Question about Navman GPS
Navman f25 only shows screen with usb connector sign. Won't do anything
5 Suggested Answers
  • 135 Answers
SOURCE: Screen is showing computer, usb
The F20 Desktop Software and Service pack on the CD's from navman do not work, as you have seen. The solution is to go to the navman website and download this Service Pack
Be sure your f20 is connected to the USB cable and turned on displaying the USB Connection screen. Leave it on during the entire process.
Once downloaded, run this self extracting file and let it install automatically. After it is installed and ran.....you will see the same error again of failure to connect.
At this point you must reinstall the driver manually. Right click on your "My Computer icon, Select Devices, then properties on the navman. You should see a yellow "?" next to a statement "Unknown Device" in the USB devices. Click on the "Reinstall Driver" and select a specific location or the Have Disk button. The USB driver is now located in C:\program files\Navman\f20servicepack\USB directory.
You should get a button that now says Okay at the bottom, click onto it and allow the MS program to update the drivers. You should see the device screen change and say "This device is operating properly". You can then close the windows and run the F20 desktop program. It should connect then.
Posted on Jul 06, 2008
SOURCE: F-10 navman showing a screen
I need to find a software download to install my navman f10
Posted on Sep 07, 2008
  • 240 Answers
SOURCE: cannot get screen to switch on only shows my pc
It will not come on until it is disconnected from your pc. This is normal.
Posted on Oct 03, 2009
  • 1139 Answers
SOURCE: Navman model no N197 -
This is sometimes caused by corrupted files on the flash disk. What I would advise doing is to restore the backup folder on the flash disk and try and start the device again.
Hope this helps and thank you for using FixYa
Posted on Aug 31, 2010
Navman is stuck on usb screen
This is caused by the battery charger and USB combo connector port being damaged (bent pin), you will need to either have the connector in the GPS replaced or replace the GPS.
May 12, 2011 | GPS
Screen is showing computer, usb connection, navman which are joined together by a serious of dots with the computer screen to usb connection showing green lights
Jul 06, 2008 | Navman GPS
Navman My50T - screen has frozen, can't get any other screen apart from initial start-up screen (except for screen showing connected to computer when connected by usb).
Had a similar problem with a MY60T.
Spoke to Navman support.
1. Connect your unit to the computer.
2. Use windows explorer to go to the Navman folder
3. Go to the database folder.
4. Delete "Database.db"
5. Switch off & re-start you unit. The databse file is re-created on startup
Dec 24, 2010 | GPS
Ineed a manual for a F15
http://www.navman.com/docs/manuals/navman-f15-f25-manual-en_us.pdf
There is a 70 page manual. Not that its much help if the satelite signal doesn't kick in.
Nov 25, 2009 | Televison & Video
I hvave a Navman F15 and don't know if the maps can be upgrated as i did not receive any cords for this
As Navman Support told me there is officially NO SOFTWARE UPGRADE, NO OTHER MAP and NO COMPATIBILITY WITH OTHER NAVMAN PRODUCTS.... Because F15 is an SPECIAL OFFER for beginners... oh God.... I aquired my F15 in RadioShack.... Will try some inofficial methods.
John
Nov 10, 2008 | GPS
Navman F10 wont function shows sat nav connecting to computer on screen
Try holding down on/off button till screen clears,switch back on and it should be working normally,this worked on mine,it had picture of laptop ,navman usb cable and a red cross,hope this helps.Cheers.
Jun 10, 2008 | Navman F20 GPS Receiver
Navman f10
i was in car,using navmanf10, went blank and a comput screen connect to unit appeared, cannot do anything with it
pamelathanson@aol.com
Dec 28, 2007 | Navman Tracker 5500i GPS Receiver
GPS Logo
133 people viewed this question
Top Navman GPS Experts
Martin Murray
Are you a Navman GPS Expert? Answer questions, earn points and help others
