Question about Mantis Gas Mini Tiller/Cultivator, 2 - Cycle
Mantis tiller will not start. Cannot get primer bulb to draw fuel.I replaced all of the lines,primer bulb still won't work. Tiller will start by priming cylinder by removing spark plug. Help?
  • Anonymous Mar 17, 2014
    Just got our mantis deluxe xp tiller 4cyl march 3rd cannot get primer bulb to draw fuel wont start.
    Problem Solver:
  • 17 Answers
Make sure there are no leaks in the bulb. Did you reattach the fuel lijnes correctly? You should feel resistance after pushing 3 or 4 times to ensure fuel is getting to the carb. If necessary replace the bulb. Otherwise check with Mantis at www.mantis.com or give them a call for troubleshooting assistance.
Posted on May 24, 2011
Just bought a carb kit. Which way does the diaphragm go in ? Also,the primer bulb won't show gas.
if the primer bulb cannot pick up fuel and the fuel lines are good then you have a bad primer plate and you need a new carb
Mar 25, 2015 | Mantis 2-Cycle Tiller
My mantis tiller with a honda gx22 engine starts then shuts off after approx. 30 sec.
If your unit has a primer bulb, start your engine . When it starts to die push your primer, if the engine comes back to life you have a carb issue.
Aug 09, 2014 | Mantis Tiller 4-Cycle Engine Handy Item...
Vapor lock on Mantis
check the fuel lines for a breakage or the primer bulb for a crack. Sounds like it is sucking air instead of fuel
Jan 06, 2013 | Mantis 2-Cycle Tiller
Cannot fill primer on mantis tiller
Check valve in primer body stuck with debris, cannot clean, buy replacement
May 23, 2012 | Mantis 2-Cycle Tiller
Mantis tiller won't start,does not seem to be getting any fuel in
if the primer bulb isn't filling up with gas when you push it the the diphram in the carb. behind bulb is bad needs to be replaced then it should work unless fuel lines are crossed or has holes in them
Jun 08, 2009 | Mantis Tiller
did it also run out of oil, because it seized like it did you might of burnt the engine
May 31, 2009 | Mantis Tiller
Would like to know what year this tiller would be.
replace primer bulb. If that's not the problem check the float in the carb for pin holes . check fuel lines and intake line
May 15, 2009 | Mantis Tiller
Mantis tiller no fuel getting through to the primer bulb
the fuel line may be clogged or is collapsed go to a car or a home improvement store go to lawn and garden and get a 3-4 mm gas line
Apr 23, 2009 | Mantis Gas Mini Tiller/Cultivator, 2 -...
Mantis Tiller
check the fuek lines for hole and leaks, check the fuel filter and clean if necessary. remove the carbuerator and inspect the gasket; it should be soft and flexible, if it seems hard or brittle replace it. clean the carb with carb cleaner sray (available at any local auto parts store) and compressed air. make sure you get inside the small fuel rail holes. check the primer bulb for pin holes and seating/sealed properly. if that doesn't work have the carb repaired at a service center or replaced.
Nov 13, 2008 | Mantis Tiller
Mantis Gas Mini Tiller/Cultivator, 2 - Cycle Logo
1,875 people viewed this question
Top Mantis Garden Experts
paulfvincent
Matt Olenzek
Matt Olenzek
Mike Squire
Are you a Mantis Garden Expert? Answer questions, earn points and help others
