint Aquarius WD440G
Unplug the machine from the wall for 5 minutes, then plug it back in and try it again. If the lights come back, the control board needs to be replaced.
Jul 28, 2017 | Hotpoint Ariston WD440G Front Load...
Control lock light will not go off.
Do you have any error codes?
Does water remain in the washer after the final spin?
If water remains in the washer after the final spin, then the door will not unlock. Drain/Spin or Spin Only to remove any remaining water from the washer. The door should unlock at the end of the cycle.
Is the door locked and the Add A Garment light on?
If the Add A Garment light is on, then the washer door will unlock after the Pause/Cancel button is pressed once. Pressing the Start button will restart the washer at the same point where it left off in the cycle.
Is the door locked and the Add A Garment light off?
If the Add A Garment light is off, then the washer door will unlock after the Pause/Cancel button is pressed twice. The door will not immediately unlock while the cycle is running due to a possible high-water level in the washer, high-water temperature, tumbling or spinning. It may take up to five minutes for the washer to stop spinning and draining before the door will unlock. You will hear the door click when it unlocks.
If Pause/Cancel does not work:
  1. Unplug washer or disconnect power for one minute.
  2. Plug in washer or reconnect power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, call for service.
Dec 19, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Control Lock
Beko WMA 510 stuck on cycle
Hi if your beko WMA 510 washing machine wont drain or has a spin problem then you have to check the carbon brushes first.
Also check all waste pipes are clear and inspect the pump I have included this video below.
At our website I am doing self diagnostic videos on these beko's as we speak so all tutorials will be in this link below
How to replace Beko Washing Machine Motor Carbon Brushes
you might find this test video helpful but only do it if you have checked the motor
Sep 05, 2008 | Indesit W 123 Front Load Washer
The 3 buttons
button selection : To select an option press the button and you will see a light come on above the button. Press again to cancel and the light will go out. You cannot alter the options once the machine is running. Note : remember to cancel buttons after use!
As you look at the machine
Left hand button... Rinse Hold.. use this option to Help reduce creasing of delicate or synthetic fabrics by holding clothes in the final rinse water. The rinse hold light will flash to indicate that the programme is holding final rinse water. Complete the final spin by pressing the Rinse Hold button when light is flashing.
This is not available with Wool or Spin only programmes.
Middle Button.... Energy Save... use this option to save money and time on lightly soiled loads. This is not available with the Quick Wash, Rinse and Spin, or Spin Only programmes.
Right Hand Button .... Super Rinse... use this option for Large Wash loads and items for young children or people with sensitive skin. This option increases the water level for the first two rinses. This is not available with Cold Wash, Rinse and Spin or Spin Only programmes.
Copied from my Hotpoint FEW12 user instruction sheet.
Hope it helps.
Sue
Jul 31, 2008 | Hotpoint First Edition FEW12 Front Load...
Final spin cycle for kenmore 417.40042990
This is an interesting problem. How long does it have to sit before you can get it to spin? Can you let it go through the cycle and then immediatly put it into spin and it work? This machine will not spin until the pressure switch senses the water has drained. So you could have a slow drain, a clogged pressure hose, or faulty switch. A clogged hose or faulty switch would usually cause it to fill with more water than normal also. A slow drain is most likely, check the drain hose when it is draining and see if it is putting out a strong flow or just slowly draining. I think you will find it to be slow. This will cause it to take up all or most of the spin time trying to drain the water. If it is slow draining, check the pump for a sock or some obstruction. If the drain is good, remove the top and remove the rubber hose from the pressure hose and blow through it. You should be able to blow through it easily. A restricted pressure hose will cause the machine to think it has water in it after it has drained.
Oct 05, 2007 | Washing Machines
Washing Machines Logo
18 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
