Question about IBM ThinkPad T30 2366 Notebook
Computer freezes constantly - has to be hard rebooted
I have had my T30 for about 5 years now. in the last year, the screen freezes periodically and the only way out is to do a hard shutdown, then turn the machine back on. I am wondering if this could be a fan problem (i.e. causing the processor to overheat) because the fan starts and stops, which I am told it is not supposed to do on this machine. Anyone else deal with this issue?
  • 320 Answers
HI it can be true if the fan stops processor overheat to prevent overheat. it should work all the time (when your pc is on ;))
Posted on Aug 15, 2008
Westinghouse LED flat screen. 2-3 years old. Started freezing up while in play and only a "hard shutdown" would allow the unit to power off and automatically reboot. Getting worse. Second problem is the...
I have a Westinghouse lcd tv myself about 5 almost 6 years old, I only had problems with the green light not coming on. The best thing to do is to open it up and replace any aging electrolytic capacitors or any bulging ones.
Oct 18, 2013 | Televison & Video
Compaq Presario CQ56 freezes
Well the best thing to do is to start testing your hardware, you could have a problem with your hard drive, or your ram, or your video card, or your usb ports or cable's. You can make diagnostic cd's easily by using these free downloadable utilities:
http://www.memtest86.com/download.html This utility is a classic and works great for testing the ram in your computer.
http://www.seagate.com/support/downloads/seatools/ This is a seagate hard drive diagnostic utility that works on all types of hard drives to test that part of your computer.
http://mikelab.kiev.ua/index_en.php?page=PROGRAMS/vmt_en This is a video card testing bootable image.
If those pass, you can disable the usb ports on your computer from your bios potentially, and or crack open your computer and disconnect them if they are connected to the motherboard with cables :)
May 14, 2012 | Compaq Presario CQ56-115DX Laptop
Should I bother trying to fix this laptop or is it time for new?
it would be cheaper to get a net book and an external hard drive you can get a good one for about 200$ and an external drive enclosure for like 20 and a used hard drive for like 30-40
Dec 17, 2009 | Acer Aspire 3000 Notebook
My laptop is freezing up soon after start up. It takes a long time for the system to initialize, it is an instant problem as it has worked perfectly up until now. When we opened the screen this morning,...
It would appear that your laptop is infected with spyware / malware.
You can verify this by answering the following: is the hard drive light constantly on after boot up? If the hard drive is constantly running, then you probably have spyware running in the background and this is causing the laptop to "freeze".
Disconnect the laptop from the Internet and see if the laptop will respond after a period of time after boot up. Spyware uses the Internet connection - removing this connection should allow the comptuer to start responding.
You will need to perform the standard procedures to remove viruses and spyware. Make sure your antivirus is up-to-date and at least install a free version of an anti-spyware removal tool. Microsoft offers Windows Defender for free, LavaSoft also offers a free version of their Ad-Aware program.
Install the anti-spyware program and run a deep scan, reboot and repeat. You will need to do this at least 4 times to clean out the "Last Known Good" restores as well as the currently running image.
Nov 18, 2009 | Toshiba Satellite PSAG0U-02D00M Notebook
Dell D600 Freezing on network detection
try a repair of the network connection (Right click it, repair) that will clear several settings that might be an issue. If no change boot to safe mode with networking, see if issue occurs in safe mode. If issue doesn't occur in safe mode, then you might try a system restore to a time period when the issue was not occurring. You can flash the BIOS to a current version if a newer version is available. You can uninstall the driver in the safe mode, reboot and re-install the driver. If the issue does not occur in the safe mode, you may also try editing the startup group of MSCONFIG to see if a driver installed there is causing an issue Last but not least, run a malware scan of the system (Malwarebytes from Download.com is highly recommeneded)
Oct 02, 2009 | Dell Latitude D600 Notebook
Imac G5
Check the Memory9RAM) on your computer.
Jul 24, 2009 | Apple (661-2795) for iMac Motherboard
Gigabyte MB Bios Freeze
It could be any number of things. Yes, it could be motherboard but it could be any piece of hardware connected to it. Detach everything except CPU, memory, cpu fan, and video (if it doesn't have onboard video). And reboot. If it does the same thing then we've narrowed it down. If it gets past the screen and says can't find bootable device (or something simillar), then start adding on one device at a time until you find the culprit that locks it up at the splash screen. Experience tells me possibly CD drive or hard drive. Good luck!
May 25, 2009 | Intel Motherboard
Freezes every time
if the clearing of cache didn't work, try to check the format of the time and date if its correct and try to detached the hard drive. use the console without the hard drive. if the console works and didn't experience any freezing on the screen. its the hard drive that has a problem. if its purchased with the console it has a 1 year warranty, but if purchased seperately it has a 90-days period of warranty. so use it =)
Oct 12, 2007 | Microsoft Xbox 360 Console
IBM ThinkPad T30 2366 Notebook Logo
248 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
