Question about Dryers
I HAVE A MAYTAG LSE1000 WHICH WORKS WELL BUT NOT DRY CLOTHES
  • Dryers Master
  • 43,501 Answers
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Posted on May 26, 2011
I need color coded wiring diagram for maytag combo model # lse8500ace
Double Check Model Number. Can't find anything with that model. Have LSE1000 and LSE7806 which are stacked Washer and Dryer
Nov 18, 2015 | Maytag Dryers
What does my Maytag Bravos 300 quite series electric dryer take so long to dry clothes?
Those sensor bars can become faulty and that is probably the problem. Try cleaning them off with a clean rag. Good Luck!
Sep 08, 2014 | Maytag Dryers
My maytag gas dryer work on dry cloth and stays hot but as soon as i put wet cloths in it they wont dry ?
My dryers timer wouldn't work correctly and the clothes were taking forever to dry. I decided to check the vent. My advice....Always check your dryer vent before spending any money on unnecessary parts or service calls. This Nest was pulled out of my vent with my shop vac sucking out and my house vac blowing out from inside. It finally broke free and now my dryer works like new.
Sep 24, 2011 | Maytag Atlantis MDG7400AW Gas Dryer
Hi, Have a Maytag LSE1000 stackable w/d. Has worked flawlessly for years. Now the washer will not drain and shuts off after wash cycle leaving the unit full of water/laundry. Can you give me an idea where...
Hello
Washer not draining completely is caused due to clogs/blockages in the drain hose. You can start by checking the drain hose and clean the drain pump filter of any foreign particles. Please get back to me if you have any other questions.
Kevin
Nov 09, 2010 | Maytag Washing Machines
Model LSE1000 - The washer is getting old and not spinning the clothes as dry as it used too. Am I looking at replacing belts, pumps or cleaning out something that may be causing this problem. The washer...
NEED TO KNOW NAME BRAIND IF WHILPOOL HOW OLD IF MAYTAG REPLACE BELT SAME WITH GE WITH WHILPOOL NEED MOR INFO TO HELP LIKE IS IT SPINING AT ALL OR SLOW IF SLOW MAY BE YOUR CLUTCH OR DRIVE BLOCK IF NOT AT ALL WILL IT AGITAT IF NOT DRIVE COUPLER IN BETREEN PUMP AND MOTOR
Apr 03, 2010 | Washing Machines
Brand new Maytag Centennial electric dryer does not dry clothes!
It may have shipping damage, such as a loose or broken connection or heating element.
But if it's brand new, it's under warranty, and they will fix it free.
You can find your nearest Maytag-authorized servicer here.
Jan 09, 2010 | Maytag Appliances Over-the-Range Microwave...
Maytag gas dryer wont turn off when done drying in auto dry regular fabrics. does turn off in air fluff and auto dry perm. press. model # d3382
auto dry relies on a moisture sensor to say when its done. so your clothes arent dry enough according to sensor. perm. press. doesnt dry the clothes as much
Aug 01, 2009 | Dryers
The gas maytag neptune intellidry gas dryer does not dry clothes. It does not have enough heat. It will take about 5 cycles to dry 1 load.
how do i set this dryer to dry my clothes??? what is the right setting?? should i use the time dry setting or the more dry/less dry setting?? Clothes never dry???????????????????????????????????????????????????????
Jun 28, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Dryers Logo
91 people viewed this question
Top Dryers Experts
