Question about Sharp AL-1217 Copier
Replacing Drum Catridge
I want to know the steps involved in replacing AL-1217 Drum Catridge
  • 103 Answers
Hello, Here are the steps involved in replacing the drum assembly as copied from a users manual:
The useful life of the drum cartridge is approximately 18,000 copies. When the internal counter reaches approximately 17,000 copies, the drum replacement required indicator will light up indicating that replacement of the drum cartridge will be needed soon. When the indicator begins to blink, the unit will stop operating until the cartridge is replaced. Replace the drum cartridge at this time.
1 Remove the TD cartridge (Toner Cartridge). Hold the drum cartridge handle and
gently pull the cartridge out. Dispose of the old drum cartridge in accordance with local regulations.
3 Remove the new drum cartridge from the protective bag and remove the protective cover from the cartridge. Then gently install the new drum cartridge.
When closing the covers, be sure to close the front cover securely and then close the side cover. If the covers are closed in the wrong order, the covers may be damaged. Do not remove the protective cover on the drum portion (black paper) of
a new drum cartridge before use. The cover protects the drum against external light.
Do not touch the surface of the drum (green portion) of the cartridge. Doing so may cause smudges on the copies.
4 Gently install the TD cartridge. Close the front cover and then the side cover by pressing the round projections near the side cover open button. The drum
replacement required indicator will go out and the start indicator will light up.
Posted on Dec 11, 2008
Pls sir i want to know how to clear H4 AL 1217
Dec 16, 2010 | Sharp AL-1217 Copier
Recently replaced drum cartridge on our Sharp AL-1217 photocopier and copies are now coming out smeared with toner. I have done what I can to clean the parts.
First of all, remove both toner cartridge and drum unit. Wipe the space they occupied with a clean cloth till you see its clean. Wipe also the upper part where the laser unit is, that is the place you will see a small glass-like strip above where the drum fits, till clean. Check that the paper tray is not dirty with toner and if it is , wipe it clean. Slowly turn the semi-circular feed rollers while wiping with damp clean cloth till clean. Then check that you replaced a new drum and blade and that the main charger above the drum is clean. Also check that the drum seal blade , that small nylon paper-like seal is not broken , and if broken reinforce with a clear cello-tape. Then, re-insert your cartridges back into the machine and a very clear copy will come out. Please try and you won't fail.
Nov 23, 2010 | Sharp AL-1217 Copier
Old model AL-1217 photocopier giving error reading of L? Any thoughts, tried everything! Thanks
L1 mean scanner is not goes home position,
Solve: Clean all surface then solve your problem
Feb 06, 2010 | Sharp AL-1217 Copier
Replaced drum cartriddge on model AL-1661CS and still has error reading to replace cartridge
After replacing drum catridge you should reset the drum counter in the following way
1.Identify the buttons used for adjusting exposure (darker or lighter copies), amount of copies, clear copies and start copying
2.Now press the following sequence of buttons: [CLR], [AURO], [CLR], [AUTO] all thes one by one
3.Your unit should turn off the numbers in the panel
4.Now press 24 as if asking for 24 copies and press [START].
4.Now press 07 as if asking for 7 copies and press [START].
This should reset your drum and it should stop flashing
Sep 15, 2009 | Sharp Office Equipment & Supplies
Sharp AL-1217 Driver for Windows Vista
try the driver for AR123E at
it covers
Supported Models AR-123E, AL1045, AL1216, AL1225, AL1255, AL1530CS, AL1540CS, AL1456
Aug 21, 2009 | Sharp AL-1217 Copier
AL 1217 noise when started
hi first u check with out drum and toner unit. that time also u getting noise u check main drive assembly and fuser assembly.
Jun 24, 2008 | Sharp AL-1217 Copier
Sharp al1217
I've never seen this model in Australia but could you confirm if its drum or toner either way its just the machine letting you know that it needs changing soon, however we have other models that do the same and run for quite a while before the quality drops off
Mar 18, 2008 | Sharp AL-1217 Copier
1,191 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
