Question about Whirlpool Washing Machines
My whirlpool washin machine won't drain? - Whirlpool Washing Machines
    Genius:
  • 1,044 Answers
Please check the out let pipe and the out let. Sometimes they get clogged with the dirt and lint. Also check that outlet cover is functioning properly and not stuck up.
Posted on May 22, 2011
2 Suggested Answers
rickyrt441
  • 4399 Answers
SOURCE: Whirlpool duet Washing machine won't drain
Thanks for choosing FixYa and welcome. If your washer doesn't drain or spin, you may read and learn what parts may cause this. First, you will want to check your water pump. You need to make sure it is working. Make sure you check the belt on the pump. Make sure it is not broken or loose. Also, make sure your pulley is not stuck in place. Sometimes, they will stick or barely turn at all. If this is the case, you will need to replace it. If the pump, pulley, and belt are working, make sure your motor is working. You should be able to hear it if it is. If it isn't, check your lid switch. The lid switch can cause the motor to not work. It may need adjusted. If not, go ahead and change it. A bad lid switch may cause the washer to not work at all. Now, if your pump is pumping and the washer still won't spin, you will want to check your belt and clutch. Once again, the belt may be broke or loose. Check to make sure your clutch is not worn also. This may be a case of a bad lid switch again as well. You could have a bad drive motor. This is what controls spinning, draining, and agitation. You could have a broken motor coupler. Over time, they will go bad and need replaced. It is possible that your transmission is slipping or damaged. And lastly, you could have a bad basket drive or spin bearing. This is what allows the inner tub to move. If this is the case, you will probably hear loud sounds or loud banging.
Posted on May 11, 2011
Whirlpool top loading washer won't fill completely
did you shorten the stand pipe for the outlet drain ?if not try putting a short extension on the top .
Nov 18, 2017 | Whirlpool Washing Machines
Whirlpool wtw5700sw0 sometimes won't spin
It is possible that the motor capacitor is weak and so does not start by itself. So use a similar value capacitor in parallel to confirm.check this link;
http://www.espares.co.uk/advice/washing-machines/a/7/1379/how-to-replace-the-carbon-brushes-on-a-washin.html
Mar 14, 2012 | Whirlpool WTW5700S
Whirlpool wtw5700sw0 won't spin and motor hums
Please check the motor capacitor, use a capacitor in parallel to confirm. check the motor spindle and paddle for free run., Please check this link;
What should i look for on my whirlpool washer if it hums but won't spin, agitate, or drain?
The motor may be shot if it is getting current and won't operate the washer.
Nov 04, 2011 | Washing Machines
Whirlpool washer model LSR5232LQ0 won't drain. just stops. is there way to cause drain?
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 22, 2011 | Whirlpool Washing Machines
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE please show me a diagram
Jun 14, 2011 | Whirlpool LSR7333 Top Load Washer
Whirlpool LSR5132PQO not working
Check the lid switch with a volt/ohm meter for continuity.
If no continuity, replace the lid switch.
Check the direct drive coupling on the motor.
If it will not drain, bad lid switch.
If it will not agitate or spin bad drive coupling.
Feb 27, 2009 | Whirlpool LSQ8000 Top Load Washer
Washing Machines Logo
21 people viewed this question
Dan Webster
Dan Webster
Sal De
