Question about Dryers
Door catch has broken on the tumble drier - Dryers
    President:
  • 3,074 Answers
You will need to order a new on, do not know what type but here are two websites, Good Luck Tim:
eBay:
http://shop.ebay.com/i.html?_from=R40&_trksid=p5197.m570.l1313&_nkw=dryer+door+switch&_sacat=See-All-Categories
repairclinic:
http://www.repairclinic.com/Dryer-Switch-Parts
Posted on May 22, 2011
How to adjust door on white knight tumble dryer
Micro switch may need adjustment as when pressure applied to door the dryer operates. It may be the operating arm (if there is one) needs to be bent out slightly. I switch has a button operator then maybe an adjustment of switch position will fix. If not try gluing a small piece of plastic to the door where the operator pin is and this may work.
May 30, 2014 | Dryers
How to get the lid of Hotpoint tumble drier Model PCF780
Usually the lids are released by a putty knife in the corners, releasing a catch.
Dec 01, 2013 | YouTube Videos
Bosch Exxcel Condenser
replace the broken drive belt
May 13, 2013 | Dryers
My door for a hotpoint ctd40 tumble drier wont stay closed. The spring latch seems ok but not holding dooe closed. Any ideas since it dont say anything in my manual about it and its 2 yrs old. cheers andy
Hi andy.
the fault is likely to be in the roller catch mechanism. Hotpoint have modified these. Part Number is C00257618.
It includes both door latch and catch.
If you have problems obtaining one please email me on: aardvark.repairs@btinternet.com or call me on 01733 307019
Regards
aardvark repairs
Nov 18, 2009 | Hotpoint Dryers
The tumble inside stoped turning.
You have a broken belt on your drier. Take the back of your drier off and youll see the problem.
Good Luck
Dave
Aug 11, 2009 | Kenmore 77032 Dryer
Dryer won't heat. I just replaced the felt seals on the drum, the door switch didn't work but after I unplugged it & reconnected it worked. Could it be the doorswitch? I replaced the high temp switch a...
A tumble dryer that isn't heating up at all needs checking with a continuity test meter. The most common cause is a heating element failure, or t.o.c's going open circuit. It depends on which make and model of tumble dryer you have as to how easy it is to get to the relevant parts. Some tumble dryers have heating elements that are easily accessible by removing the back panel, and can be tested for continuity or checked for obvious breakage. Others though have their heating elements inside, which aren't accessible without stripping the dryer down. Tumble dryer heating elements are always protected by thermal fuses which are usually simple devices with 2 wires connected. They can be tested for continuity with a test meter
or
If power is getting to the tumble dryer and the socket is definitely OK, then the most common problem with tumble dryers not working is when the door micro switch fails, or the catch on the door that operates the switch either breaks or no longer activates the door switch. Check for broken door catches. There is usually a plastic peg on the door that pushes through a hole in the tumble dryer's casing where the door catch is. Closing the door should operate a simple micro switch. If the plastic peg is broken or bent it might not operate the switch properly
Jul 19, 2009 | Hotpoint NVL333GY Gas Dryer
Valh my dryer model fer641fso wont start when i push the start button it does this low beeping sound bought brand new only owned for 5 months worked fine all day yesterday stopped working last night.
If power is getting to the tumble dryer and the socket is definitely OK, then the most common problem with tumble dryers not working is when the door micro switch fails, or the catch on the door that operates the switch either breaks or no longer activates the door switch. Check for broken door catches. There is usually a plastic peg on the door that pushes through a hole in the tumble dryer's casing where the door catch is. Closing the door should operate a simple micro switch. If the plastic peg is broken or bent it might not operate the switch properly. OR The start capacitor may have failed and i would not suggest you deal with that as they give out a nasty electrical charge, also check and clean all filters and check your user manual for further advice as your machine should still be under warranty, call the numbers listed in your manual. good luck
Jul 19, 2009 | Frigidaire Electric Dryer
Hotpoint CTD00 Door Catch Replacement
If yuo are referring to the catch on the door, then undo all the scews holding the 2 halves of the door together, and prize apart, fit new door catch.
If you mean the door lock, then you will have to remove the top cover and right hand side panel to access the door lock.
Hope this helps.
Plz rate this solution.
Thanks.
Dec 26, 2008 | Dryers
White knight 767 tumble drier
If the rug was very heavy you could have burnt up the motor. If it will restart after it cools off, replace the motor and clean out the vent system.
Good luck.
Dec 08, 2007 | Dryers
How to reassemble door catch of indesit tumble drier
Very difficult to explain with out pictures, the pin should go through the spring it really is a matter of fiddling until you get it right or go back to where you bought it from and ask them how it goes.
Nov 30, 2007 | Dryers
Dryers Logo
Top Dryers Experts
