Question about Zanussi TC7102W Electric Dryer
Over the last 3 weeks, there has been little water in the collector although I have used the dryer every day. Previously, I had to empty the water in the collector every week. I have pulled the machine out and cannot see any kind of leak from the machine. Can you help?
    President:
  • 3,074 Answers
The drain hose/hole is probably becoming clogged, clean out and it should be all good. Tim
Posted on May 22, 2011
My steam iron has calcified outlets although have regularly emptied the machine through the outlet, therefore not working properly
its a great iron no argument there
de scaling products can only do so much
even if using demin water or filtered water
they dont last forever
Nov 09, 2016 | Tefal Irons
It says the water needs emptying but it is empty
After reading about various dryer problems / solutions it seems others have had this same problem. It could be that a smaller resevoir which houses the sensor connected to the water collector is full and it's valve may be blocked with lint. It can be solved by getting to the valve and removing the lint. You may need to remove the valve itself. Hope that helps. Good luck.
Oct 20, 2012 | Candy CDC266 Dryer
I have a side-by side refrigerator/freezer with the water and ice dispenser in the door of the freezer--model # GS5VHAXWY00. For the third time within a year and a half the water dispenser does not work. ...
I would suggest that this is a design fault and the manufacturer should rectify the problem, you may have to go direct to the manufacturer to get some real help
Mar 24, 2011 | Whirlpool GS6NBEXR Side by Side...
No water accumulating
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
Dehumidifier is running but no water is in bucket
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
May 06, 2010 | LG LHD45EL Dehumidifier
My dryer is drying cltohes properly and the water collector is empty. What is the problem?
david, no dryer unless a special one made for campers collect water please if possible discribe you problem or question what you think the water collector is to us techs/fixers then maybe it just something not identified properly
Sep 03, 2009 | Hotpoint Dryers
Zanussi TC 7114 W Condenser dryer leaking water
Maybe it's the water collector's upper side which leaks...
Apr 15, 2009 | Zanussi TC7114W Electric Dryer
Hoover Vision HD VHC391 saying it is full of water
My son seems to have fixed my dryer.
Although I followed the instructions about cleaning the filter after each cycle and the condenser after ten, fluff had blocked the drainage from the internal reservoir to the water collection bottle. It seems like this will be an ongoing problem, as even cleaning every time, fluff will gradually biuld up. The filter isn't good enough to stop fibres getting into the condenser and then into the reservoir behind it.
I expect that taking the cover off the reservoir to clean it invallidates a guarantee if you have one, but that is what my son did and now the dryer is working.
Jan 12, 2009 | Hoover HDV7FM Electric Dryer
Water dripping outside the collector
I think that there is a 90 degree bend in the outlet on the bottom right front side of the collection tray that gets pluged with dirt, line etc. You can see this when you remove the collection container from the unit. I used a small piece of wire to clean out the hole and now the water goes into the tank and not onto the floor.
Aug 24, 2008 | LG LHD45EL Dehumidifier
Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Apr 29, 2008 | Bosch Classixx WVF 240S Front Load Washer...
Zanussi TC7102W Electric Dryer Logo
91 people viewed this question
Top Zanussi Dryers Experts
Tim Whalen
Are you a Zanussi Dryer Expert? Answer questions, earn points and help others
