Question about Polaroid i737 Digital Camera
My camera says "card locked".
  • 21 Answers
  1. Remove you memory card.
  2. Check on the sides, it should be a "small slider"
  3. Slide it the other way
  4. Should be unlocked now.
Posted on May 22, 2011
  • 10865 Answers
SOURCE: how do you unlock camera card it says card locked
Hi. Remove the card. On the side of the card is a small sliding lock. That's it. J.
Posted on Jul 12, 2010
  • 102366 Answers
SOURCE: "CARD LOCKED"-just downloaded pictures from memory
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
It's easy enough for the switch to get moved accidentally, especially when inserting it into a card reader or a camera.
Posted on Nov 15, 2010
Testimonial: "That was exactly what the problem was...Someone that I know had already given me that answer and my card is now unlocked and ready to go!! "
lock123
  • 6831 Answers
SOURCE: My camera screen is saying the "Card is Locked".
Hello
OK, if the memory card itself is locked, you might sometimes get this error code. All you need to do is to take out the memory card and switch the lever on the left side to the unlock.
If the error is still displayed after you did the above, you might want to try the card in another camera.
If the card works in another camera . the problem is with your card reader in your camera.
If you open you sd slot and look inside with a sharp light , you should be able to see on the left side of the slot there is a little copper or spring steel lever switch. This switch work as follows:
1. When no card is inserted / no write protection , the switch is open and thus the protection is off.
2. When locked card is inserted , the tab is depressed and tells the camera that the card is lock.
Contrary to popular belief ,the little tab on the sd card is not an electronic switch and does not physically influence the card operation itself. If you put a locked card into a camera without a sd lock switch , you would still be able to use the card normally.
It is incredible difficult to fix this switch because of space limitations in the sd card. Look into the sd slot and if you can see the switch , use a needle to pull the little tab down toward the base of the camera by about 2mm or until it works being careful not to bend it.
If this does not resolve your problem , there might be a short in the switch circuit and the camera will need to be disassembled to resolve this error. This should cost no more than $50.
Please feel free to contact me if you need further information
Kind regards
Andrea
Posted on Dec 08, 2010
Testimonial: "Brilliant! Thanks for an instant solution."
  • 70 Answers
SOURCE: Every time I try n
Slide the lock switch on the SD card away from the lock position. It is a small plastic switch, usually yellow or white, on the side of the card.
Posted on Jan 02, 2011
  • 262 Answers
SOURCE: Camera is saying "card locked" how can I unlock it
Why does my camera say "Card Locked" or "Write Protected"?
The basics. In the same way that the recordings on audio cassettes and VHS tapes could be protected by breaking off the little tab on the back corner, the material on a memory card can be protected against being overwritten. Instead of a tab to break off, write protection is done by a tiny slider on the edge of the card (opposite the cut corner). Before the camera will take pictures, it's necessary that this slider on the card operates a microswitch in the camera, which it will only do if it's NOT in the 'lock' position. The slider actually does nothing inside the card, which is why I don't call it a 'switch' even though it seems like one. Its only purpose is to be detected by the microswitch in the camera's slot, and it's the camera that takes care of the write protection, not the card.
Diagnosis.
Obviously the first thing to do is to check that the slider is NOT in the lock position. If the camera is giving you this error in the unlock position, it means that the slider has failed to operate the microswitch, or that the microswitch itself is faulty, or possibly that there's some file system error with the card. To diganose the problem, it would be really helpful if you could try two or more different memory cards in the camera and see if just one, or all of them exhibit the problem.
