Question about Dryers
I have power to my dryer but when pushing the start button nothing happens
  • Dryers Master
  • 8,220 Answers
All dryers have a door switch, perhaps yours has failed. If that turns out to be fine look for air restrictions that would cause overheating. If you see some then be aware one or more of the safety's on your dryer may have tripped to prevent a dryer fire. The most obvious safety to look fo is the thermal limit mounted on the blower housing or very near where air can be quickly judged to be in excess of 350f. A dryer should never get above 160f.A high limit is mounted on the heater element if the temp rises above 250f another is mounted on the opposite end and rated for 300f. If the filter area is completely blocked the air inside the drum will rapidly exceed 350f and the thermal limit will melt. These are your safety's. A simple $10 ohm meter can help you verify which safety is blown. Unplug the dryer and set the meter to read ohms. Remove a wire and check for continuity between the safety terminals. If you can't see the needle move (on analog meter) Or get an audible beep (On digital models) then you know you have found the problem.
More Here
Posted on May 22, 2011
dididsaythat
  • 291 Answers
SOURCE: Amana Dryer
sounds like a bad motor or something stuck in blower fan.. see if you can maually turn the drier drum if so motor is bad if not something is binding up drum or blower fan.
Posted on Nov 04, 2007
Illeagle
  • 525 Answers
SOURCE: Amana dryer
Check your fuses or breaker. An electric dryer requires 240 volts to operate. In a fuse box system, 2-30 amp fuses are required for an electric dryer to operate. If 1 fuse is blown it will not start or heat depending on which fuse is blown.
In a breaker system the breaker can trip and sometimes look ok. Find your 30 amp dryer breaker and reset it by flipping the lever to off, then back on.
If this doesn't help, you may have a faulty door switch or maybe your door has loosened from the hinges and has sagged a bit, breaking contact with the door switch plunger.
If you can locate the door switch, push on the plunger... you should hear an audible click...if you do then the door switch is normally ok, but not always, it is just a simple test to rule a bad switch which is normally silent if it is faulty.
You may want to inspect for a burned wire or wire termination.
Make sure dryer is unplugged from the power source before inspecting!!!
Other than the previous instructions, it is difficult for a novice to diagnose the problem...call a technician in to fix your dryer.
1 more thing, Just because a breaker appears to be on, and/or you flipped it off then on, doesn't mean the breaker is ok. Fuses also can look good and be bad. A small volt-ohm meter($10.00) is a good investment for testing voltage, and to save time and money.
Hope this gets you up and running.
Posted on May 26, 2008
  • 603 Answers
SOURCE: Dryer won't start.
Would first check the Breaker panel Breaker and see if it is tripped. Try resetting, if it trips out immediately would call an electrician.
Posted on Mar 13, 2009
lhendrix04
  • 11 Answers
SOURCE: Kenmore electric dryer won't start
DOOR SWITCH
Posted on Apr 20, 2009
braindead56
  • 5 Answers
SOURCE: Push start and motor hums, but nothing else works.
Hey, either the belt is broke or something has happened to the tensioner pulley so remove front or rear panel & visually inspect & if belt is broken look & see if part # is still visible on belt surface & order a new belt.
Posted on May 12, 2009
Dryer will not power when you push start
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
May 25, 2010 | Whirlpool WED5300S Electric Dryer
Pushed a button but dryer does not start, can not push any other
Dryer2_bing.gif Repair ? The dryer will not start
heatman101
May 12, 2010 | Kenmore Elite HE4 Electric Dryer
Push start and nothing happens, there is power to dryer
Start button is possibly shorted out. The power goes from the wall to the start button before it goes anywhere else
Dave
Mar 29, 2010 | Amana NDE5800AY Electric Dryer
Nothing happens when I push the start button on my Gas Dryer
Three things you can check the door switch is it clicking? The thermal fuse you want to make sure there is continuity or worse case would be your motor.
Apr 02, 2009 | Whirlpool LGV4634JQ Gas Dryer
My whirlpool dryer wont start.
check the door switch and also the push to start button. Timers will advance even if the unit is not on
Mar 30, 2009 | Dryers
Maytag Dryer
are you sure the door is completely close?
if the door is not closing the door switch, nothing will happen when you press the start button.
drcool
Sep 17, 2008 | Dryers
Dryers Logo
44 people viewed this question
Top Dryers Experts
