Question about Yamaha RX-V1900 Receiver
Does the yamaha RX-V1900 have analog zone two output
  • 635 Answers
Yes your amplifier has assignable multi zone capability .You have to go into the initial setup of the amplifier and select if you want to assign any one of the amplifiers ( eg: rear back amp ) as zone 2.
Posted on May 22, 2011
I Have an Yamaha RX-V1300. Is there anything I can to allow it to pass thru 3D video signal?
No. You'll have to connect the video to your TV and then pass the audio to the receiver. 3-D pass-thru was only added to some audio receivers with HDMI outputs in about 2010. The Yamaha RX-V1300 was released at least 7 years earlier. Video monitors/TVs with 3D display were virtually unknown when this model was released. You can find the specifications for this receiver here: http://usa.yamaha.com/products/audio-visual/hifi-components/stereo-receivers/rx-v1300_black__u/ (click on the Specs tab).
I wish that I had better news for you.
Dec 01, 2014 | Yamaha RX-V1900 Receiver
How much is a FM/AM tuner replacement part for a yamaha RX-V1900. My connection are broken on current unit.
If you mean the where the aerial goes in, it will be much cheaper to replace that, then buy any board, even if they are still made.
Have a look in Maplins (uk) or Radio Shack (USA) to see if you spot something like it. It will just need soldering on!
Jun 14, 2010 | Yamaha RX-V1900 Receiver
Rx-v1900 hdmi hdtv problem
On most modern receivers you must select which signal type you want it to process.
for example on my Denon, I have to go into the on screen menu and select the input I want ie: video 1.Then tell it which signal I want it to use ie: s-video, component or HDMI input for video and then which input corresponds to the audio signal for that component ie: analog, digital, optical or hdmi.
Its complicated and a pain in the ****
Hopefully that helps call Yamaha they will usually walk you through the process while on the phone.
Feb 14, 2010 | Yamaha RX-V1900 Receiver
How do I link mt remote (rx-v1900)with my tv
OK. So did it come with instructions? If not, it is a rip-off. I suggest you contact your retailer in that case.
-K.R.
"I know what I know because I know what to do!"
Feb 07, 2010 | Yamaha RX-V1900 Receiver
Yamaha receiver RX-V663
Make sure you have an analog RCA audio cable from the source to the receiver. Digital coaxial or optical will not work for zone 2 or zone 3. By adding an analog cable it will not affect your main zone, it will always go to digital first. Hope this helps
Dec 29, 2009 | Yamaha RX-V663 Receiver
HDMI out jack physically broken on my rx-v1900. Fixable?
An audio repair shop should be able to get a replacement connector and swap it for you. I doubt that the part is available from Yamaha (and it would be pricy if it was). The connector shouldbe available generically. Digikey or Mouser should be a good source.
Dan
Nov 18, 2009 | Yamaha RX-V1900 Receiver
I have a Yamaha RX-V1400. Can no longer select ZONE 2
check the setup menu in the receiver to reset the outputs for zone use instead of 7.1 use
Oct 17, 2009 | Yamaha Audio Players & Recorders
Hi where can i downlowd a manual for the rx-v1900
I would start at the www.yamaha.com web site's support page. Find a Support page, and then look for Downloads. Be prepared to enter specific info about your device, like model number, serial number, etc.
If that fails, enter something like: yamaha rx-v1900 user manual in Google and you should see many different references to it. Spend a few minutes browsing the most likely places by reading the headings.
Aug 21, 2009 | Yamaha RX-V1900 Receiver
Yamaha rx v1800 receiever will only play tuner on zone 2 speakers
Solution on page 111 of the owner's manual:
"Connect the source component to the analog audio input jacks of this unit to play back the source in Zone 2 or Zone 3.
This unit does not output the audio signals input at the DIGITAL INPUT and HDMI jacks to the ZONE OUT jacks."
Basically you cannot use an HDMI input if you want to play in Zone 2 or 3. A simple solution is to add an extra audio cable from your PS3 audio output jack to an analog audio input jack on the receiver.
Feb 22, 2009 | Yamaha RX-V1800
Zone2 problem
I had the same problem.  Yamaha's web-site states that the zone 2 and zone 3 can only be driven from analog inputs (RCA stereo input jacks), not digital inputs.  If your media center is hooked up with digital connections (such as HDMI), it will not feed the zone 2 or 3.  Yamaha's web-site suggest hooking up both analog and digital feeds.  It claims that the digital will drive the main zone and the analog will drive the other zones.
Good luck...
May 25, 2008 | Yamaha RX-V2700 Receiver
Yamaha RX-V1900 Receiver Logo
115 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
