Question about Mantis Garden
The shield over the tines has become loose. What do I need to get to reattach?
    Problem Solver:
  • 17 Answers
A ratchet wrench with the correct socket size. It should not be at all complicated to re-tighten the bolts.
Posted on May 24, 2011
Loose heat shield
Peen the shield rivets with a suitable tool which usually become loose, place plain washers under the bolts, lubricate with a drop of engine oil and tighten the bolts.
Dec 01, 2013 | 2005 Toyota Corolla
I have a Proform Smart Strider. We just assembled it & when I tested it there's a very loud scraping sound when I stride, regardless of the level or program...help, pls. Thx.
I recomend you to disassemble again, and repeat the steps. Something must be there ARE not according with the instruction assembling. Try however for to see the some loose parts, bolts, nuts, and lube.
See this small instruction.s
God bless you
Remove the screws or bolts securing the ends of the pedals to the crank axles. Slide the ends of the pedals off the axles. Remove any screws or bolts securing the left and right disc shields to the base unit. Pull or pry the disc shields off the base unit and set them aside.
Remove any screws or bolts securing the left and right side shields to the base unit. Detach the side shields and set them aside. Examine the interior of the base unit and locate the drive belt.
Pull the drive belt free of the crank pulley, flywheel and any other pulleys. Discard the old drive belt and install a new belt in its place. Turn the crank axles by hand to confirm that the belt will turn smoothly when the device is in use.
Lubrication:
Detach the ends of the pedals from the crank axles. Spread a layer of machine grease over the crank axles, then reattach the ends of the pedals.
Remove the bolts connecting the pedals to the swing arms. Detach the pedals from the arms, then spread a layer of machine grease over the axles on the swing arms. On some models, the bolts may also serve as the axles. Reattach the pedals to the arms.
Remove the bolts connecting the swing arms to the elliptical's upright. Detach the swing arms from the upright, then spread a layer of machine grease over the axles on the upright. Reattach the arms to the upright.
Oct 15, 2013 | Proform Smart Strider SpaceSaver...
Need parts for sears 917.299858 shield,tine no longer available at sears
then no longer available... need to rethink your need for this tiller
Sep 08, 2013 | Mtd Bronco Rear Tine Tiller
Hi my 1999 expedition is rattling when in reverse or at a stop light.Wish I knew what it was.
Hello, Have someone check the metal shields around the exhaust pipes and Catalytic converters. What usually happens is the shields rust off their spotwelds or pieces of gravel get kicked up on them and dance across the surface.
Check the driveshaft "U"-joints. When in reverse, the joints have Torque in the opposite direction than normal. If there is wear or slop in the joint, the part will rattle when the driveshaft turns.
Last would be loose or broken motor or transmission mounts. The engine is lifting off the mounts and rattling.
I hope it is only the shields as a muffler shop can reattach them and eliminate your noise.
Jul 28, 2011 | 1999 Ford Expedition
Rattling sound underneath when changing to a higher gear.
most likly a heat shield check and see if any are loose
Dec 30, 2009 | 2001 Acura MDX
I have a Whirlpool side by side with an ice dispenser. The little door that closes on the outside opening of the ice dispenser has come loose from its bracket. I cannot get to it to reattach it, or even...
if it has become loose, the pin that holds the disp door came be put back into place. if the plastic tab that holds the pin into place broke, you will need to have a kit installed that has a metal bracket. that should be done by a tech. hope this helps.
Oct 21, 2009 | Whirlpool Refrigerators
Need manual....for 917293401. took it apart and can not put back together
here ya go! go to this page and there is 7 blue links to choose handles,frame,transmissin,ect..each has pictures and part numbers
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?pop=true&modelNumber=917.293401
  • CRAFTSMAN
  • REAR TINE TILLER
  • Model# 917293401
Browse Subcomponents To make your search easier, we have grouped this model's parts into subcomponents. Please choose a category below to view the related parts and diagrams.
r3_placement('category_page.bottom_modelsearch'); r3_placement('category_page.bottom_modelsearch');
Aug 28, 2009 | Craftsman 8.50 Torque Rating Dual...
Craftsman 6.5 tiller model 486.252444
Not sure about this tiller but some others just need oil in the crankcase - tillers tend to lose oil because of the harsh conditions they work under. If you hear squeaking down their it might be a good idea to check it out.
Apr 19, 2009 | Craftsman Cultivating Shield
I need a mannual for a craftsman 5 h rear tine tiller
Try this website.  http://c.managemyhome.com/mmh/ You will need to register.... and go to home page... manuals.... put in Craftsman and serial number. Pdf should come up, you can download or print.
I worked for me on a mower manual that no one could track down
Hope it works for you
John Elsegood
Apr 06, 2009 | Craftsman Cultivating Shield
Craftsman tiller engine dies when I try to engage tines
tilt the back of the tiller up and check for a rock or stick wedged in between the tines and the shield
Mar 22, 2009 | Craftsman 8.50 Torque Rating Dual...
Garden Logo
136 people viewed this question
Top Mantis Garden Experts
paulfvincent
Jim Parker
Jim Parker
Mike Squire
Are you a Mantis Garden Expert? Answer questions, earn points and help others
