Question about Elna 1010
The thread guide under the needle screw is broken. where can I buy one? thanks, Marcia
  • Elna Master
  • 1,125 Answers
I would firstly try Elna office in your country, they should be able to either source the part or direct you to a dealer who carries it. www.elna.com then choose your country from the drop down box.
Other parts sources for various makes are www.sewingpartsonline.com, or www.sewingparts.co.uk. www.whitesewingcenter.com, specialise in Elnas, but moreso the Swiss made models from Tavaro. The 1010 looks like it isn't one of these, probably made in Japan?
Posted on May 23, 2011
The little piece of metal that is the last thing the thread goes through before it threads the needles has fallen off. Is it normally screwed on or can I safely glue it into place?
Difficult to diagnose without a machine brand and model. Is it a thread guide or the needle threader that is broken?
If the needle threader is broken, they are very fragile and are easily broken. There are moving parts associated with the needle threader so gluing may not be the best answer. However, it is not working anyway, so even if glue doesn't work, you will still be in the same position. You could take it for service, but that could be expensive.
The other alternative is to manually thread your needle--not such a big deal since that's how it's been done for 100 years... It helps to apply saliva to your finger and wipe it over the back side of the needle's eye. Then when you poke the thread toward the eye, the moisture helps draw the thread through the eye.
Aug 31, 2015 | Sewing Machines
Why does my thread get wound up on the spindle of the pfaff 230 sewing machine
Do you mean the spindle that holds the spool of thread, on the machine's top ?
If it's winding on that, chances are it's something about the spindle itself. Check that there isn't a loose washer under the spindle. If there is, check the washer for any rough spots, it may need replacing. Make sure the spindle is firmly screwed into the machine, if it screws in. If it's welded on, make sure there are no rough spots. If all that's ok. try putting a felt washer under the spool. You can b buy them but they're easy to make. Just cut a spool base size circle out of firm felt, and snip a hole in the middle just large enough to slip onto the spool. A leather punch works great for this. If it's still winding up, check the instructions, if you have them, and make sure you have the thread coming out from the spool in the right direction.Some machines are very picky about how they are threaded. For some, the thread must come from the back of the spool, for others, from the front of the spool. Try both to see if one orientation works better. And last check there is no rough spot, either on the needle or any of the thread guides. If the thread is being chafed anywhere along the thread path, excess tension may result, which can cause the thread to start winding on the spindle. Changing the needle is easy. Changing a guide may not be, but if it's a guide that's got a rough spot, see if you can remove the guide and then smooth the rough spot using some very fine sandpaper or emery cloth. The entire thread path has to be perfectly smooth for thread to move as it should.
Oct 09, 2014 | PfaFF Sewing Machines
How to guide thread on kenmore 158.13201
Most machines are very, very similar, therefore, no matter what brand you own, there's basically the same steps to follow: 1. Place good quality thread on spool pin, back right-hand side of machine and raise presser foot UP. 2.Pull thread taut from spool.Make sure silver take-up lever raised to highest position. 3. Guide thread under first tension disc. 4. Hold thread taut, guiding thread into next tension disc. When you get to the take-up leaver (silver lever on right side of machine that has a hole at the top--hold thread taut guiding it from right to left through hole, bring thread down left side of it, and put thread into tension bracket, hold thread taut! Put thread in back of needle into another small bracket and pull thread towards you. Time to thread needle: put thread front to back into eye of needle. Put thread under presser foot and pull under the center of it a good 6".Lower presser foot on scrap of fabric to test. Turn hand wheel toward you to lower needle into fabric scrap. Use foot (or knee depending on machine) to start machine. Do not pull or push fabric but gently guide it. Jimmy Place fabric scrap under needle. Low
Apr 04, 2012 | Kenmore Sewing Machines
Bobbin shuttle
1. Clean shuttle with your sewing machine brush to remove old broken threads, lint, and sweep out the feed dogs carefully. 2. Rethread making sure you have the handwheel turned toward you, all the way up. 3. Lift presser foot up BEFORE you put thread front to back in eye needle. 4. Set machine on straight stitch sewing. Attach straight stitch foot if necessary. 5. Make sure 5-6 inches of thread are pulled toward you from threaded needle. 6. Pull up bobbin thread. 7. Pull 5-6 inches of bobbin thread and put it, along with needle thread under presser foot. 8. Put fabric scrap under presser presser foot and LOWER it now. Make sure, too, that the needle is correct size for fabric you're sewing. 9. Do a test. You may need to set tension at 4, stitch length at about 4 and width at 6. Just test it and adjust tension in very, very short turns. Another tip: Put one drop of good quality sewing machine oil on the hook, lower left-hand side. Make sure when you thread bobbin in the bobbin case to hold bobbin between thumb and forefinger and pull out about 4 inches of thread after you make sure thread unwinds top left (if you are right-handed!). Guide the thread into the slot in edge of bobbin case (screw sits on top of this "edge". Pull thread under tension spring and then into the delivery eye. Never panic, my friend! Try this and see if this helps. You should probably insert new needle too--just in case "old" one bent. Jimmy
Mar 31, 2012 | Brother LS-2125 Mechanical Sewing Machine
Stitch tension problem - bobbin thread lies flat or bunches. If you increase the needle thread tension there is no improvement - even at the highest needle thread tension the bobbin thread is a mess. Any...
