Question about Sony VAIO VPCEA36FM/W Laptop
I have no sound and the realtec audio driver is not showing up in my device manager. I've tried everything..help
  • 175 Answers
Hello!
first uinstalle realtec audio driver then follow this
all what You need a driver
here is a web site that let's you to scan your
computer and then automatically display different compatible drivers , you will find out the compatible driver sound
http://www.touslesdrivers.com/index.php?v_page=29
good luck
Posted on May 22, 2011
    Master:
  • 752 Answers
It isn't showing up because it doesn't belong ther. Vaio.com/support/drivers/download and get the right one.
Microphone Problem MSI / Realtek
disable your internal mic, go to start--type computer management--go to drivers-- sounds and audio-- right click, and disable the one you dont use.
Jun 18, 2013 | MSI Microstar GE60 0ND-257US 15.6" Gaming...
Can't find correct driver for multi media audio controller using XP.
http://download.cnet.com/%7Bvalue=http://www.download.com/jetway-motherboard-driver/3000-2098_4-163033.html or http://download.cnet.com/%7Bvalue=http://www.download.com/motherboard-driver-audio-via/3000-2110_4-130898.html This package supports the following driver models:
  • Vinyl AC'97 Codec Combo Driver (WDM)
  • VIA AC'97 Enhanced Audio controller
  • VIA Sound System
  • VIA internal FM Synthesis
  • VIA PCI Audio controller
  • VIA MIDI External Port
  • VIA Gameport Joystick
Mar 01, 2013 | Computers & Internet
How do I Reinstall the internernal soundcard on my Dell Vistro 200 without a installation disk
Control panel - device manager - check the audio section and see if there is a red x anywhere. This should indicate if there is a problem. If you're certain that the driver showing here is wrong, you should be able to google the driver you need and replace the one in use.
Nov 14, 2012 | Dell Vostro 200 Desktop Computer
No sound, drivers can't be found
right click on the red X icon select playback devices there will be a red x on the speakers right click configure them
hope this helps
Jun 27, 2012 | Gateway Computers & Internet
How do I diagnose and fix my laptop's sound problem? Should I just throw it out the window?
which operating system
You receive an error that states: There might be a problem with your audio device
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrative tools computer management device manager scroll to sound video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to
reinstall drivers
click start control panel sounds and audio volume advanced speakers make sure you have selected the
(appropriate speakers) also audio you will find 3 drop down lists make sure you have selected the correct speaker settings there
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
if his does not fix the problem
click start control panel sounds and audio devices you can adjust the volume there also select speaker
volume you can change your settings there you can also tick in the box place icon in taskbar for any
further volume control settings you will need to right click on the speaker volume icon system select adjust volume
click start control panel sounds and audio volume advanced speakers select the appropriate speakers
from the drop down list or navigate to the device manager scroll to system devices + to expand system
speaker right click properties then select use this device (enable) also you might check
the speaker plug/outlets is usually at the back of the computer or if its a laptop on the side
you will have to open up the computer to check the lead attached to the rear of the input plug make
sure the connection is good with no dust as dust causes static electricity
clean your computer of dust using a fine air blower from a compressor making VERY sure that there is
no MOISTURE in the air line specifically around the sound card and the CPU central processing unit
dust causes static to build up in a computer
hope this helps
Jun 26, 2012 | Fujitsu Siemens Amilo Pi2515 Laptop...
Audio
so it does not appear in device manager eh?
well that only has one simple answer
either the device chip is shot OR the wiring to that device is unhappy
i just looked into this hp page and there appears to be something missing on the product specifications can you see a conextant audio card on this list? click here for that specification page
May 23, 2012 | Computers & Internet
Have only realtec audia manager but can find my normal volume botton anymore on my home pc
Hi Tania,
This problem is a 'bug' in Windows XP operating system.
Follow these steps to restore your volume button:
  • Click on 'start' & select 'Control panel' from the menu.
  • Look for the icon named 'sound' in your control panel & click on this icon to open sound properties.
  • Look for the check box with the words: "Show volume control in task bar"
  • Remove the check from the check box & click on the "apply" button at the bottom right of the properties window.
  • Now click on the check box once more to add the check once again.
  • Apply the change by clicking "Ok" at the bottom of the properties window.
Your volume control should now be visible once again in your task bar.
Don't hesitate to respond should you have any further queries.
Best wishes,
Graemevm
May 28, 2011 | Microsoft Windows XP Home Edition
After formatting, I installed my XP OS to my Fujitsu FMV 820gm laptop, everything is ok except the sound, I search for the sound driver , I tried to install the Realtec AC 97 driver but it display BLUE...
Go here http://www.fmworld.net/globalpc/download/ and pick what region you live in then choose the model of laptop you have. Then look for the driver for the sound card for xp. You can look in device manager to see which sound chip you have on the motherboard. You will need to get the right driver for xp in order for it to work properly. Uninstall the driver you have now that is causing the bluescreen. You can disable the sound card and let it detect it when it reboots - after you've gotten the right sound driver for xp to install. Then install the new driver and it should work.
May 28, 2011 | Computers & Internet
I just bought my dell laptop less than three months ago and the sound is not working anymore. how do i fix this? It is not on mute. the volume it up. I've checked everything. I've restarted the...
Hi whitco0313,
A corrupted or missing audio driver can cause this problem. You can try to do a System restore back to the earliest date that it worked fine. If this doesn't help, you need to check out Dell website and download the audio driver compatible for your laptop model and operating system version.
I hope this helps, please inform me if this resolves your problem or not to check for other resolution that we could try. Thank you.
May 12, 2011 | Dell Computers & Internet
Dell computer with no sound
you must check in your BIOS (when start up press del) and see if your settings whit sound card is ok,you have options to make onbord sound card after removed pci sound card
Jul 14, 2009 | Computers & Internet
Sony VAIO VPCEA36FM/W Laptop Logo
141 people viewed this question
Top Sony Computers & Internet Experts
Martin Murray
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
