Question about Lands Phones
Terraneo system 342600 error message displayed which says -- SCS2 on --
Suspect upper panel faultr,shows En9 in r/hand[speed]window at start up
DescriptionError 09 checks lower PCA memory locations during the power up test sequence. If a fault isfound during the power up test sequence, error 09 will be displayed. This error code is only usedon products utilizing the dual microprocessor system.Possible Causes1. This error message almost always indicates a lower PCA problem when it is consistentlydisplayed. Failures causing this error message to be displayed are rare.Possible Remedies1. If the error message is consistently displayed when the unit is powered up, the lower PCAshould be replaced. It is possible to see this error message displayed intermittently due toexternal causes. If the units A.C. input significantly dips during the power up test sequencethe test could fail resulting in this message being displayed. Treadmills operating onnon-dedicated A.C. circuits may see this message displayed on an intermittent basis.God bless you
Apr 03, 2013 | Avanti Fitness AT380 Treadmill
I have an everlast treadmill Jx-269e showing error e09. Any idea what to do about that please?
DescriptionError 09 checks lower PCA memory locations during the power up test sequence. If a fault isfound during the power up test sequence, error 09 will be displayed. This error code is only usedon products utilizing the dual microprocessor system.Possible Causes1. This error message almost always indicates a lower PCA problem when it is consistentlydisplayed. Failures causing this error message to be displayed are rare.Possible Remedies1. If the error message is consistently displayed when the unit is powered up, the lower PCAshould be replaced. It is possible to see this error message displayed intermittently due toexternal causes. If the units A.C. input significantly dips during the power up test sequencethe test could fail resulting in this message being displayed. Treadmills operating onnon-dedicated A.C. circuits may see this message displayed on an intermittent basis.God bless you65723e8e-6bcc-4a02-900e-e9fa117bb428.gif
Apr 03, 2013 | Exercise & Fitness
Treadmil t733 shows E9 error and soes not start
Dear Sir:
Hello I hope you are o.k
I wil give some tipoe with this Error code:
Error 09 - Lower PCA Memory Test Errors
Description
Possible Causes
Possible Remedies
Thank you in advance, sincerely. Blessing.
If you need additional Help, please reach me.
E.CUADRA
Managua, Nicaragua. C.A.
Sep 28, 2011 | Exercise & Fitness
It does not start and shows E9 error
Dear Sir:
I hope you are o.k
I will help you:
Please follow this step:
Description
Possible Causes
Possible Remedies
If you need additional Help , please reach me.
E.CUADRA
MANAGUA, NICARAGUA. C.A.
I got message "system error
Having a "System Error" message display on the camera's LCD display generally indicates a problem where the camera will need to come to Nikon for repair. A System Error is a general error which can be caused by many things: lens problem, CF Card problem, general camera failure, etc. Before sending the camera in, check these:
  1. Use the memory card that originally came with the camera (or a Nikon approved card) [/*]
  2. Remove and replace the battery [/*]
Mar 05, 2011 | Nikon Coolpix 8800 Digital Camera
Error code=403, system error code=10060. This is the message tally client displays. Tally server running successfully. Pls help. thanks
Sep 14, 2010 | Computers & Internet
I WANNA INSTALL XP2 BUT MY SYSTEM SHOWS ERROR: C000022UNKNOWN HARD ERRORSYSTEMROOTSYSTEM32NTDLL.DLL
  1. This problem may occur if the file that is described in the error message is corrupted. The following files are checked for integrity when Microsoft Windows XP starts:
  2. All driver files (except those that are loaded by the system loader to start. the computer)
  3. All dynamic-link libraries (DLLs), including User, Graphics Device Interface (GDI), Shell, Kernel, Ntdll, Crtdll, and others.
  4. This problem may occur if you install an inappropriate driver for your hardware. For example, you receive one of the error messages that are described in the "Summary" section if you install a MIPS driver on an X86-based computer.
    This problem may occur if an Iomega Zip drive is on the same integrated device electronics (IDE) cable as the hard disk drive.
  5. To resolve this problem, obtain a new copy of the corrupted file or reinstall Windows XP. If you continue to receive any one of the error messages that are described in the "Summary" section after you reinstall Windows XP, a hardware problem or a network problem may exist.
  6. This error message may be displayed in many different formats, including an error message that is displayed on a blue screen or an error message that is displayed in a dialog box. The type of format that the error message is displayed in depends on how much of the operating system was loaded when the corrupted file was detected.
Apr 11, 2009 | Microsoft Windows Vista Ultimate Edition
Editing text
Windows
» HP Scanjet Scanners Supported and not Supported in Microsoft(R) Windows XP s.gif » Resolving 'Missing MSIEXEC.EXE File is Linked to Missing Export: MSI.DLL.222' Error Message During Installation of the HP Director Software s.gif » Resolving 'Scanner not supported' or 'Unsupported operating system' Error Messages s.gif » Resolving Image Zone Install Error 1402, 1406, 1714, 1904, 1935, 2203, or Unknown Error s.gif » Error 'The System Cannot Find the File Specified' While Attempting to Install the HP Photo & Imaging Software in Windows 98, 98se, or Me s.gif » 'Cannot Install This Hardware - The Required Section Was Not Found in the INF' Error Message in Windows XP s.gif » 'Error Install Failure' Message for the hpznfx01.exe Software Module Displays on the Computer When Installing HP Image Zone s.gif » The message 'Fatal error during installation' or 'Error Install Failure' Occurs When Installing HP Image Zone s.gif » A 'Fatal Error' or 'Error_Install_Failure' Error Message Displays on the Computer When Installing the Image Zone Software s.gif » The Error Message 'Error_Install_Failure' or 'Fatal Error' Occurs when Installing Image Zone Software s.gif s.gif
Macintosh
» Mac OS: Software Driver Install Causes Error, "Interface Lib Get Component Resource Could not be Found" s.gif » 'Cannot Install This Hardware - The Required Section Was Not Found in the INF' Error Message in Windows XP s.gif » 'Scanner could not be initialized' Message Displays in Mac OS X when the All-in-One Software is Installed s.gif » Mac OS: Software Driver Install Causes Error, "Interface Lib Get Component Resource Could not be Found" s.gif s.gifs.gif
Jun 13, 2008 | HP 4570C Flatbed Scanner
Lands Phones Logo
60 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
