Question about Garden
The engine starts with the choke on but stalls when the choke is opened
    President:
  • 3,074 Answers
Carburetor needs cleaned/rebuilt, Tim
Posted on May 22, 2011
Stalls when choke is opened.
If you adjusted idle to spec with the choke on, you need to do it again with a fully warm engine. Try turning up the idle with the choke on, to around 3k rpm, then see if you can back off on the choke.
You have a fueling issue - have you done carbs before? there are internal passages and settings that must be cleaned and adjusted.
Dec 02, 2015 | Power Motorcycles
99 FXDWG, Choke cable broke, bike stalled then wouldn't start. I fixed the choke cable but bike still won't start. Any ideas?
"Crank" and "turn over" mean exactly the same thing. I think you mean it won't "fire". How did your choke cable break on the highway? You shouldn't have been pulling (closing) the choke at that point - does that ride have other issues?
It might be flooded now - try letting it sit for several hours, then try starting with the throttle WIDE OPEN and no choke - that helps clear extra gas out of the cylinders.
You might also need to pull the spark plugs and dry them out thoroughly.
Aug 13, 2014 | Harley Davidson FXDWG Dyna Wide Glide...
Poulan pro ppb350 weed trimmer stalls when choke is open
-After start for 10-20 second. Choke lever should turn or move to full open before need more gas. Why it stop when you give more gas..?
Because the engine need more air to burn the gas.
Good Luck
mai
Jun 06, 2014 | Garden
My 1996 VF 750 C Magna starts fine with the choke open. After a minute or so as I reduce the choke and try to open the throttle, the engine just stalls out. Cannot seem to get the throttle to control
I think you are mixed up. The choke is usually closed to start a cold engine and opened once the motor warms up. The choke is closed to restrict the air flow and make the mixture richer in fuel. You can't open a choke that's already open. It's stalling because it's starved of fuel. Either a blockage or the fuel pump is not supplying enough gas.
May 06, 2012 | 1996 Honda VF 750 C Magna
Engine starts but won't continue to run. Choke doesn't stay closed after starting. will stay running only if I hold choke closed manually.
let it warm up with choke closed manually after it starts to stall with choke closed open it and dont let it stall u can learn to play with the choke a little to get it to run right GOOD LUCK!
Aug 14, 2011 | Toro Lawnmower 20099 Mower Mowers Lawn
My 1984 rx7 starts when choke is pulled out. WHen engine warms and choke pulls in it stalls out. when trying to start it back up the engine sounds like it's trying to start, and it does when I pull the...
try removing air filter and spaying CARB CLEANER in carb while holding open intake rub thouroughly with hand in side carb, start vehicle and run... spray more cleane and by hand throttle open and spray reinstall filte and runner good on open stretch of highway.
see how that works
Apr 27, 2010 | 1983 Mazda RX-7
2006 kawasaki 750 vulcan will not idle , will idle with choke
ok buddy on the carb will be some sort of screw and idle screw turn this in 1/4 of a turn with the machine running until it idles at 1000rpm also the choke will stall the engine when warm the choke is only for cold starts get back to me more info or problems f4d68ca.jpg
Sep 24, 2009 | 1992 kawasaki VN 750 Vulcan
Stalling out
Generally with two cycle engine as soon as the engine starts the choke needs to be moved to the off or open position. Some chokes have a middle position that lets the motor run until it is warm enough to move the choke into the open position. In other words weather it is a two or four cycle engine the choke is used only to start the engine. If you unit is newer and still does not run well with the choke in the open position, you may need to adjust the hi-speed circuit to a richer one.
Jul 13, 2009 | Troy Bilt Tb70ss Gas Trimmer
Honda 750 stalls if throttle is opened unless choke is on.
Hmm , sounds like a vacuum leak, check all the hoses, and the rubber intake manifolds and clamps
Jun 18, 2009 | 1992 Honda CB 750 Nighthawk
I start bike by using choke on cold start after 2 minutes once I push in choke engine stalls can you help?
hi nl friday,
here is a trick i learned from a friend who is a great fan of V twins.
on cold starts he usually opens the drain plug to let the carb balancer / floater set. once a few drops comes out, open the choke then start the engine. right after pushing the choke back, twist the throttle to force the jet to spray out.
hope this will work for you.
regards,
voodoo
May 06, 2009 | 2006 Yamaha V Star Classic
Garden Logo
104 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
