Question about Refrigerators
Emerson cr500 freezer works but refrigerator doesn't get cold
  • 4 Answers
SOURCE: refrigerator does seem like its working right
Your refrigerator compressor is either pumping or it is not. Set the refrigerator to low temperature, pull it out and listen for a while to see it the compressor is coming on. If it is coming on then there may be a freon leak or the internal coils may be iced up. If it is not coming on, then either there is no power to the coompressor, or the compressor itself is defective. Use a voltmeter at the compressor to check for voltage. There is also an add on device to start stuck compressors from your local HIVAC jobber store.
Posted on Jun 07, 2010
taran_2005
  • 10515 Answers
SOURCE: Emerson CR500 3.1 cubic ft
This is more suggestive of either bad compressor or bad compressor relay. Compressor's usually have 5 years warranty.
If you have experience in repairing appliances, could take all precautions necessary and use multimeter - You could do a continuity check on compressor motor and all combination's. An infinity value on multimeter would confirm bad compressor.
On the side of the compressor you will see a box (maybe a cover) remove the cover if it has one and then remove the wire harness. next you will see the relay with the capacitor mounted to it. give the relay a tug and pull it off the side of the compressor. once you have it off pull the capacitor off and then give the relay a shake. If it rattles the relay is bad. if the relay does not rattle the compressor is bad and you will need to call a service guy to replace the compressor.
Other option would be - Go to a local repair shop and get an overload and relay ( cost around $50 ).Replace it. If the problem still persists, then it is faulty compressor.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Aug 22, 2010
SOURCE: My daughter's Emerson CR500 compact refrigerator
My husband and I bought this same refrigerator around 11/2009 and it doesn't work now either. We too bought this refrigerator at a local target. Yikes. We bought ours for our daughters dorm room and it didn't stay working even one year. Is that how Emerson told you to handle it - by shipping that stupid thing to CA. Thats ridiculous.
Posted on Sep 02, 2010
  • 86 Answers
SOURCE: freezer works but refrigerator doesn`t get cold
Check the back panel on the freezer compartment , is it all icing up or frosting up on the panel. If it is then your defrost cycle is in trouble, and that may be the defrost timer , the defrost elements or the thermodice. I normally change all these items at one go since I'm opening up the compartment and they are not that expensive and I know I'll have a no call back on this defrost cycle situation. Hope this can help.
Posted on Oct 06, 2010
heatman101
  • 43501 Answers
SOURCE: Freezer works, it's cool nolt cold in the
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Dec 27, 2010
Emerson compact fridge with freezer compartment freezer is very cold fridge nothing just warm is there any fan to blow air>> thanks
Your freezer fan unit may be frozen behind the inside wall and therefore not circulating the cold air down.
Se if you can remove the screws and back wall to check the fan unit.
Not all modeles can be repaired this way
Jun 04, 2016 | Emerson Cr500 Refrigerators & Freezers
Emerson CR500: freezer is cold; refrig is not
If your refrigerator freezer compartment is cold, but the refrigerator compartment is warm--It could be a defrost system problem. When a defrost problem occurs, it is usually the fault of one or more of three basic parts: defrost timer/adaptive defrost control, freezer thermostat or the defrost heater element. See in detail how to dx and fix: Refrigerator Defrost Parts .
Aug 24, 2014 | Emerson Cr500 Refrigerators & Freezers
What could the problem be; my refrigerator not cold but the freezer is freezing?
If your refrigerator freezer compartment is cold, but the refrigerator compartment is warm--It could be a defrost problem. When a defrost problem occurs, it is usually the fault of one or more of three basic parts: defrost timer/adaptive defrost control, freezer thermostat or the defrost heater element. See in detail with illustrations how to dx and fix: Refrigerator Defrost Parts
Jul 31, 2014 | Emerson Cr500 Refrigerators & Freezers
Freezer works/ refridgerator doesn't cool
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Aug 21, 2011 | Refrigerators
Freezer works great but refrigerator. Doesn't get cold its cool but not cold turned thermostat to 33 and ut isn't gettingcold
heatman101
Aug 21, 2011 | Kenmore Side by Side Refrigerator
Freezer is cold enough but refrigerator doesn't get to temp. Any ideas?
heatman101
Aug 12, 2011 | Danby DFF8802 Top Freezer Refrigerator
Freezer works fine but fridge doesn't get to cold any more
heatman101
Jul 31, 2011 | GE Refrigerators
Freezer and Refrigerator are not cold enough. Freezer barely keeps things cold and fridge doesn't keep cold at all.
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Jul 07, 2011 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Freezer work great but the refridgirator doesn't get cold.
heatman101
Jul 06, 2011 | Refrigerators
My daughter's Emerson CR500 compact refrigerator completely stopped getting cold about four months after we purchased it. It would cost me $57 to ship it to CA to have it fixed, so I'm wondering if it...
Aug 17, 2009 | Emerson Refrigerators
Refrigerators Logo
163 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
