Question about Kenmore Elite 45986 Front Load Washer
I have a kenmore elite he 3 front load washer...im getting f error 02. it runs fine until the end of the cycle will not drain or spin.
  • Kenmore Master
  • 1,902 Answers
Hello & Welcome to FixYa
F02 is a drain error in your Kenmore washer, if the unit is unable to drain then after 4 minutes it will display suds and then F02. The first thing that should be done is cleaning the drain hose and the drain pump filter, you can take out three torx screws from the bottom front panel and then clean the area completely, lift up the cap to clean the filter. If the error returns then check the drain pump if it is not working then replacing the pump is recommended repair. Please get back to me if you have any other questions.
Kevin
Posted on Dec 12, 2011
How-To Unlock The Controls For A Whirlpool Duet washer
I have unplugged the machine and plugged it back in and restarted, just like when a computer needs to be reset/cold boot.
Jul 03, 2015 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore elite washer sm 9711034, washer will not go through spin cycle at end of wash cycle
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Feb 19, 2011 | Kenmore Washing Machines
Stops washing cycle without draining and spinning: gives error code F 02
"F02" is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a "SUDS" error may also be generated as a secondary error. This is an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1. Check the drain hose to make sure it is not kinked or clogged.
2. Check the electrical connections to the pump and ensure the pump is running.
3. Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions.
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Apr 20, 2009 | Kenmore Elite 45986 Front Load Washer
Washer won't spin- flashing "f 02"
in the HE3 series it means the drain tube or pump is clogged
Mar 02, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite HE4t washer won't spin
The motor controller board is likely bad.
Jan 06, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite Washer
Try this first.
Washer won't drain or spin
Is the drain hose clogged, or the end of the drain hose
more than 96" (2.4
m) above the floor?
Is your voltage low?
Check electrical source or call electrician. Do not use an
extension cord.
Is the "SUD" routine active?
Cycle will complete once extra suds are removed.
Is the load balanced?
A single or bulky item may cause imbalance. Add more items
or redistribute the load.
Dec 16, 2008 | Kenmore Elite 45986 Front Load Washer
Spinning and draining does not work, F error or sometimes Sud
Sud means you using to much soap and the f code means soap is locking the drain pump up and wont allow unit to drain and spin.
Nov 22, 2008 | Kenmore Elite 45986 Front Load Washer
HELP!!
We've had this problem for about a yr when i finally firgured out how to correct it.
the problem is that the circuit board is attached to the washer, when it starts to shake it causes the connections to loosen and theats the fault code you get.
How I fixed this was to suspend the circuit from a bungie strap this will allow the washer to shake all it wants and the circuit board is stable, connections stay tight andwasher works fine, after 6 months not one error code at all
Aug 24, 2008 | Kenmore Elite 45986 Front Load Washer
F 11 Error Code
The door will stay locked if the machine did not drain properly. Try running a Drain & Spin cycle.
Mar 17, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
75 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
