Question about Philips DVP5982
DVD Door keeps opening and lcosing during viewing?
  • ed_faroun May 28, 2011
    I couldn't get to this the same day and I was out of town on business but I have looked today and could only find one leaf switch, contact seems to be fine.
    sorry fo the delay adn thanks for your help.
    Top Expert:
  • Philips Master
  • 75,311 Answers
Hello
Its loading belt is loose and so the tray do not close properly. Replace the loading belt. Loading belt can be located under the tray connected between loading motor and loading gear assembly. Check whether there is any break in gear wheels too. If so replace them too. Tray is not close properly is your DVDs problem. OK.
Posted on May 22, 2011
  • 1 more comment
  • ed_faroun May 22, 2011
    Thanks gopakumarg43, I took a look and everything seems to be in order, the gears have no wear and tear and so also is the belt, could it be the logic board? I would be bale to watch for about 15 minutes and then it would start openning , closing, loading, opening ..and so on and so forth.
    thank you
  • The Knight
    The Knight May 22, 2011
    Hello - If so, check the leaf switches also. There is two leaf switches fitted inside the loading tray mechanism as sensors. One is open sensor and the other is close sensor. They can be located underside the loading tray, fitted to its main frame. If close leaf switch doesn't get proper contact after loading, this type of intermittent open-close truble may occur. Before suspecting and confirming to the logic board, check this also. OK.
  • The Knight
    The Knight May 29, 2011
    No. There will be two leaf switches, one is close sensor and the other is open sensor. Look keenly into the loading mechanism.
What causes door to open during cycle
The door has an electrically actuated door lock/latch. it must be defective or hanging up at times.
Nov 05, 2016 | Washing Machines
Dryer door pops open during cycle
Good Afternoon Friend,
I understand that your Frigidaire dryer door keeps popping open during the cycle. I suggest making sure that the door has been completely closed before starting the cycle. If this is done, and the door is still popping open, there might be something going on with the door latch. I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your appliance and determine why the door keeps opening mid-cycle. Hope this is helpful.
-Best regards-
WP
Jun 07, 2014 | Frigidaire Electric Dryer
Microwave not turning off when door opened during operation
It is likely a bad door switch or mount. See the help file here.
On some models, the door switches, fuses, and TCOs / thermal cutouts / thermostats must be checked, too. See photo below.
There should be a "mini-manual" (tech sheet) hidden inside the unit - behind the back, behind the control panel, or hidden on the left side behind the grille - which is very helpful when troubleshooting, testing, and locating components.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Dec 15, 2011 | KitchenAid Microwave Ovens
My device cant open the disc tray please advise me on what to do
Electronics Corporation sells inexpensive DVD players. The DVD players, however, often exhibit problems due to their manufacture and way that they work, which must be dealt with during the course of the player's life. Knowing what these problems are beforehand can aid in resolving difficulties when using the DVD player. In some cases, it can help eliminate the problem before it can become catastrophic
The disc door is not properly closed if the Disc player display shows an "Open" error message. Check that there are no gaps in the door and use the remote to open the disc door. If it will not open, unplug the Disc player and gently pull out the disc door and then push it in. Plug the Disc player back into the AC socket.
If the DVD has not been inserted properly into the disc tray, a "No Disc" error message will come up on the display. Eject the disc and lightly flick off dust using the edge of a lintless cloth. Inspect the disc for damage. Insert it carefully again into the disc tray and use the remote to close the disc door.
Because the Disk player is inexpensive, the power supply is not of the highest quality. Having a surge protector to plug into the Disc player will help to keep the power supply from being damaged over the course of its lifetime.
Have a nice day
Feb 16, 2011 | Audio Players & Recorders
Disk access door won't close
This sounds like the door latch is broke or stuck it may have to be sent in for repair...go to www.sony.com customer service and they will take good care of you!
this should fix ya!(please eate me acordingly!,This is what keeps this free site running
Thank you!
Dec 13, 2008 | Sony Handycam DCR-DVD100 DVD Camcorder
"Loading disk" appears on screen during movie viewing
buy a can of "dust remover air" or canned air , open unit and flush dust from the unit with emphaisis on the underside of the disk tray.. the sensor are dirty the sense the disk insert .
cliff
Dec 30, 2007 | Durabrand PDV-709
Dishwasher DI450 Door
Hi chrissy99
Not sure what do you mean by keeping the door to stay open. Well if you want to keep the door open during operation , identify the mechanism that triggers the on button .
In my dishwasher to check if it function properly , I keep a small wedge / strip near the handle / button which opens the door.
Dec 18, 2007 | Indesit 18 in. D41 Slim-Line Free-standing...
Philips DVP5982 Logo
175 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
