Question about Logitech FreePulse Wireless Consumer Headphones
My logitech headphones dont turn on anymore. - Logitech FreePulse Wireless Consumer Headphones
  • vds13 Sep 07, 2008
    my transmitter and headphones do not connect
Quote from LOGITECH official site:
In rare cases, the FreePulse Headphones may loose synchronization with the receiver. If this occurs the following steps will re-establish the connection by putting both the headphones and the receiver in discoverable mode (actively searching for another bluetooth device it can connect to).
Putting the headphones in discoverable mode:
Press and hold the power button (located next to the charging port on the right earpiece) on the headphones. The LED on the button will go through three states in this order:
  • Blinking Red
  • Off (continue to hold. the LED will be off for several seconds)
  • Alternately blinking red and blue. (The headphones are now in discoverable mode and you can release the button at this point. The headphones will remain in this state for 30 seconds).
Putting the receiver in discoverable mode:
Press and hold the power button (located on the side of the receiver opposite the headphone jack).The LED on the button will go through three states in this order:
  • Blinking Red
  • Alternately blinking red and blue. (The reciever is now in discoverable mode and you can release the button at this point. The reciever will remain in this state for 30 seconds).
Re-establishing the connection:
To re-establish the connection between the headphones and the reciever, put the headphones and the receiver in discoverable mode at the same time. It will take a few seconds for the two devices to establish the connection. Once the connection has been established the LEDs on both the headphones and receiver will glow solid blue.
Do this and Freepulse will be pleased.
Posted on Nov 19, 2008
Perfect, thanks
Posted on Jan 07, 2009
Hey, I have a problem with my soundsystem Logytech Z4 and I would like to know if you can help me? The following problem occurs: The black control panel, where I can adjust the volume and bass has a...
Sounds like (no pun intended) the amplifier circuit in the speaker is bad. When you use the headphone the amplifier is not used - only the preamp. It will need repair.
Nov 25, 2010 | Logitech Z4 Speakers
My Freepulse headphone won't pair anymore. Both components charge, both both of them display the red LED light. I've tried the override button on the transmitter, and I've tried holding the power button...
You hold the button on the transmitter for about 50 seconds - light flashes red, solid red, goes off and then flashes blue and red. Then you can do the same on the headphones. Then wait and they should pair.
Jun 29, 2010 | Logitech FreePulse Wireless Consumer...
I need to install a logitech webcam but i dont have cd anymore
Go To the Logitech web site and select downloads and drivers . Follow the directions and it will ask you for your web cam model number and then it will allow you to download the drivers for your web cam.
May 13, 2010 | Logitech Webcam
Warranty
most of electronic products have not warranty if they have damage. i mean water, break. your seller is right.
May 28, 2009 | Logitech (9804090914) Consumer Headphones
Logitech internet cordless phone will not work with IE8. and logitech appears to not support the phone anymore. The internet phone program freezes when I try to load it and I have to use task manager in XP...
Hi, Sorry as Skype stopped to support this hardware since version 4, this device has been END OF LIFE and is not in use anymore. Unfortunatly unless using Internet explorer 6 and Skype v3 there is no much you can do... Thanks and have a nice day ! J-
May 02, 2009 | Logitech Cordless Internet Handset Phone
Connecting Logitech speakers to Sylvania TV
"All the audio inputs in the tv dont fit with the cable from the speakers." You would be connecting the speakers to an audio output on the TV.
Mar 18, 2017 | Sylvania LC320SS9 32 in. LCD TV
Logitech freepulse headphones not charging?
Same Problem, Headphones will charge but they wont turn on no matter what you do. Called, got them replaced, so I thought hmmm I can figure out what went wrong with the old ones.
It is the switch itself. The connection next to the charging plug does not make contact anymore. It is a weak point and after putting excessive force on the power button it actually twists the switch enough to beak the solder joint. DO NOT LIFT THE SWITCH ITSELF! Just solder the one next to the charging plug and it will be good to go.
To take them apart is a pain. Remove foam by pulling on it. Remove tiny torrx screw (CR VT-6, bit I used), then remove (actually pry up) silver "ring" at the point where the band meets the ear piece. Finally, pry apart at the band section. I used a razor blade. It is 4 tabs on the inside and is a pain, but came apart. Then take 2 screws out to remove the band and there is the board.
Solder the switch next to the light and charge plug and it is good to go.
Hope this works,
Ryan R. Gerner
Dec 17, 2008 | Logitech FreePulse Wireless Consumer...
Logitech Freepulse headphones won't turn on
There is a reset button on both the headphone and the transmitter. Try to reset them both before attempting to pair them again. Since the led won't turn on there is a possibility that the battery is not charging. Is the orange light working when the headphones are charging? It should be and then it should turn off when the battery is full.
Nov 25, 2008 | Logitech FreePulse Wireless Consumer...
When i turn on the peice that is ment go into the headphone jack it turns blue for a second and then red and stays red
i researched the logitech website and found the solution.
you must turn both parts on, but instead of letting go after 3 seconds, you keep holding until the lights start flashing red and blue on both pieces. Once BOTH pieces flash ONLY BLUE they have re-paired themselves, and they should work fine now.
http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/fattach_get.php?p_sid=kPXUPeRi&p_li=&p_accessibility=0&p_redirect=&p_tbl=9&p_id=2883&p_created=1125080596&p_olh=0
Nov 18, 2007 | Logitech Bluetooth Wireless Headphones
The peaice that goes into the headphone jack isnt working
Oct 06, 2007 | Logitech Bluetooth Wireless Headphones
Logitech FreePulse Wireless  Consumer Headphones Logo
719 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
Jerry Umali
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
