Question about Whirlpool GS6SHAXLQ 25.5 Cubic Foot Side by Side Refrigerator (White) (GS 6SHAXLQ, GS-6SHAXLQ)
When we got our refrigerator the power cord had been cut off. we are trying to replace it with a new one. we have the connectors for it. i just need a diagram for the wiring?
    Guru:
  • 683 Answers
when we got our refrigerator - walterkunesk_0.jpgOn the plug you will find three wires. wiring is pretty simple. Black to black, white to white and green to green. Hopes this helps.
Posted on May 22, 2011
Tryn to replace water valve with diff type i have 2 valves need wiring specs for tfx25ppbe
All you need is to make sure it mounts ok , the water lines fit in properly and cut the connector and wire on new female connectors that fit properly on the new valve. Just be are to insulate properly and have power cord unplugged while installing and do not cross wires.
Aug 23, 2016 | Refrigerators
After delivering ourModel # JCD2389GES JENN-AIR Side-by-Side Refrigerator it was plugged in and the power cord blew. Will replacing it work?
if this is a brand new unit , ask for a service call under warranty as the cord may not have been assembled correctly in the factory
if it is an old fridge then it is possible that the cord was cut or damaged and so an electrician will be able to fit a cord for you
Jun 25, 2015 | Jenn-Air Refrigerators
Lost power cord connector is their a way to get alternate power
It will be best to buy a new one, rather than trying to repair the damaged power cord. Some times, it might be risky. Power cords are of different types, and can be bought from most of the electronic spare part selling shops, and wont cost more. Keep the damaged power cord with you as a sample, when you to to buy a new one.
Jul 27, 2012 | Televison & Video
The wire is been cut?
If you are talking about the plug wire, you can repair it with some connectors and electrical tape, or buy a new cord at any hardware store and replace it. This is a very easy way to go.
Shastalaker7
Mar 30, 2011 | Refrigerators
I have a Whirlpool ET8GTMXK000. The refrigerator was hit accidently on the side, and it quit working. On the very bottom corner on the left back side there is a black spot where it looks as if an...
You are correct, it sounds like an electrical short happened. I am guessing when it was hit, it caused the cord to get pinched in the metal casing. The pinching must have broken the insulation on the cord and the casing is grounded...therefore, instant short. The unit probably wasn't hurt but will need to have a new cord. If you follow the now unplugged cord to the refrigerators electrical connection, it is probably either held on by crimped connectors. Cut those connectors off as close to the connectors as you can (on the opposite side of the power cord). Follow the path of the old cord and remove it from the unit. A new cord can be obtained from a local appliance store or ordered online from places like applianceparts.com. Put the new cord back in the same path the old cord was removed from. Make sure there is no sharp metal to puncture the new cord where the old cord was pinched.
Hope this helps
Jan 21, 2011 | Refrigerators
My idiot roommate cut my power cord in two and tried to pull it out of the back of the TV. Can I just replace the cord outright? If so, how do I remove the old cord. It won't come free from the TV. dj
You can probably replace the cord outright , but to do that you will have to take the tv apart and also purchase a new cord. If you still have the original cord that got cut, you can just splice it using **** connectors and it will be easier and cheaper. If you do take that route, just make sure you splice the same colors together, and use some electrical tape to re-insulate the cord. Hopefully this helped.
Thanks
Jan 03, 2011 | Toshiba 32A33 32" TV
Rabbit chewed power cord. fridge not working. Need to replace. I have the back of the fridge open, cord leads to plastic box with wires, do I simply pull the wires out and go to hardware store for...
Do not simply pull wires out of box. It sounds like they go to the control board. There should be a spot to safely unplug cord from inside the plastic box. then you can go to local appliance parts store and get replacement cord. They may sell cord at local hardware store but usually their is a specific plug in and that requires the manufactuers specific cord. In some cases it will come with the wire harmess then you can cut and splice where needed with appropriate connectors.
Oct 26, 2010 | Whirlpool Gold GR2FHMXPQ 21.6 Cu. Ft....
My power cord connection to my Acer laptop is poor. It seems that the laptop is melting the male portion of the power cord connector..What would you suggest to eliminate this problem?
This problem arises due to internal wire cut at the connector junction, simple solution : cut the powerchord and fix a new connector,
Connector is moulded, the mould can be easily cut and the same connector can be used by soldering the wires appropriately
Oct 07, 2009 | Acer Aspire 4520-5582 Notebook
Battery wont charge unless I jiggle the cord
This is due to a faulty cord or a damaged power inlet on the motherboard. Hope for your part it is the cord. Try a new power cord and if it doesn't work I'm afraid you might have to replace your motherboard...
Cheers
Sep 28, 2009 | Dell Inspiron 1521 Notebook
Power cord has been cut
Yes you can replace the entire cord, or you can splice the cord back together. Get some crimp on wire connectors get a tube of heat shrink that will fit over the cord, cut back the insulation crimp, the wires back together (match color to color). heat the shrink or tape it up. Back in business.
Jul 04, 2009 | Intex 2500 Gal Easy Set Swimming Pool...
Whirlpool GS6SHAXLQ 25.5 Cubic Foot Side by Side Refrigerator (White) (GS 6SHAXLQ, GS-6SHAXLQ) Logo
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