Good day!
please try this simple tips:
Good day!
A sewing machine operator can often help themselves when their machine does not operate properly.
Here are some simple instructions, which if properly used can save time and mechanics service calls.
TROUBLE;UPPER THREAD KEEPS BREAKING;
This could be trouble;================Do this;
1.Top tension to tight================loosen tension 1 turn
2.Machine improperly threaded=========check threading
3.Thread twisted on guide post========"
4.Thread twisted out of tension======="
5.Take up spring bent or broken=======Check action of spring
6.Thread jumped off pull off finger===Check threading
7.Needle bent or burred===============new needle
8.Bad cone of thread==================try another cone
TROUBLE;LOWER THREAD KEEPS BREAKING;
1.Bobbin tensionspring to tight=======Loosen tension slightly
2.Bobbin threaded wrong===============check threading
3.Bobbin wound to tight or uneven=====try new bobbin
4.lint or thread on bobbin case=======clean inside case
5.Lint or thread inside hook==========clean inside hook
6.Bobbin case nicked bent or burred===check/change case
TROUBLE;MACHINE STARTED SKIPPING STITCHES;
1.Needle bent or burred===============change
2.Needle set in crooked===============Check
3.Thread jumped off take up spring====check threading
4.Thread jumped off pull off finger===check threading
TROUBLE STITCHES SHOWING LOOPS;
1.Forming loops on top of cloth=======Tighten bobbin tension
======================================or loosen top tension.
2.forming loops on bottom of cloth====Tighten top tension
3.Bobbin placed in case incorrectly===remove and replace
4.Bobbin thread slipped from under====check threading of
tension===============================bobbin case
5.Lint or thread in top tension=======clean between tension discs
Thank you and good luck.
Jun 16, 2011 | Consew 7360R-1 Mechanical Sewing Machine
I bought the old White Speedlock 1634. They use 1 needle and 3 thread rolls. But the needle is broken and it is stuck inside.Can you show me what kind of needle for this machine ? How can I change a new...
I just am looking at your manual on www.singerco.com under customer support, (you can download a copy for free). It shows that you should have HA x1 or 15x1, 130/705h in other words just standard ones. Your machine is a 2 needle one, look at the manual and you will see which screw to loosen to release your broken needle. Just be patient, do not strip the threading on the screw. Go slow and if you can grab the needle with some tweezers. Reading the manual will be a tremendous help. Good luck
Jan 26, 2011 | Singer White Speedylock 1634
Need threading instruction for white sew ez plus childrens machine
Raise thread spindle by graspi G the expose s too and pulling up wears until thread spinale is fully extended, Place thread spopola on the three ad spindle. Pull thread from the thread on the thread spopola on the thread spinale and put it through the thread holder in the direction toward front of macchine. Bring thread a cross to the thread tension screw. Thread goes over the tension adjusting screw and must be position ed between the two washers beh ind. The tension adusting screw. This is what provides the lockstitch tension to the thread. Pull thread from tension adusti G screw guide through thread take up lever in the directions tovwarped front of machine. Pull thread through thread guide inserting in the direction tosare the front of the machine. pull thread down to thread guide and insert thread from the top downward. If necessary, loser the neede to reach this guide by turning the handwheelslightly counterclockwise (in the directions foward you) to loser the needle. Raise the need le to reach the eye by turning the handwheel slightly counterclockwise (toward you) insert thread through eye of the needle from the front toward the back of the machine ( use threader accessory if necessary) raise the presser foto by lifting up on the lever st the rear of machine. Pull about 10 inches of thread through the needle and lay it on the deck under the presser foot running in the directions away from you.
Feb 14, 2010 | Sewing Machines
I have a Bernette 50 sewing machine....i was sewing velcro....the screw assembly on the post where the needle goes into fell off and the thread guide fell off it....i can't tell if it is broken or just...
That can be tricky. Some thread guides and needle clamps have to be assembled and then slid up into place with the needle screw holding it together. Some have a set screw to hold it.
Jun 27, 2009 | Bernina Bernette 75
The needle holder came off the pin that holds the sewing foot in place. It appears a part is broken
Not familiar with the XL-5340 but I have an XL-6562 - mine has done the same thing. There is a small black screw that requires an allen wrench to adjust. It is on the right hand side of the needle holder. Apparently it just works loose over time and with use. My son put the holder back on, adjusted that screw with an allen wrench and it has been fine. Not sure what to tell you though about the missing thread guide. Maybe it will be ok without that - I guess try it and see.
Aug 05, 2008 | Brother XL-5340 Mechanical Sewing Machine
Sewing Machines Logo
69 people viewed this question
Top Elna Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Derek Massey
Are you an Elna Sewing Machine Expert? Answer questions, earn points and help others
