Question about Intermatic & Indoor/Outdoor Rain Tight Timer
I am trying to learn how to set up the T104 timer etc. I just moved in and there is no manual how to set timer.
Here are two links that will be handy to keep on file:
http://waterheatertimer.org/How-to-troubleshoot-Intermatic-timer.html
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html
T104 is 240Volt timer.
When you open the door, there should be piece of translucent plastic covering the wiring.
As long as plastic cover is in place, it is safe to touch visible timer parts.
If you have a child who might stick something into the timer, then lock timer door.
As a general rule with electrical devices, do not stand on bare ground or wet surface or lean into or touch anything metal while working on timer. Put down dry boards. Same with your circuit breaker panel.
The T104 yellow dial rotates just like a clock.
The dial has ON and OFF trippers attached to outer edge of dial.
As these trippers rotate around they move on-off lever that turns the pool pump or Load on and off.
ON tripper moves lever one direction, and OFF tripper moves same lever other direction.
The manual override lever clicks back and forth with audible sound each time tripper moves on-off lever.
Move manual override back and forth and it will turn Load on and off.
Override should snap crisp and clean.
To set timer, lift and rotate dial until current time lines up with stationary silver pointer.
Stationary silver pointer is pointed at 6:00.
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on May 22, 2011
  • Anonymous May 24, 2011
    Upvote the hard work here. This answer is 100% correct and researched, and does everything except drive over there and show you how to do it.
How to set up intermatic t104m to work with two speed motor
T104 cannot be easily set up to handle 2-speed motors
You need T106 timer with NO NC terminals.
Or you can use the T104 to control relay with NO NC terminals... relay would need 240 Volt coil. Problem is most relays with NO NC terminals are 120 Volt coil or rated too low amperage for motor.
Or move T104 clock motor wires to A and 1... connect 240Volt power to A and 1... then terminals 3-4 are dry and can be used to control any voltage relay coil (120 Volt for example).
When T104 is ON, then relay uses NC terminals to send power to low speed. When T104 is OFF, then relay uses NO terminals to send power to high speed.
Buying T106 timer is probably cheaper and simpler.
http://www.amazon.com/dp/B000JJM7ZS/?tag=waterheaterti-20
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html#T106
http://waterheatertimer.org/Buy-T100-series-timers.html
http://waterheatertimer.org/Intermatic-control-centers-and-manuals.html
Gene
Sep 21, 2014 | Intermatic Hardware & Accessories
What position is lever on intermatic pool timer t104p3 for timer to work?
Lever automatically moves back and forth as trippers pass.
Move lever to ON position, move to the right.
If timer dial is not rotating, then check wiring, or replace clock motor:
If timer worked before and stopped working, but dial still rotates, the trippers are worn down, replace trippers:
http://waterheatertimer.org/How-to-operate-and-set-T104-timer.pdf
http://waterheatertimer.org/Buy-T100-series-timers.html#pool
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html#T104
Gene
h
May 20, 2014 | RTO Intermatic Inc Ej351c Timer Night...
The "little gray box"
You need 2 ON trippers and 2 OFF trippers.
Part number 156T1976A sold at WW Grainger etc.
1) Copy following links for WH40 little grey box Intermatic timer operation and resources:
http://waterheatertimer.org/pdf/How-to-operate-and-set-T104-timer.pdf
2) WH40 timer is identical to T104, same replacement parts, same operation, same wiring options, except the grey box timer has override lever that sticks out of box. Both WH40 and T104 have override levers, the WH40 override can be moved without opening box door.
This allows you to use the WH40 as ordinary on-off switch if the trippers are removed from dial.
Jan 25, 2013 | Intermatic Hardware & Accessories
T104 intermatic stationary pointer moved to the side
T104 pointer is stationary and is supposed to be pointed straight down, assuming timer is installed in vertical position.
Move pointer until it points straight down and apply bit of super glue, or just remember correct location.
Copy following link for detailed information:
Jul 15, 2012 | Intermatic & Indoor/Outdoor Rain Tight...
Moved pointer intermatic T104
The time pointer is supposed to be stationary.
On T104 timer the pointer is stationary pointed downward at 6:00 position. So you can move it so it is pointed straight down and add a bit of super glue where pointer meets stem.
Copy following link for instructions how to set T104 timer:
Jul 05, 2012 | Intermatic T104 24h 208-277v Mechanical...
Timer T104 triggers can't move
Problem is not identified.
Copy following link to troubleshoot T104 timer:
http://waterheatertimer.org/How-to-troubleshoot-Intermatic-timers.html
Dec 21, 2011 | Intermatic Hardware & Accessories
My timer for sign is Intermatic T104,I Don't know
Copy following link to troubleshoot Intermatic timer:
http://waterheatertimer.org/Intermatic-timers-and-manuals.html
Dec 20, 2011 | Hardware & Accessories
I have Intermatic Model T104 timer for my pool. The power went off a few days ago, and i have not been able to set it where i wanted it since. I do not have a manual. The pool contractor didn't...
Open following links for T104 timer manual and information, and then add a comment for more information.
Jun 24, 2011 | Intermatic Industrial 24 Hour 120v...
How do I program this timer?
T104R3 is ordinary 240V T104 timer mechanism inside a beige metal weathertight enclosure.
Put ON-OFF trippers on dial, lift and rotate dial until current time lines up with silver pointer.
Reset current time after power outage.
Open following links for T104 Instructions:
http://waterheatertimer.org/pdf/Intermatic-t104-240V.pdf
Open following link if you have T104R201 with fireman's switch
http://waterheatertimer.org/pdf/Intermatic-T104R201-instruction-manual.pdf
Jun 23, 2011 | RTO Intermatic T104R3 Timer Switch 220V -...
When setting my timers should the manual switch be left in the on or off position?
Either position is fine.
The override is not permanent ON or OFF since it moves back and forth when trippers pass.
The trippers push a lever back and forth that opens and closes electrical circuit.
When the lever moves back and forth, it also clicks the override back and forth with audible sound.
If the timer is ON, you can move the override to OFF.
When the next ON tripper rotates around, it will move the override back to ON.
So the override just temporarily overrides the timer function.
Jun 21, 2011 | Intermatic T104 24h 208-277v Mechanical...
Intermatic & Indoor/Outdoor Rain Tight Timer  Logo
323 people viewed this question
Top Intermatic Hardware & Accessories Experts
Craig Butler
Craig Butler
Gene Haynes
Jay Finke
Jay Finke
Are you an Intermatic Hardware and Accessory Expert? Answer questions, earn points and help others
