Question about Kohler Plumbing
I have a Kohler kitchen faucet, model# K10416CP that is leaking around the bottom of the center ring just above the spout. It leaks very bad when we change the position of the spout. Can we fix this ourselves?
    President:
  • 3,074 Answers
Yes, remove the nut and lift the faucet up and out, you will see a rubber washer/o-ring that is like chewed up, at any home improvement center,hardware store or even a discount in there plumbing section they have faucet repair kits. Either take the old piece or the faucet and match it up, then reinstall and it will all be good. Good Luck Tim
Posted on May 22, 2011
  • 1 more comment
  • michellesdai May 22, 2011
    Tim, am I removing the entire faucet from the sink or does that center ring unscrew opening just the leaky area?
  • Tim Whalen May 22, 2011
    there should be a nut, it has grooves on the bottom of the spigot where it connects to the base, I believe it is righty tightly lefty loosely. you need not remove the whole faucet.
  • michellesdai May 23, 2011
    Thanks Tim, we will give it a try!
How do l fix our leaky kitchen faucet
If its leaking from the base of the spout where its attached to the body, its most likely the O rings that need replacing. The spout body could also be leaking as the metal is quite thin and can develop pin holes under the bottom face of the spout. To determine it that's the problem, turn the water on, place your hand under the spout body, you should not get any water spray, if you do (its usually a fine mist so its hard to see, but you will feel it) the spout is bad, replace it.
Jul 27, 2014 | Belle Foret Kitchen Kitchen Faucet With...
Need to replace O Ring but cant pull the spout off
there might be a allan screw holding it down usually located at the back of the faucet if not there is a chance that there is a screw on escutcheon just above the base of the spout this should screw off with a strap wrench.
Aug 24, 2012 | Moen Monticello Single-Handle Kitchen...
7700 series Moen leaks at top and bottom of base hub
You can just replace the o-rings. You have to remove the large nut at the base of the spout. I posted a blog post -and a video about me replacing mine.
http://blog.trebacz.com/2012/12/how-to-fix-leaking-moen-kitchen-faucet.html
The replacement o-ring and retainer parts were free to me. Hope it helps you.
Aug 17, 2011 | Moen Monticello Single-Handle Kitchen...
Our American Standard kitchen faucet has become hard to swing from one side of the sink to the other. What could be causing this? Is there a bad part?
Hi! If there are no leaks from around the spout, you can remove the spout and apply silicone lube to the spout o-rings and resemble. If it is still hard to move ,replace the o-rings.
Jul 15, 2011 | American Standard 4205.001.021 Reliant+...
Upper O rings leak. How do I take the units apart to get at these rings on the handles and on the spout?
handles are secured with small allan screw in back.then the escutcheon unscrews,then valve stem unscrews,use a little plumbers grease when reassembling.spout collar un screws might be really tight, then wiggle wiggle spout while pulling up.grease o rings when reassembling.
Jan 28, 2011 | Kohler K-16109-4-CP Revival Kitchen Sink...
Moen 7700 leaking at base of faucet. how do you get to o-rings
Here's a link to show you how to get the spout off using "strap wrenches" The allow you to get the nut off at the base of the faucet spout without harming the chrome finish.
There is also a video at the bottom of the blog post showing how I did it.
Oct 17, 2010 | Moen Monticello Single-Handle Kitchen...
Moen kitchen faucet model 7430 leak
cartridge does not stop that type of leak. If it is leaking from around the base of the spout it is o-rings that are the problem that are onthe valve after you pull the spout all the way off.
Oct 17, 2009 | Moen 87530 Touch Control Single Handle...
I have a moen pull out kitchen faucet that leaks
You have a bad internal o-ring or the sprayer o-ring is leaking, if you look under the sink turn it off and then turn it back on, if you see it leaking out the center shft where the water pipes go into then the faucet may have a broken pipe or loose pipe. check and tell me where it's leaking at. You can buy kits to repiar them they are inexpensive.
Aug 30, 2009 | Moen 87555C Trianna Single Handle Pulldown...
Unable to pull spout to replace O'Ring in Kohler Faucet F10416
They just pull out, sometimes things get stuck and I cant get them lose as a plumber and you just have to buy a new one...dont feel bad
Jan 31, 2009 | Kohler K-10416-BN Fort½ Single Control...
Plumbing Logo
243 people viewed this question
Top Kohler Plumbing Experts
Mike
Donni Steen
Are you a Kohler Plumbing Expert? Answer questions, earn points and help others
