Question about Skil 921502 85 Amp Reciprocating Saw
Can i use dewalt blades in my 9215-02 - Skil 921502 85 Amp Reciprocating Saw
  • 2,176 Answers
As long as the tang is the same there should be no problem. Most reciprocating blades are universal.
Posted on May 23, 2011
I can not find my instructions for the Dewalt321 jigsaw so i therefore cannot replace a blade that fell out
Most Dewalt manuals are available here: https://servicenet.dewalt.com/Home . There are 40 Dewalt power tools with 321 in the model number. Several are jigsaws. There are two types for the DW321 (TO3PAK-2LE JIG SAW) jigsaw. Please look at the label on the jigsaw to ensure that you get the correct model and type. The direct link to the manual for the DW321 Type 1 is currently https://servicenet.dewalt.com/Products/GetDocument?docName=402086-01,DW321.pdf&productId=2841&productType=3001&documentId=24909&translatedFileName=http://documents.dewalt.com/documents/English/Instruction%20Manual/402086-01,DW321.pdf .
To change the regular blade on the DW321 type 1, unplug the power tool. To remove the blade, pull the knob on the top of the jigsaw up about 1/4". Rotate the knob counterclockwise until the clamp opens. Do not force the knob after it stops. Insert the blade making sure that the back edge of the blade fits into the support roller. Rotate the knob clockwise until it clicks and then push it down.
I hope this helps.
May 24, 2017 | Blade Saws
Dewalt 331k jig saw blade falls out
Dewalt Jig Saw
DeWalt Jig Saw MANUAL ManualsOnline com
Blade catch wears out too fast
I loved this tool when it was working but after not that much use the teeth that hold the blade under pressure no longer hold hard enough to prevent the blade from coming out. The mechanism that holds the blade has no catch hole, it uses a few serated teeth to pressure hold the blade in place. Unfortunately, once the pressure starts to lessen you can't tighten it down...
Aug 24, 2014 | Dewalt 331K 6.5 Amp Top Handle Jig-Saw
Blade stuck in dw331 blade clamp
I've been all over the internet with this because the blade clamp on my 331 is jammed as well. It turns out DeWalt has redesigned the blade clamp, I'm guessing they did this because the original design jams. Solution: call DeWalt. Tell them that you have the old and now obsolete blade clamp that is prone to jamming, and that yours is stuck making your saw worthless. Ask them to send you the new redesigned clamp that is supposed to work better. You swap out blade clamp by removing two hex head (allen) screws.
The new style blade clamp for the 331 is part number: N072135SV
*The obsolete part #: N072135, 586203-00 and 589148-00
Good luck getting DeWalt to send you the working part for free.
Jul 07, 2014 | Dewalt Saws
How to change a dewalt DW317 jigsaw Reciprocating Shaft
You will need to remove the blade holder then the 4 screws that hold the front cover on. You can go to DeWalt's service site using the link below and view or print a parts diagram which will help.
DEWALT ServiceNet
May 24, 2014 | Dewalt DW303 Heavy Duty 65 Amp...
How do you use the feeler gauge to adjust the blade on the unishear
Go to Dewalt's service website at http://servicenet.dewalt.com/ and search for your model in the find parts box. Select the 3225-10 model and there will be a manual available that describes how to set your blades.
Jan 15, 2013 | Dewalt DW8920 Blade Kit for DW892
I replaced the blade in the dewalt DW716 mitre, now the blade spins slow and trips my breaker??
Hello, W/D here.
Remove your new blade. With the hardware, bolt, washer,blade and cups off, try the saw. If it operates correctly, re-examine how the blade is installed One blade cup goes on, followed by the blade, then the other cup, followed by the washer and bolt assembly. If the cups were in the wrong order, the blade can drag against the frame of the saw, pulling too many amps, and tripping the breaker.
Here is a link to DeWalt. Enter your model # for manual download and exploded diagrams.
Best regards, --W/D--
Feb 07, 2011 | Dewalt DW716 15 Amp 12Inch DoubleBevel...
Spindle and spindle hole in blade different shapes
there is a blade clamp missing like you get on grinders that transfers drive from the motor to the blade,otherwise they are quite a nice saw
Jan 07, 2010 | Dewalt DC390K 18v Cordless Circular Saw...
Size of hole in 10inch blade for dewalt power workshop radial arm saw
The size of the hole directlly relates to the size of the blade that fits on the saw, do not change blade sizes it is dangerous and will not fit properly
Mar 10, 2009 | Dewalt Factory-Reconditioned DeWalt DW432R...
Skil 921502 85 Amp Reciprocating Saw Logo
102 people viewed this question
Top Skil Saws Experts
JOHN LAPIER
Tejodhar Atreya...
Tejodhar Atreya...
Are you a Skil Saw Expert? Answer questions, earn points and help others
