Question about Invacare Pronto M51 Power Wheelchair
My chair will only turn to the left going either front and back
    Guru:
  • 1,833 Answers
It seems like one of the motor disengaged. There are some other possibilities like
Posted on May 22, 2011
Power steering electric
If the chair wants to drive left then you have a disengaged left motor clutch lever or a left motor going bad. Then M51 will not give an error code if the clutch is disengaged. If the chair is veering left as you are driving but you are still able to turn to turn right then the motor is not likely to be disengaged but has a brush or gear problem.
It is also possible that the joystick is not working well. The joystick is much less likely to be the problem unless it is damaged somehow.
Sep 02, 2014 | Invacare Pronto M51 Power Wheelchair
My M41 invacare controller keeps flashing and it flashes 5 times. I don't understand what the fix for this.
If your M41 has the mark V controller that is seen pictured in the stock photo you provided, the 5 flash code is a left park brake fault.
1. Turn off the chair.
2.Disengage the left motor (levers are located in front under the seat) roll the chair back and forth and re-engage the left motor.
3. Engage the left motor.
4. Turn on chair.
If you happen to have the older Mark IV controller (has a toggle switch to turn on/off and three battery lights), the 5 flash code means the chair is receiving high or low voltage from the batteries. I would recommend having the batteries checked.
If the chair stops flashing, you are good to go. If the chair is still flashing, you will need to contact a technician to possibly replace the left brake. I recommend Repair Xpress FixMyPWC com Nationwide service and delivery solution for power...
Jul 15, 2014 | Electric Mobility Invacare Pronto M41...
What the lights moving right to left on jazzy select 6 power chair
If you are moving as soon as you turn on the chair, the lights will move from right to left. Try waiting a few seconds and see if the lights stop moving. If they do stop, then you can move forward. Hope this helps.
Jun 20, 2014 | Pride Jazzy Select 6 Indoor Power...
What does my tss300 power indicater keep flashing left to right but won't move. batteries are fully charged and reset is set?
The chair is more than likely in free wheel. There are two levers under front of the seat (yellow). Pulling them forward should place the chair in freewheel and pushing the levers back should place the chair in drive. Once in drive mode, turn power on to reset joystick.
Apr 27, 2014 | Pride Mobility Pride TSS300 Power Chair -...
Charger inhibit error
Hello Debbie Waters,if you contact a Wheelchair/Scooter Repair Shop.Give them what you see as to (WHY) & ask for a price on the Part.I hope this has helped,Colin.
Jan 16, 2014 | Quantum 6000 Power Chair - Used Electric...
I have a htt 9c chair. it was working yesterday. I went to use it today and it would not turn on. it has no power and circuit is fine. please help
First, check the power with a volt meter on the receptacle you are plugged into. (or plug a lamp into the receptacle and make sure it turns on. believe it or notI have seen this many times) If power is fine, then remove the back of the chair (with the cord unplugged) and stabilize the back of the chair as the wires hang from the back of the chair to the chair itself. Plug back in your chair and check power to the on/off switch on the back of the chair, if you have power there then it gets a little more complicated. Again, unplug the chair, remove the black plastic cover on the lower left of the chair that covers the main circuit board. You should see a soldered in fuse, use an ohm meter and check the fuse for continuity. If it reads good or "shorted" then you are past my knowledge in this matter. Hope I could be of some assistance.
Jun 28, 2011 | Interactive Health New Htt 9c Curve Track...
I have an Invacare Pronto M41. When you push the power button, the battery meter lights ramp up from left to right, then go off, then ramp left to right, go off, continuosly. Also, the service light is...
mad check the freewheel levers under the front of the seat on the base make sure that they are in the drive mode turn the chair on and you should be good to go. Have the power off move the levers back and forth and leave in the drive mode then turn the power on and you should see normal lights and operation Hope this helps
Apr 06, 2011 | Electric Mobility Invacare Pronto M41...
When i turn the on switch three red lights flash on the left side
glenn You have a left motor fault and the motor will have to be replaced. If Medicare paid for your chair they will pay for 80% of the repair costs. Contact Repair Express @ 877-581-3733 or Roadrunner Mobility @ 1-800-467-2668 they are both great service companies that will send a tech out to pick up your chair and leave you a loaner to use. They will bill Medicare for all repairs and get your chair back to you all ready to go You can also check with your provider to see if they will repair it for you Hope this helps
Mar 01, 2011 | Jet 3 Ultra Power Chair
The speed control light goes back and fourth on the console.
If the lights are chasing left to right then you are in inhibit mode meaning a charger is attached or there is a problem in the joystick with the inhibit functio. Right to left chasing I think means you are in freewheel. Turn the Power off and reset the levers in front on the chair then turn the power back on and hope the lights are steady and the chair will work. If this doesn't do it maybe you are in lockout mode. If you have the manual for this chair it should explain how to get out of "lockout". If not try turning the power on and within 10 seconds push the joystick straight forward and hold until you hear a beep then immediately move the joystick to the rear and hold until you hear another beep then release joystick to the center. This should get it out of "lockout" Hope this helps!!! Of course you could always call Hoveround and ask for tech support to help with this. Checkout their website for phone number Hoveround.com
Aug 19, 2010 | NRS Hoveround MPV 5 - Used Power...
How do I charge the Hoveround mpv 4? I plugged the charger into the chair and plugged the cord into the wall using an extension cord. The red light on the box turns red when in the "on" position but the...
Firstly, it is bad news to use an extension cord with the charger as it can get very hot. It will sometimes take 8-12 hours to get a full charge on the batteries. If the light does not go to green on the charger, the batteries may be damaged and not able to take a charge. This is especially true if the Power chair was stored after your father in law died; the gel in the batteries may have gone solid. The lights on the controller will go left to right then back if the charger is connected properly.
The brake release knobs both need to be in the UP/DRIVE position for the motors to engage.
Jun 22, 2010 | NRS Hoveround MPV 4 - Hovaround Used...
Invacare Pronto M51 Power Wheelchair Logo
Top Invacare Health & Beauty Experts
wcdoc1953
wcdoc1953
Colin Taylor
gnshome
Level 1 Expert
Are you an Invacare Health and Beauty Expert? Answer questions, earn points and help others