If only one memory card exhibits the problem: In this case, it's clearly something to do with the memory card. Is the slider worn, bent or missing? A missing slider will write protect the card in the same way that sliding it to the 'lock' position will. There's another possibility. I've recently discovered that
some cameras which use xD-Picture cards also give this error even though those cards don't even have lock sliders! Furthermore, some users have reported fixing this error by reformatting the card. Therefore, I feel it's also possible that your error may be fixed by reformatting. Before you do this, make sure that you've copied all you want off the card and then use the camera's 'format' function to reformat the card. I advise using the camera for the format function because this guarantees the correct file system. If you use your computer to format it, you may easily get the wrong one. However if you need to do it this way, see which file system is currently in use on the drive before you start. Go to "My Computer" and right click on the drive which is the memory card, and choose "Properties". Examples of filesystems are "FAT" (probably FAT16), "FAT32" and NTFS; to make sure your reformat is successful, ensure you use the same filesystem as before.
If some memory cards work, and others don't, or the same cards sometimes work but only sometimes:
The slider is really tiny, so it's possible that the number of people reporting this error is caused by lack of precision in manufacturing sizes. It must be hard to make a microswitch that can feel such a small thing. Does a better brand of card work? Can you bear to simply stick to the better brands, or the ones that work most reliably? As a remedy of last resort, you could try wrapping a small strip of sticky tape over the slider to increase its thickness, but I think this is a risky solution. There's a risk that the tape will come off in the slot and cause even more problems, or that the tape will be so thick that the card will jam in the slot and you'll have trouble getting it out.
If all of your memory cards behave in the same way: In this case, it's clearly something to do with the camera. It could be that the microswitch is broken, or there's some software error. Although it's less likely, let's cover the software error first; please find the 'system reset' function in your settings menu and use it to clear everything. Any good? If not, try the sticky tape solution in the last paragraph in the hope that it's a size/fit problem with operating the microswitch, but if that fails we're out of options really, beyond a repair of that microswitch.
Posted on Feb 10, 2011
I need a manual for the sanyo 4x optical zoom 14.0 720p HD
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
If you require a manual, please specify the model of the camera instead of merely listing its features.
Feb 18, 2013 | Cameras
Just installed a new memory card in my powershot A430 and the camera says memory card error, card is locked. how do I unlock?
What type and size memory card? The A430 works with SD cards. It won't work with SDHC cards.
Jun 28, 2012 | Canon PowerShot A430 Digital Camera
Camera states on screen that "card locked". How do
Sep 20, 2011 | Canon IXUS i7 Digital Camera
Canon Powershot SA710IS Screen tells me the "Card Locked!" How do I unlock it, please? Not had this feature before in the 4 years I have had this camera
Take the memory card out of your camera and look at it. SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Sep 01, 2011 | Cameras
Apr 24, 2011 | Canon PowerShot SD1200 IS / Digital IXUS...
How do unlock "card locked!"
There are several possible causes for "memory card locked", "memory card error", or "no memory card". Some include trying to use a 4GB SDHC card with an older camera made before SDHC format came out. Others include problems with the tiny slide switch on the side of the card, or the electrical contact switch internal to the camera. The problem may also arise from simple formatting problems if the card has never been formatted in the camera (note that this will also erase the card). Troubleshooting tips for this problem may be found at this link.
http://camerarepair.blogspot.com/2009/07....
thanks.
Apr 11, 2011 | Jazz DV150 Camcorder
Every time I try n take a pic my samsung sl30 camera says "card locked!" How can I unlock the card?
Jan 02, 2011 | Samsung SL30 Digital Camera
THIS IS THE SECOND MEMORY CARD THAT HAS GOTTEN LOCKED IN MY CANNON A470 CAMERA. IT SAYS "CARD LOCKED!"
Nov 16, 2010 | Canon PowerShot A470 Digital Camera
Nov 15, 2010 | Canon PowerShot SD750 / IXUS 75 Digital...
Card locked!
there will be a small projection at the side of the memory card. push it to its opposite side. this will unlock the card.
if not solve try that card in a card reader then use it in camera.
Dec 24, 2007 | Cameras
Polaroid i737 Digital Camera Logo
60 people viewed this question
Top Polaroid Cameras Experts
Greg Cann
Greg Cann
Are you a Polaroid Camera Expert? Answer questions, earn points and help others
