Question about Philips GoGear SA2825/37 MP3 Player
Hi my philips gogear spark 2gb is stuck on the language selection screen. I have tries resetting it but the screen just turns off when I press reset. The problem persists even when I turn it on and off. I can access the files in my pc but I cannot go beyond the language selection screen on the device itself. Please help.
My ipdo get struck..not at all working ....even it reseted many times
Posted on Apr 03, 2012
    Problem Solver:
  • 5 Answers
Hi, please check my other solutions with gogear spark. l repeated two times with two problems, so please check it.
Posted on Jun 22, 2011
PHILIPS GOGEAR 8GB STUCK on the screen showing that Go gear & if I press the reset buttan it wont works what should i do?
read owners manual,you can look inside manual also for technical support number they will help you.any time you buy devices they have instruction manual that tell you how to operate device.
Nov 13, 2011 | Philips GoGear Micro Jukebox 8GB...
My Philips Gogear is stuck on the philips screen
Reset.Hard reset: press the 'RESET' button with the end of a paper clip or the point of a pencil. Then try to switch on your player. Note: do not use the microphone input.
Oct 16, 2011 | Philips GoGear ViBE Digital Media Player
The screen is frozen on the PHILIPS icon and when i reset it it did nothing, but when i put it on the charger then reset it, it starts charging, but when i take it off the charger it goes back to the...
Please follow the below steps and check if that resolves the issue:
  1. Press down on and hold the "Power" button on your Philips GoGear MP3 player.
  2. Press down on and hold the "Volume Up" button on your Philips GoGear MP3 player. Continue to hold both of these buttons down for three consecutive seconds. The MP3 player will turn itself off.
  3. Press and hold "Power" until your Philips GoGear MP3 player turns itself back on. Your GoGear will no longer be frozen and you can use it as normal.
If you require further assistance then please revert back.
Regards
Anand Gupta
May 04, 2011 | Philips GoGear ViBE Digital Media Player
My 16 gb gogear froze
1 On your computer, select Start >
Programs > Philips Digital Audio Player
> Aria Device Manager > Philips Device
Manager to launch the Philips Device
Manager.
2 Turn off GoGear Aria before you
continue.
3 Press and hold the volume button
while you connect GoGear Aria to your
computer.
4 Keep holding the key until the Philips
Device Manager acknowledges GoGear
Aria and enters the recovery mode.
5 On the computer, click the Repair
button and follow the instructions of the
Philips Device Manager to complete the
recovery process.
6 When the recovery is completed,
disconnect GoGear Aria from your
computer.
7 Restart GoGear Aria.
The full manual is found here: http://www.p4c.philips.com/files/s/sa1ara16k_17/sa1ara16k_17_dfu_aen.pdf
Oct 29, 2009 | Audio Players & Recorders
GoGear Aria reset stuck in, will not turn on.
Have you reset the player? Reset the player by holding the off-switch and the volume-+ (plus) switch.
If this doesn't help try this: Connect your player to the pc that has the Philips device manager running, then reset the player by holding the off-switch and the volume-+ (plus) switch. As soon as the player shuts off, press and hold the volume- - (minus) switch. The Philips device manager will recognize the player now, and recommend a repair, let it do so.
Aug 18, 2009 | Philips GoGear HDD1830 MP3 Player
Stuck on Scyn screen!
It is normal for it to display the "Do Not Disconnect" screen.
It is not normal for the Windows Media Player not to recognize it.
If you have Windows Media Player 11, update the firmware.
If the PC is not recognizing the device:
Make sure the hold/lock is not engaged
Try another USB port
Reset the player
If that fails:
Download the newest version of the Philips Device Manager:
www.usasupport.philips.com - change your country/language as needed
Enter in your exact model #
Click on the link for your exact model #
Click on the Software & Drivers section
Click on "Firmware Upgrade Software"
Install the new Device Manager
Open and run the "Repair" tab
If still nothing:
Disconnect the Go Gear from computer. Press the reset pinhole until the player turns off. Hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard. If this pop-up does not appear, reset the player again WHILE connected to the computer. Open the Philips Device Manager, and go to Repair Tab. Reset the player one more time while connected to computer. Follow the repair instructions.
After repair is complete, upgrade the firmware for this player. Will erase all the songs, but you should be good to go again.
If these methods fail, call Philips to see if you are still in-warranty.
-Tha Mp3 Doctor
Mar 26, 2009 | Philips GOGEAR SA6045 MP3 Player
Philips HDD082/17
when this unit gets stuck on screen usually caused by not safely removing hardware from computer. in that mode you press power and vol + button at same time for a couple seconds and will reset. sofware available through philips website: http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?ctn=HDD060/17&slg=AEN&searchtxt=HDD0
Jul 14, 2008 | Philips GoGear HDD060 MP3 Player
Philips GoGear 30 GB HDD6330 Won't Turn on.
Try a soft reset by pressing and holding [VOL+] & [POWER]
whenever this happens, then try powering up again.
If this doesn't work, it could be corrupt firmware. Run the Philips Device Manager software (on the product CD). Select the Restore / Repair option and follow the on-screen prompts.
This will format the player and re-flash the firmware.
Note: ALL tracks will be deleted from the player.
Mar 07, 2008 | Philips GoGear HDD6330 MP3 Player
Philips GoGear 2GB MP3/Video Player LOCKED ?
you have to look at the side and shift the lock button
Nov 26, 2007 | Philips GoGear HDD075/17 MP3 Player
Philips GoGear SA2825/37  MP3 Player Logo
393 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
